Using little red caps Cox_ba12
Using little red caps Pixel
Using little red caps Empty
Using little red caps Empty Using little red caps
Post  oldguy Tue Feb 23, 2016 10:23 pm
Can some explain how to use these for a tank setup.
Any photos of a setup would help.
http://littleredcap.com/
oldguy
oldguy
Using little red caps Empty Re: Using little red caps
Post  NEW222 Tue Feb 23, 2016 10:33 pm
If I am not mistaken, look up balloon tank. I believe they are used in the same manner, also fingers off nitrle gloves I hear work too.
Post  RknRusty Tue Feb 23, 2016 11:18 pm
I've seen TD Bandit use one on a TD, so you might send him a PM. I don't recall what he plugged it with. It's meant to be used as a pressure bladder rather than a balloon, but for a very small fuel supply it could work like a balloon.
He gave me one, but I capped a tube of caulk with it Lol. It worked great for that.
Post  JPvelo Wed Feb 24, 2016 6:10 am
http://www.flyfreeflight.com/Site/Commercial_Parts.html
I think the allure of these is they are lower pressure than a latex bladder so a fine thread needle isn't needed.
JPvelo
JPvelo
Post  fredvon4 Wed Feb 24, 2016 8:10 am
IN side the link JPvelo posted above read the General recommendations page on the red caps, set up and use
I use them quite a bit as lower pressure than tubing bladder
They are not as tough as tubing bladder so must be in a holder or compartment that has zero sharp points to burst them when full
Both tubing and red caps deteriorate when not being used.... I fix up a new red cap every fling session after removing the fitting from the used red cap
For tubing on small cox a fine NVA is required
For red caps a standard NVA will work but a fine thread one will give a better needling range
Post  oldguy Wed Feb 24, 2016 11:54 am
fredvon4 wrote:IN side the link JPvelo posted above read the General recommendations page on the red caps, set up and use
Thanks guy's
oldguy
oldguy
Post  badbill Wed Feb 24, 2016 2:07 pm
TDBandit and I have been using these on our td's for quite a while now with excellent luck. I wait till they break before replacing them, and find I can get a lot of flights out of one,don't want to be wasteful. 20, 25 flights is achievable. The bladder fittings come from www.texastimers.com . Stretch a piece of silicone fuel tubing with hemostats and put it over the big end of the fitting. Slide the end of the red cap over this and secure with a small zip tie. You will love them Laughing
badbill
badbill
Post  fredvon4 Wed Feb 24, 2016 2:21 pm
Bad Bill is correct and re-reading I implied that they deteriorate fast and truth is they do.... depends a lot on how often you get to fly
Bill can fly more often than I do...I assume from his posts here on CEF ....in my case several weeks between flying days and it sucks to get there and POP a bladder ( yes Virginia I carry spares of every thing)
I actually prefer the red caps cuz I got several packs (5) of 24 from Ace hardware (I bough all they had) and they are much easier for me to make up than a tubing bladder.... IN fact the way they are designed you can make a full length one or short it and still have a fair amount of fuel for testing with similar pressure to full length
Bladder tube must be "trained" I don't bother on the red caps
Post  badbill Wed Feb 24, 2016 2:22 pm
And here's how I "mount" them. I use a small pill bottle with both ends sawed off.
Using little red caps Fs31110
badbill
badbill
Post  oldguy Wed Feb 24, 2016 3:28 pm
badbill wrote:And here's how I "mount" them. I use a small pill bottle with both ends sawed off.
Bill, how do you connect the red cap to the fuel hose?
oldguy
oldguy
Post  badbill Wed Feb 24, 2016 9:04 pm
See my first post in this thread. I use the bladder fitting from Texas timers, fuel tubing stretched over the large end of that, red cap over that secured with a zip tie.the fuel tubing goes on the nipple of the bladder fitting. I'll get a pic tomorrow.
badbill
badbill
Post  NEW222 Wed Feb 24, 2016 10:29 pm
I like the idea, but I have a question regarding it. Actually two. First, how do you recess the bottle in the wing? Second question is does it not weaken the original design and structure of the wing? I don't think it would really matter or pertain to me as my models generally have a short lifespan, but maybe in the future! Shocked
Post  oldguy Wed Feb 24, 2016 11:08 pm
Thanks Bill
oldguy
oldguy
Post  coxaddict Thu Feb 25, 2016 1:59 am
I'm curious, what are red caps designed for originally ? Huh...
coxaddict
coxaddict
Post  batjac Thu Feb 25, 2016 3:42 am
coxaddict wrote:I'm curious, what are red caps designed for originally ? Huh...
Capping caulk tubes in caulking guns, etc.
THE Mark, etc., etc., etc...
Post  coxaddict Sun Feb 28, 2016 11:49 pm
hi, thanks for the information I Love This Forum! Very Happy Very Happy Very Happy
coxaddict
coxaddict
