Building tip:  Xacto knife blade matrix Cox_ba12
Building tip:  Xacto knife blade matrix Pixel
by TD ABUSER Today at 9:43 pm
by roddie Today at 6:17 pm
by TD ABUSER Today at 2:13 pm
by Ken Cook Today at 1:41 pm
by Ken Cook Today at 1:37 pm
by getback Today at 11:52 am
by roddie Today at 10:43 am
Building tip:  Xacto knife blade matrix Empty
Building tip:  Xacto knife blade matrix Empty Building tip: Xacto knife blade matrix
Post  SuperDave Thu Nov 24, 2011 10:12 am
Most everyone uses hobby knives, Xacto's being most common. Xacto provides a matrix showing the many types of blades and describes their modeling applications.
I find the matrix a very useful refernce to have posted in my den. The matrix is free and available @ www.xacto.com
REMEMBER, Xacto's are VERY sharp!
SuperDave
SuperDave
Building tip:  Xacto knife blade matrix Empty xacto
Post  dankar04 Thu Nov 24, 2011 10:23 am
I have cut many pieces of balsa with these blades, and yes they cut fingers just fine !! lol!
Dan Airplane
dankar04
dankar04
Building tip:  Xacto knife blade matrix Empty Re: Building tip: Xacto knife blade matrix
Post  PV Pilot Thu Nov 24, 2011 10:37 am
In the toolbox is a #1 #2 and #5 and they get used all the time. Don't know how many blades I have used over the years.
Just picked up the extra fine tooth crosscut saw with Mitre box. Really slick, no tearing of soft balsa wood and makes a machine grade thru cut.
PV Pilot
PV Pilot
High Tech Balsa Basher
Post  microflitedude Thu Nov 24, 2011 10:42 am
I have found Excel blades to be much sharper. Maybe it's just me.
And yes, I have a LOT more respect for them now then when I first started using them.
microflitedude
microflitedude
Post  Kim Thu Nov 24, 2011 10:49 am
Just a note that everybody probably already knows---but just in case not: If you do your cutting on a pane of glass (old desk-top glass is best), you will extend your Xacto blades' service lives several fold over using them on a regular cutting board.
Post  jetpack Thu Nov 24, 2011 11:43 am
Along with the #11 blades I always make sure I have a few of those single-edge safety razors around. They work great for chopping (usually makes a straighter line than trying multiple draws with a #11) and I also like them better for trimming tissue against a balsa edge.
jetpack
jetpack
Post  hlsat Fri Nov 25, 2011 4:52 am
Kim wrote:Just a note that everybody probably already knows---but just in case not: If you do your cutting on a pane of glass (old desk-top glass is best), you will extend your Xacto blades' service lives several fold over using them on a regular cutting board.
Congrats great idea.
I know and use the glass over globalization cutter.
hlsat
hlsat
Silver Member
Silver Member
Post  PV Pilot Fri Nov 25, 2011 5:41 am
I have one of the big size Hobbico self healing cutting mats for any serious slicing and it makes for a nice level tractioned surface. The printed rulers on the surface are handy as well.
The single edged razor blades are also good for carefully getting behind a unobtainable gasket for removal, and for general gasket scraping/removing. Lowes had a plastic box of 100 blades for about $6.
Another name For good cutters is Fiskars, I have several pairs of there fabric scissors big and small as well as one of there 45mm cutter wheels for trimming tight turns in covering material. Those wheels are super duty sharp BTW, the handle that they mount to has a plastic piece that thumbs up to protect the edge(and fingers) when not in use. I even have a pair of Fiskars hedge trimming shears/limb loppers which again, are incredibly sharp and hold that edge for years.
PV Pilot
PV Pilot
Post  Kim Fri Nov 25, 2011 11:33 am
Another "Ye Olden Days Tip"...the old-style double-edge blades can be cut with scissors to give you two, VERY thin and flexible cutting blades for fine work. Wrap the back side with masking tape to protect your fingers, and you're set to go.
Building tip:  Xacto knife blade matrix Empty Xacto
Post  dankar04 Sat Nov 26, 2011 10:28 am
Good post on blades. Glass works well with nice clean graffics.
Dan
dankar04
dankar04
Post  nemoskull Wed Nov 30, 2011 9:20 pm
anyone use self-healing quilting mats?
i use HK blades, cant tell the difference from exacto. its all ways funny and scarry at the same time when a hobby knife falls of the table and lands straight up sticking into the floor.
have not impaled my feet......yet.
nemoskull
nemoskull
Silver Member
Silver Member
Post  SuperDave Sat Dec 03, 2011 9:23 am
nemo:
What about the cat under the table? Laughing
SuperDave
SuperDave
Post  microflitedude Sat Dec 03, 2011 9:43 am
nemoskull wrote:anyone use self-healing quilting mats?
I know, crazy.
My uncle dropped his once and tried to catch it. He nearly lost the tip of his finger. Shocked
microflitedude
microflitedude
Post  Ivanhoe Sat Dec 03, 2011 9:55 am
Anyone in the UK is better off using the Swann Morton craft tool, Swann Morton make surgical scalpels, which are also available for crafting use, though I've always found scalpel blades too brittle and liable to snap (dangerous!) The biggest advantage of the craft tool is that the handle is flat, no rolling off the bench and impaling feet (or the cat!) I have always used this tool, in the good old days the handle was brass, now they are plastic and too much pressure can break them where the blade clamping screw goes through. I could never get on with Xacto blades, I always found them too thick and not as razor-sharp as SM, but each to his own!
Wilf
Ivanhoe
Ivanhoe
