What is a "electrical squid"?
In finishing my EP Dumas Chris-Craft speedboat I've encountered problems matching electerical connectors.
A "squid" has been suggested as a solution.
Anyone have any experience using a "squid" outside using them to make calamai?
If so, enlighten me please.
SD
SD
SuperDave- Rest In Peace
Re: What is a "electrical squid"?
https://www.youtube.com/watch?v=AIOqOxI0K_I
An "electrical squid" is generally an adapter that connects from one device to a choice of other devices. What connections are you trying to match?
It may be better to re-end some wires instead of making an adapter, but making a custom pigtail is also easy.
Hi SD,
Look at this site. It's some sort of multi electrical connector
http://www.readymaderc.com/store/index.php?main_page=product_info&products_id=1966
Lieven
Lieven
OVERLORD- Diamond Member
I've seen charger squids with as many as 7 or 8 connectors attached.
But, Phil's suggestion of re-terminating your wiring is really the best. Just find some connectors that match, have sufficient current carrying capacity, and replace both ends with the new connectors.
http://www.headsuphobby.com/Battery-Connectors_c242.htm
Excuse me for asking SD.. but I thought you were running all Dumas electronics in the model? What exactly is/are the connector(s) in question? Have you chosen to run an aftermarket Speed-controller with Battery Eliminator Circuitry (BEC) per chance? Just trying to narrow down the solution.
Thank you to Phil and Andrew.
Upon closer examination the connectors DID matchup so all is well.
SD
SD
Don't let their answers fool you, you literally use squid arms (they're conductive)
daddyo- Gold Member
Yeah, an electric squid. But be careful, they pack quite a punch. You won't need batteries as long as you keep it alive.daddyo wrote:Don't let their answers fool you, you literally use squid arms (they're conductive)
[quote="roddie"]Excuse me for asking SD.. but I thought you were running all Dumas electronics in the model? What exactly is/are the connector(s) in question? Have you chosen to run an aftermarket Speed-controller with Battery Eliminator Circuitry (BEC) per chance? Just trying to narrow down the solution.[/quot
Roddie:
Good question.
Originally I purchased a Dumas ESC on Tower Hoddies recommendation THEN I discovered it was an "old tech" version FAR inferior to the "IntelleiSpeed" unit (#DTXM1059) that I discovered later from DURATRAX. It's actually intended fo CARS but is well suied for boats too. (It does NOT have a BEC).
I discovered the Duratrax unit on a model boat forum to which I am most indebtited. In short, the connector problem I first experienced is now but a bad memory.
So now I'm set to complete the Chris-Craft AFTER the weather warms enough for the Lustre-kote finish to dry properly. (Originally I used two-part finishing resin from Pacer which had MANY problems.) Bad mojo that Pacer!
SD
Roddie:
Good question.
SD
