by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
by rsv1cox Today at 3:38 pm
How should I call the engine? What is his new name?
If an old Cox of a model PT19 U-Control, I remove the metal tank of fuel and I place a Surestart Backplate, I also add a Throttle Ring, my question is: How should I call the engine?
MauricioB- Top Poster
Re: How should I call the engine? What is his new name?
I don't think there ever was a "factory original" engine with that configuration, so you'll need to come up with a good name yourself
I think I would call it "Sure Start with a throttle ring" but that is just because of my lack of imagination
EDIT: How about "Mauricio Bee"
KariFS wrote:I don't think there ever was a "factory original" engine with that configuration, so you'll need to come up with a good name yourself
Hahaha! It would be too much for me ... you have made me smile a lot of friend! ... I think that "Sure Star Custom" would in any case be a possible name, what do you think?
You know KariFs, I'm working on a home regulation ring to get the engine turns down at about 4500 rpm. This is because this model is very small and the engine with an original standard setting ring drops to about 6000 rpm and what happens is that it generates enough traction to continue flying, it sways, but it is fast enough to land, the ideal I estimate, would be about 4500 laps thing that the engine does not pull so much and that way land with less speed ...
I noticed also the landing gear struts Mauricio! Very nice! Have you tried different propellers with the throttle-ring? Is there ground-clearance to run a larger diameter prop.? I have run 8" x 3" wood (Zinger-brand) on my Cox .049 reed-valve engines. I only tried this a few times with my control-line models.. to achieve a slower.. more scale-like flight. I put bushings in the propeller-hub to fit Cox 5-40 screw.. and went flying! It's best to test-run a "seasoned" engine for this. Try a bench-run Mauricio.. (exhaust open..) you will love the sound! My fuel was high (25/35%) nitro though.. and I didn't use a throttle. The engine will fire on every revolution (stroke)... except the needle/mixture adjustment range is smaller. Top engine-speed is reduced.. because the engine is "lugging". After a short time.. it is good the check/reset the piston ball-socket joint. It would be interesting to see how/if the engine will run with a throttle-ring/larger-prop combination. The "flywheel-effect" (inertia) should allow lower engine-speed at low-throttle. Maybe try a 7" diameter "Texaco" prop in the case that the 8" takes away too much power. My thought is; if an 8" prop will fly a control-line model with the same engine.. it should be well capable of flying an RC airplane.
I wish you the best luck!
"parts"
But it really doesn't matter. You may name it
Matilda
Jessica
Abigail
Johnathan
Frank
or even
Mud
Call it what makes you happy.
Matilda
Jessica
Abigail
Johnathan
Frank
or even
Mud
I actually kind of agree with Kari. Mauricio Bee has a great ring to it.
The "Me Too" Mark
The "Me Too" Mark
batjac- Diamond Member
MauricioB wrote:If an old Cox of a model PT19 U-Control, I remove the metal tank of fuel and I place a Surestart Backplate, I also add a Throttle Ring, my question is: How should I call the engine?
R/C Sure Bee.
Davenz13- Platinum Member
TLD - Tank-Less Dragonfly.
2-Bee-or-Not-2-Bee.
2-Bee-or-Not-2-Bee.
roddie wrote:Bee-LT.. now I'm hungry..
Bee Lite Throttle - I like it.
In America, a common nickname for "Maurice" is "Mo." You can call it, "Mo Bee." Or Moby, for short.
RustyBee
RustyBee
Ohhh guys, thanks for all your opinions on how to call this engine! .... I like several of the names that you propose ... I will see for which I decide and thus to share with you ...
Meanwhile I show you the acceleration ring I made, it has a thicker section of metal (iron) and this is to maintain or concentrate the cylinder temperature at low turns, (at least that's the idea and it seems that It works!) To see if they like it as it goes:
Very nicely done. Deserving of a better name than "parts" even.
Wow! Nice work Mauricio.. and a great video! Congratulations!
roddie wrote:Wow! Nice work Mauricio.. and a great video! Congratulations!
Roddie, I like how it goes there, it behaves just the way I need it!
A friend hug!
Many thanks Phil for your review!pkrankow wrote:Very nicely done. Deserving of a better name than "parts" even.
Very nice! That throttles better than most much larger engines with carburators. Great work!
fit90- Diamond Member
fit90 wrote:Very nice! That throttles better than most much larger engines with carburators. Great work!
Many thanks Fit90, I highly appreciate your comment.
RknRusty wrote:In America, a common nickname for "Maurice" is "Mo." You can call it, "Mo Bee." Or Moby, for short.
RustyBee
Dear Rusty, I finally decided to call it:
Cox Moby 0.049, thanks for your idea!
Yay Moby !!!!!!!!!!!
Very well done my friend , looks to bee the iron is holding the heat as you had suggested for the lower idle I am glad to bee watching the progress one day i know i will need this on a RC Cox engine plane , Thank you sir !
Hello Kim, that's how I chose that name since Rusty has taught me how my name is produced in your country and how is the way, so that way makes me feel closer to you, I really enjoy being here sharing with everybody.Kim wrote:Yay Moby !!!!!!!!!!!
» What did Comet call the OK .059-.060 engine?
» Now here is a jet that interests me!
» Put in a - Where are ya? PM call
» Knob Style Sandblaster Engine disassembly
» **Black Lynx Engine Giveaway Jan-June 2022** Cox Engine of the Month
