by roddie Today at 9:22 pm
by rsv1cox Today at 3:38 pm
Modeling COX engines with 3D Printer
Page 1 of 3
Page 1 of 3 • 1, 2, 3
Hello
Somebody remember the topic about 3d printers?
I think I saw some messages about this ...
I´m printing COX tee dee parts and assembly the plastic engine.
Printing parts in many colours
Assembly with hard work and adjust lime
Regards
Jose
Regards
Jose
Re: Modeling COX engines with 3D Printer
Simply amazing!
Bill
Bill
smooth_bill- Gold Member
Thanks Bill
I scaled up x1,5 and the size is Tee dee .15, here with black carb body.
I only have to make the yellow parts: drive plate and needle valve body.
Looks good enough to run!
Bill
Bill
jmcalata wrote:Thanks Bill
Do you have the stl files for the engine? I'd like to try printing one.
Jason_WI- Top Poster
jmcalata wrote:Hello
Regards
Jose
That is an accomplishment. 3d printers are not as easy to set up as most people imagine.
While uniform objects are relatively easy, once you get the printing speed, flow of the molten plastic, layer height, nozzle temperature and bed temperature set properly! This takes time and varies by material.
However, objects that have protrusions - like the venturi - are very difficult to set up to avoid the plastic sagging before it has hardened.
I am impressed with this.
The software add suports to maake protrusions. After finish yuo can remove eady.
There are many parameters to adjust depent of material and geometry part.
jmcalata wrote:There are many parameters to adjust depent of material and geometry part.
But mostly trial and error! I use ABS plastic and this needs higher temperatures but I use it for structural parts (and it is fuel proof). I have the burns and blisters to prove it. (I can't resist touching things to see if they are hot!)
Video-run
Ja, ja, ja ... curiosity killed the cat ... Ian you do not touch hot parts with the finger.
Here the video-run of COX Tee dee .15 with PLA material.
I still do not have hot bed and can not use ABS, only PLA.
Hot bed is optional for my ·D printer Hephestos called I-Phrusa 3 of Bq
Also clear plastic show piston movements into cylinder.
It has created the cylinder with transparent PLA to see the movement of the piston within the cylinder . Jmcalata and soon finished the set where the case will also be translucent so you can see the crankshaft with the rod.
Thanks Jmcalata
WELLCOME TO THE FORUM kilimon !!!! Jose's must bee you friend , The engine is VERY NICE O crap I forgot to watch the engine run ,,,, Rewind /// okk not run but very COOL . Looks like fun! Eric
getback wrote:WELLCOME TO THE FORUM kilimon !!!! Jose's must bee you friend , The engine is VERY NICE O crap I forgot to watch the engine run ,,,, Rewind /// okk not run but very COOL . Looks like fun! Eric
Thanks getback
going forward...
3D Printed Tee DeeModelling COX engines with 3D Printer
Hi,
I think that Admin Jacob must be move these mesages to a now Topic called: Modelling COX engines with 3D Printer.
Ok???
Ok???
jmcalata wrote:Hi,
Ok???
Done!
I need to get a 3D printer one of these days. This is really cool!
Hi Jacob, thank you very much, very fast change , you are the best Admin of the world.
Tee de .15
Here the real Tee dee .15 and the plastic copy.
My first plastic model engine looks so good.
It does Look GOOD and you should bee proud very nice work (whats next ) getback
Next will be ... Tee dee .09 reduced 84 % and after Tee dee .049 scaled 70 %.
I´m sure that smaller will be more dificult.
Could be good idea, paint plastic parts with silver and gold colours.
Tomorrow, We will do a pretty stand.
I could make a logo like this.
There is a PLA with wood but is very expensive.
I use blue for the stand.
Cool deal are the cly screwed on ? if so I would be crazy enough to try and start on (with just a prime) (tight fit cyl. piston?) I could not stand it after the build , just me . getback
O Yeah the stand DO IT !!getback wrote:Cool deal are the cly screwed on ? if so I would be crazy enough to try and start on (with just a prime) (tight fit cyl. piston?) I could not stand it after the build , just me . getback
» Anyone have a 3D printer?
» Just ordered a 3D printer
» My Antique "3-D Printer"
» Printer woes, a plea for help
» Been away fro modeling for several months because.......
Page 1 of 3
