Prop quiz...............
Cleaning out my flight box this morning and installing a new Enya #3 glow plug in the N-28's series 21 motor I noticed a couple of things.
First on the APC I saw the numbers 254 X 102. Took me a moment to realize they were the metric equivalent of 10/4", senior moments coming more frequently.
Then I pulled out this Tornado 6/3 prop marked "pusher". A lefty, and the only one I have seen marked that way. Put it on a Cox .049 start it backwards and you have a "puller", right?
To make Ken happy, I will probably toss out all those nylons. But they have come in handy when I have to drill out the hub hole to fit a specific engine for testing purposes.
I don't think that McCoy .35 has ever been ran. I should remove it and bench run it first but may just break it in in the air.....
Just rambling thoughts from a rambling man......
https://www.youtube.com/watch?v=1x28jaeyX2s
Re: Prop quiz...............
Thanks Rod. Mystery solved. I thought I had seen one like it before.
I still often use the same yellow bendy props that i bought back in the early 1990's, great on a Cox model with no wheels fitted , most of mine are pusher props I just run them the other way, I found it great when first using cox engines as they tended to always start backwards for me back then... most were fitted to cox engines i bought from swap meets, I now have reverse direction spring starters on the engines as i needed to put the reverse spring starters from product engines somewhere!
» MY FIRST PROP ROD !!! AT age 57
» Quiz for members
» Spot the real Oliver Tiger (quiz)
» WTB - NIB Cox Prop Rod
» Quiz for members
