Test stand fuel tank experiment Cox_ba12
Test stand fuel tank experiment Pixel
Test stand fuel tank experiment Empty
Test stand fuel tank experiment Empty Test stand fuel tank experiment
Post  rsv1cox Mon Dec 26, 2016 6:20 pm
Tired of fighting the existing fuel tank on my test stand I came up with this:
Test stand fuel tank experiment Fuel_t10
One continuous fuel line from tank to engine. Drilled a hole at the bottom of the tank slightly smaller than the silicone tubing resulting in a tight friction fit. Holds one ounce, easily refillable during run if necessary and removable for cleaning.
I just got tired of all the fuss mounting that original tank, then pulling the plug to clean the remaining goo out of it. Spike donated one of his old pill bottles. I could wrap it in thin foam to help with any foaming problems.
Test stand fuel tank experiment Fuel_t11
Test stand fuel tank experiment Empty Re: Test stand fuel tank experiment
Post  getback Mon Dec 26, 2016 6:36 pm
Thumbs Up I like it and know what your talking about with the tank flopping{ in my case }around You got the WORK HORSE 200 in drive Hand Shake
Post  roddie Mon Dec 26, 2016 7:13 pm
I like that Work-Mate approach.. in that it's adjustable to different width cases. Ever thought of cutting two planks to match.. and bolting them to (over) the Work-Mate's pads? You could flip them around, as well as flip them over.. to provide four different beam-mount patterns. It appears that there's holes there already, to use as a guide for drilling/mounting the auxiliary-pads. Just a thought. You could run most all of your beam-mount engines having different fore/aft spacing. Maybe the Enya's are all the same.. in which case.. never mind. Laughing
Good luck with the new tank set-up! It looks like you can adjust the height if needed. The thin foam you mentioned might help to hold the height-setting in the block too.
Post  rsv1cox Tue Dec 27, 2016 12:34 pm
My new best friend
Test stand fuel tank experiment New_fu10
Just fill it right from the bottle.  No syringes or bulbs or associated contamination.  Remove from holder when finished, remove cover and wipe clean, a little compressed air through the tube doesn't hurt.
Test stand fuel tank experiment New_fu13
Test stand fuel tank experiment New_fu11
Nasty Enya .15 as received.  Preheated slightly with a heat gun, 20/20 Traxx? car fuel cut with castor wouldn't run.  Lot's of brown stuff coming out of the exhaust.  NV from full in to full out and everything in between, throttle set at half.  Pumped near a whole tank through it which probably cleaned it out a bit.  That fuel has always worked in my other engines.
Test stand fuel tank experiment New_fu16
Added 25% Cox fuel uncut to an almost empty tank and she took right off running great through the TV range.  No RPM conclusions can be made however. I will run it again after a crock pot boil.  Tach shown taken at about 1/2 throttle.
Test stand fuel tank experiment New_fu14
You read my mind roddie.  I had cut new table tops before I destroy the originals leaving out the peg holes.
Test stand fuel tank experiment New_fu12
Ready for the pot.  I have loosened the case and head machine screws (warm engine).  I like replacing the same screws where they came from head and case.  Sometimes I get so picky I ensure the same screws go back in their original holes especially if they are unmolested engines.
Test stand fuel tank experiment New_fu15
Post  roddie Tue Dec 27, 2016 3:50 pm
It's nice when things work.. and are easy to clean too! Thumbs Up I notice you're using what look like sheet-metal screws to hold the engine down. Try to find four hex-head cap-screws, washers and lock-nuts.. and drill your new table-pads through to accept them. Make sure they're long enough to tighten with the engine in-place. A "ball-end" hex-key can be angled-away from the case to prevent scratching it.. and the hex-key won't slip-off the head either. Hold the lock-nut on the bottom with a small socket-wrench while tightening. It's a much easier and faster way to mount/remove an engine.
The new tabletops for the WorkMate look like MDO/plywood. Are they? If so.. that should hold up better than the existing particle-board ones.. especially if you drill them for machine-screws. The particle-board I can see is swelling from fuel exposure. I wouldn't count on sheet-metal screws to hold down another engine. You can seal the new tabletops and end-grain with poly, to help prevent fuel-soaking. Two Cents
Post  NEW222 Tue Dec 27, 2016 5:04 pm
Thank you. That is one great idea, and I too will be stealing your idea and implementing it to my workbench the same as yours.
Post  RknRusty Tue Dec 27, 2016 11:38 pm
Me too, maybe a universal clamp mount with a pair of 1/4" or 3/8" thick aluminum clamp bars, just clamping over the crankcase wings with 1/8" bearers under the wings.
With a long clamp bar, you could clamp the smallest to the largest engine in it. Screw it to the workmate with a pair of 6-32 or 8-32 brass inserts epoxied into the workmate.I can't tell you the number of engines I omitted test running because it's a pain. This would solve that lazy problem.
Post  rsv1cox Wed Dec 28, 2016 7:00 am
Thanks for the comments guys.  There is lot's of room for improvement here in both the fuel tank holder and clamp down systems.  I just got tired of floppy tanks held down with fuel saturated gooey rubber bands that were difficult to empty and clean after a run.  This is just so simple.
Yes,  I have to devise a whole new platform system.  I'm thinking 1X4's custom cut to house my various engines.  Most Enya's have mounting holes different from one another as you might think.  Then attaching each to the Work Mate in the same mounting pattern using the first one as a guide.  I like using that WM bench as it's portable and I can bring it outside and let the engines rip.  Or is that RIP... Smile
Or as Rusty says, I could make an adjustable clamp style universal mount, one size fit's all.  On ebay there is a metal stand that I have admired, but I have always thought that I could build a better one.
I'm keeping that fuel supply though, easiest system I have ever encountered.  I am looking to make another fuel supply module for bigger engines, something that would hold about 2 ounces.  Just testing here, not for endurance runs.  Maybe this old vitamin bottle would work.  It just has to be removable and easy to clean.
Test stand fuel tank experiment 00110
I think my spade bit set go's out to I think 2", ought to do it.
I do have ball end hex wrenches by Hobbico both SAE and metric that I have had for years and they do work great on hard to get at places.  But I have few hex machine screws in # 2 & 4 sizes.  Most of my mounting screws are slots salvaged from other peoples engines.
I'm cooking that .15 Enya even as we speak. Eager to see how/if it runs after a boil. Got all the new parts assembled too. Gasket, prop washer and nut, TV control arm, and a new needle. But will use the old needle to check it first.
