» PSA propellors!!!by robot797 Today at 2:32 am
» WEN-MAC STORY
by GallopingGhostler Today at 12:37 am
» Just found this
by batjac Yesterday at 10:39 pm
» I Got Cheated!
by batjac Yesterday at 10:35 pm
by Admin Yesterday at 8:41 pm
» Wen Mac Aeromite/Challenger
by getback Yesterday at 5:39 pm
by rdw777 Yesterday at 12:05 pm
» COX FUEL ?????
Fitting Cox .049 pistons to cylinders..
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Fitting Cox .049 pistons to cylinders..
Roddie. I know you said the screws tightened up ok, but I've found when removing the choke tube from a Surestart backplate that my screrws bottomed & needed shortening, or a washer under the head.
MauricioB- Top Poster
Thanks fella's.. good tips! I like the servo-mount inserts Mauricio! My airplanes almost all have firewalls drilled for mounting the backplate for the fuel-line to be on the R/H side where I usually have a wedge-tank. This keeps the fuel-line as short as possible.
I really don't know why I chose to orient the cylinders "upright" on all six engines.. and I'm going to re-orient them all to run outboard. I honestly don't want to remove the cylinder to mount an engine.. plus; orienting it horizontally helps to protect it in a crash.
This triplane had its cylinder mounted "inboard".. when I flew it 25 years ago. It had balance issues (tail-heavy.. ) so it only flew once.. and crashed.
The damage was minor and I've made some modifications.. but haven't flown it since.
Those top/bottom wing-flaps have been removed, saving .4oz. of weight behind the C of G.
I'll orient the cylinder outboard this time when I try to fly it. Those were the early days when I knew even less than I do now..
One more time.. (humor me please..) Back-plates have been re-oriented for mounting all-four screws to the firewall with a horizontal outboard cylinder configuration. (What a maroon.... Bugs Bunny..)
See that stubby screwdriver? OCD Roddie likes its' ratcheting function. I start each screw by turning it "out" until I feel the screw-threads engage with a "click".. then I tighten each a few turns. I do this to all four screws until they're close to seating. Then I set the ratchet-driver in reverse to act as a "clutch". When the ratchet clicks while tightening.. I switch to a diagonal screw in the pattern. When they all "click".. I switch-off the ratchet and tighten gradually in the same alternating sequence.. (the way I was taught to change a car tire..) without being too heavy-handed.. After all they're only 2-56 size screws.. The PH1 insert-bit fits these screw-heads nicely. The case-screws were sourced from Cox International (Bernie).. as were the back-plates.
The short-style needles and Mylar reeds were sourced from ExModel engines (Matt). I have a few long-style needles.. in the event that I want to try a choke-tube. The short needles are too short to work with them.
Page 2 of 2 • 1, 2
» Crankcase Pressure Fitting use with Tee Dee Engines.
» What are the differences (if any) between Cox .09 TD and Medallion pistons/cylinders?
» ISO plans for a V Twin glow engine using Cox 049 cylinders, pistons, glowplugs
» Tips and tricks for getting that tinyt fuel line on the tiny fitting on the back of all.049s HELP!
» BW & GB pistons
» BW & GB pistons
Page 2 of 2
