Car Engine Conversion Driveplates Cox_ba12
Car Engine Conversion Driveplates Pixel
by Oldenginerod Yesterday at 11:18 pm
» Engine choice
by 1975 control line guy Yesterday at 9:51 pm
by 1975 control line guy Yesterday at 7:29 pm
by GallopingGhostler Yesterday at 7:10 pm
by GallopingGhostler Yesterday at 7:07 pm
by LooseSpinner99 Yesterday at 6:13 pm
by balogh Yesterday at 5:08 pm
by Ken Cook Yesterday at 2:54 pm
by 1/2A Nut Yesterday at 10:34 am
by sosam117 Yesterday at 8:15 am
by balogh Yesterday at 7:42 am
by roddie Yesterday at 12:32 am
Car Engine Conversion Driveplates Empty
For Sale Car Engine Conversion Driveplates
Post  EXModelEngines Sat Mar 19, 2016 4:16 pm
After much time, driveplates are available to convert the standard car engine crankcase assembly for use with airplane-type applications. These are designed for the large diameter crankcases/crankshafts that had a tapered end and typically used with a flywheel.
http://www.exmodelengines.com/cox-.049-driveplate-tapered-crankshaft-converts-from-car-assembly.html
Also we have the entire assembly available. The case and crankshafts are refurbished while the driveplates are new. It is being offered at the current price of $6.95 for a limited while.
http://www.exmodelengines.com/cox-.049-airplane-engine-crankcase-assembly-converted-refurbished.html
Matt
EXModelEngines
EXModelEngines
Official Cox Dealer
For Sale Re: Car Engine Conversion Driveplates
Post  happydad Sun Mar 20, 2016 5:01 pm
EXModelEngines wrote:After much time, driveplates are available to convert the standard car engine crankcase assembly for use with airplane-type applications. These are designed for the large diameter crankcases/crankshafts that had a tapered end and typically used with a flywheel.
Matt
Finally.  great job, Matt.
happydad RC Plane
happydad
happydad
Post  crankbndr Sun Mar 20, 2016 5:55 pm
Seems like the diesel runners might like this, the crank is much larger.
Post  Cribbs74 Sun Mar 20, 2016 7:15 pm
Stronger than a KB crank I bet. Although I think the pin is the weak link on the standard crank.
Wonder how it would fare in tach race/reed speed?
I think I have a couple of those, might go dig one up.
Post  Jason_WI Sun Mar 20, 2016 11:50 pm
I have made a few of my own of these. The difficult part is getting the correct depth so the crank shaft end play is correct otherwise it can be tight or too much. I have found with used cases it took measurements to get it set for each one. If using new crank cases then no problem to mass produce these.
The crank pin can still break off. There were a couple of broken car cranks in the NMMTPA lot I bought a while back. There were some DD heads in the lot also so I suspect it was run on diesel.
Jason
Jason_WI
Jason_WI
Post  EXModelEngines Mon Mar 21, 2016 4:21 pm
Jason_WI wrote:I have made a few of my own of these. The difficult part is getting the correct depth so the crank shaft end play is correct otherwise it can be tight or too much. I have found with used cases it took measurements to get it set for each one. If using new crank cases then no problem to mass produce these.
Jason
Agreed on the diesel comments. They are still waaaayyyy to hard in terms of heat treating (same as the standard cranks), but I would think that they are a bit tougher.
If anyone wants to run any tests on these cranks, in whatever capacity (diesel, non-diesel, etc.) drop me a message and I will send a couple of each, all free.
Matt
EXModelEngines
EXModelEngines
Official Cox Dealer
