by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
by rsv1cox Today at 3:38 pm
How many turns?
How many turns?
On the fine threaded needle in a postage stamp backplate, how many turns open should the needle be turned to start?
The Fine Mark
The Fine Mark
batjac- Diamond Member
Re: How many turns?
Under bladder pressure it's 2 or 3, but on suction it might be 6 or 10.
If you know the standard needles's thread count you can possibly guesstimate it. Like if standard is 48 tpi, then say the average three turns times 128/48, or multiply by 3*2.7. But the shape pf the needle varies too, so you're still hunting. The 128 tpi needles are not pointy, they're usually blunt.
Re: How many turns?
Mark,
Have a look at the instructions of the Cox Stuka. This plane has a 290. The instructions say to open the needle 3 1/2 turns for starting:
https://www.coxengineforum.com/t5163-cox-ju87d-stuka?highlight=cox+stuka
Have fun!!
Lieven
Have fun!!
Lieven
OVERLORD- Diamond Member
Re: How many turns?
Yet another example of why I shouldn't post information at 4:30 am.
Re: How many turns?
RknRusty wrote:Yet another example of why I shouldn't post information at 4:30 am.
That's OK Rusty... 3-1/2 turns doesn't seem like enough for a 128 TPI needle.. (how could it be?) Maybe because of how you mentioned that the needle has a blunt point..as compared to the "Bee-style" sharp-pointed needles?
I misplaced one of my two fine-thread needles..
Here's a pic of the two I had... Notice the difference in the needle-tip profiles.. Would the seats in the spray-bars be different too?
and here's a pic showing the difference between an 80 TPI needle on the left (from a horseshoe) and a 128 TPI needle on the right (from a 290/postage-stamp) This is the needle that I misplaced.
Re: How many turns?
I don't know the answer to that but..if it don't fit I was not made for it !! I would say they are different? just a guess though. Mark my racer engine was set on 3.5 that was 20K I would start with 4-4.5 that should get you running Getback
Re: How many turns?
getback wrote:I don't know the answer to that but..if it don't fit I was not made for it !! I would say they are different? just a guess though. Mark my racer engine was set on 3.5 that was 20K I would start with 4-4.5 that should get you running Getback
I can't remember Eric.. were you running a bladder.. or suction? (at 3-1/2 turns out, I'm guessing it was suction) Was your NVA swapped from a 290 backplate.. or was it a Texas-Timers unit?
Mark, are you trying to run a 290 "engine".. or did you swap it's NVA out to a "Horseshoe"? Just curious... I can hook you up with mounts for the 290. They're thin enough (.040" alum.) to fit under the OEM case-screws with plenty of extra thread-length to tighten safely.
Re: How many turns?
It's a 290 backplate. I was going to wait until you got things shook out on your 290 mounts, and then get a set from you to build a "290 Special" with.
The "Special" Mark
Re: How many turns?
I am sorry my backplate ended up being a .....128 thread/ black plate I got from another engine / super bee crank / case / super dupper p/c / suction system Getback
Re: How many turns?
The "Special" Mark
Yea.. that's a cool looking little airplane. I'll make you the specified "L"-mounts for it then; that screw to the top/bottom of the hardwood nose-block. I can bend the plates to 90 degrees on the backplate side.. but you'll have to "open them up" to match your bevel-angle on the nose-block... which looks to be around 110 degrees or so, on the plans.
A couple of "290 Special" building considerations to think about.. I mentioned in the "postage stamp mounting" thread; that the wheels used on that model back then (Veco) would have been quite heavy.. If you use lighter-weight wheels combined with my engine-mounts (which are aluminum and NOT steel), you may want to go with an "all sheet-balsa" tail-plane.. rather than the specified ply/basswood pieces.. so it won't end up tail-heavy.
BTW... If you can measure the Pee Wee's case mount pattern.. I could make similar "L"-mounts for those "Sky-Copter" backplates you have. If you trimmed one "square".. as per the "290 Special's" design, you'd have a super-lightweight .020 with a much reduced frontal-area for less wind resistance. Were there any other plastic (product) backplates made for the Cox .020 reedie.. other than the "Sky-Copter's"??? Let me know if that's something that would interest you.
» What's up with Dan Sitter?
» My Swap-Meet Ringmaster ! Smack Down!!!! The Resurrection Begins!!
» As the Table Saw Turns
» Cox TD .020 r/c Achieving your minimum turns!
» Things that make you go, "Oh Crap!" As the Musketeer Turns....
