HELP! Looking for a ARF R/C plane that uses a COX 049 or 020 - Page 2 Cox_ba12
HELP! Looking for a ARF R/C plane that uses a COX 049 or 020 - Page 2 Pixel
by batjac Today at 10:05 pm
by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
HELP! Looking for a ARF R/C plane that uses a COX 049 or 020 - Page 2 Empty
Page 2 of 2 Previous  1, 2
Help! Re: HELP! Looking for a ARF R/C plane that uses a COX 049 or 020
Post  rainyday101 Fri Jun 09, 2017 6:21 pm
I will start building one and take some pics for you of the assembly process. I just ordered the plans, but I should be able to scale the drawing from the magazine and build from that.
rainyday101
rainyday101
Bronze Member
Bronze Member
Post  Deerej18 Fri Jun 09, 2017 7:40 pm
I would really appreciate it rainy! I have a Spektrum DX6 and fly many bigger nitro models... I guess ill give the build a go and if wait for NO WIND. Thanks again!
Deerej18
Deerej18
Moderate Poster
Moderate Poster
https://Jarrettpoppy.com
Post  Deerej18 Fri Jun 09, 2017 7:51 pm
Should I buy 5 gram or 2.5 gram Servos? also do you have any idea what battery I should be looking for?
Deerej18
Deerej18
Moderate Poster
Moderate Poster
Post  rainyday101 Fri Jun 09, 2017 9:05 pm
servos http://www.headsuphobby.com/Towerpro-14g-MG90D-Digital-Metal-Gear-Sub-Micro-Servo_p_1174.html
All the servos you mentioned are too small. Small servos with those small nylon gears are problematic and strip with 049 engines. When this plane was original designed it probably used standard size servos which were 35 gram +
You will have to ask one of the Spektrum guys on the battery I believe they usually use 6 volt receiver batteries. If I recall correctly some have had issues with the 4.8V batteries getting low and causing the receiver to reboot.
rainyday101
rainyday101
Bronze Member
Bronze Member
Post  Deerej18 Fri Jun 09, 2017 9:17 pm
Oh yeah spektrum receivers require 6.3 volts... im talking how many mah
Deerej18
Deerej18
Moderate Poster
Moderate Poster
Post  rainyday101 Fri Jun 09, 2017 9:22 pm
750 mah is what I typically use. A little more or less won't hurt.
rainyday101
rainyday101
Bronze Member
Bronze Member
Post  Deerej18 Fri Jun 09, 2017 9:40 pm
do those servos come with horns? and what linkages you going to use?
Deerej18
Deerej18
Moderate Poster
Moderate Poster
Post  rainyday101 Fri Jun 09, 2017 10:00 pm
Yes the servos come with horns and I usually use what I have laying around for control rods. Typically 1/16 rod or 2-56. Something like this http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXD855&P=SMhttp://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXD855&P=SM 1/2a control horns. 1/2a aileron linkage. Check out Tower Hobbies and look at this page. http://www3.towerhobbies.com/cgi-bin/wti0091p?&P=SM&C=QFA&V=DUBhttp://www3.towerhobbies.com/cgi-bin/wti0091p?&P=SM&C=QFA&V=DUB. Dubro or Sullivan both make pushrods, control horns, and aileron linkages for 1/2A. It's not overly critical, you just don't want it to light so it flexes without a bunch of support.
rainyday101
rainyday101
Bronze Member
Bronze Member
Post  Deerej18 Fri Jun 09, 2017 10:05 pm
ah ok
Deerej18
Deerej18
Moderate Poster
Moderate Poster
Post  Deerej18 Fri Jun 09, 2017 10:06 pm
your using a 049 correct?
Deerej18
Deerej18
Moderate Poster
Moderate Poster
Post  rainyday101 Fri Jun 09, 2017 10:16 pm
Yes I am using 049.  I am actually thinking about buying a couple of the Black Lynx engines from Ex-Models and using 1 oz. tanks and throttles.
ENGINE
THROTTLE
rainyday101
rainyday101
Bronze Member
Bronze Member
Post  Deerej18 Sat Jun 24, 2017 3:29 pm
Any update?
Deerej18
Deerej18
Moderate Poster
Moderate Poster
