» Roger Harris revisitedby rsv1cox Today at 9:38 pm
by GallopingGhostler Today at 9:04 pm
by 1/2A Nut Today at 8:43 pm
by roddie Today at 7:13 pm
by sosam117 Today at 5:32 pm
by rdw777 Today at 3:24 pm
by batjac Today at 3:47 am
by rsv1cox Wed Nov 20, 2024 9:21 pm
by 1975 control line guy Wed Nov 20, 2024 2:17 pm
by rsv1cox Wed Nov 20, 2024 12:35 am
by Cox International Tue Nov 19, 2024 6:01 pm
by getback Tue Nov 19, 2024 12:08 pm
Determine engine wear?
I have never seen this addressed in any of the Cox publications, and I imagine the info is here in the forum, but I am sorry I couldn't find it. It is the question of determining the engine wear of the Cox .049 engines. I want to introduce my 10 year old daughter to the joys of 1/2a flying, and I bought a bunch of used engines to resurrect. I am quite capable of tearing them apart, cleaning, etc., etc. But how do you determine if the piston/cylinder wear is excessive?
AV8TOR
AV8TOR
av8tor1977- New Member
Re: Determine engine wear?
First of all, welcome to the forum av8tor!
Determining piston/cylinder wear in a cox 1/2A is done pretty much by feel or its starting/running manners a worn or loosely fitted cylinder/piston set will feel spongy and lack pop when flipped slowly through compression (make sure the head is tight first with a shim under it) it should rebound when put through top dead center. When running it will be hard to needle and in excessively worn cases will quit after it warms up, it will also be hard to start by hand to a point to where an electric finger (Starter) is needed or the spring starter to get it going. Hope this helps man and again welcome to the forum!! (Bandit)
Last edited by TDbandit on Sun Oct 02, 2016 3:50 am; edited 1 time in total (Reason for editing : fixed typos)
TDbandit- Platinum Member
Mudhen- Gold Member
Mudhen's diagnosis is reliable,and particularly valid for older TeeDee049 and 51 engines with tapered cylinder bore. Later engines did not have tapered bore and the piston of even a new cylinder/piston set may be easy to push over the TDC.
My diagnosis is very simple and the same as written by others above. Check compression by looking at/listening to the hissing blow-by at the exhaust ports when the piston wet in fuel moves upwards.
I have a COX TD 051 engine with near 300 hrs runtime on it that I retired because of its impaired compression. The engine starts with electric starter but drops speed under heavier loads e.g. when the plane climbs steeply.
BTW welcome to CEF.
BTW welcome to CEF.
Engine wear
I've had three engines that deserve comment on their wear.
1. OK Cub 0.049A. Worn out in a single afternoon of flying. Castor oil fuel, snow on the ground so no overheating or dust. Just a soft cylinder or piston.
2. Pee Wee 0.020. Had poor compression and would only run with added oil in the fuel. This engine had a silver tank and I suspect was pulled from a Cox rtf plane.
3. Fox Rocket 0.099. Just gradually lost compression after many hours of running under a combination of summer and winter conditions.
When there is no compression......it's worn out!
706jim- Gold Member
Ok guys. Thanks for the nice welcome and the info. I've got her an .049 profile trainer for she and I to throw together, and I've got the engines soaking in glow fuel. Yesterday I bought some 25% 1/2a glow fuel. Man, this is bringing back some fond old memories!
Thanks again,
AV8TOR
Thanks again,
AV8TOR
I'd just like to add that engines which use separate tanks are a lot more cooperative. The ones with built-on tanks have so many more opportunities to leak air and drive you mildly mad while your young protege stands by getting fidgety.
Good luck, thanks for joining CEF.
I would also like to add if there's no compression, it's not always a worn out piston cylinder. That being said, a loose head, a damaged head gasket, a head not properly flattened which is leaking, a loose backplate, all will reveal signs of low compression which cause hard starting and problematic engine runs. A ball socket not properly set can punch a hole in the center of the piston as well. It doesn't mean the fits are worn out, just that a hole in the piston doesn't hold compression. Bottom line is evaluate the simple things first before heaving the piston cylinder. some of my best running engines were the engines with the lightest compression.
» Engine Wear
» Is there a definitive way to determine if ...................
» Wear Your Damn Helmet
» .09 Piston and Cylinder Wear
