Built to crash Cox_ba12
Built to crash Pixel
Built to crash Empty
Built to crash
LOL Built to crash
Post  batjac Thu Feb 20, 2014 2:52 am
I’ve noticed that I’m reluctant to exit straight and level and do more radical stuff with my planes because I’ve spent so much time making them pretty, I don’t want mess them up.  I’ll never grow this way, so I’ve decided that I need something different.  I need something with little to no emotional attachment, knowing I’m going to crash it, and be fine with that.
So, Batjac Aeroworks© will be coming out with the new Built to Crash Series™ of airplanes.  And when I say built to crash, I don’t mean built to withstand crashing and keep flying.  Or planes that’ll pop apart and then go back together like a Cox PT-19 or something.  I just mean, “Hey! I’m not going to make an emotional investment in these planes ‘cause I know I’m gonna crash them.”  The planes will have minimum time and money invested in them.  Other than the engine, they’ll have little personal value, so I can crank them around as much as I want, break them, and just glue them back together until there’s no original wood left to glue back together.  No neat and fancy finish.  Whatever paint I have the most of is what they get painted.  And cold and humidity be damned.  Who cares what the paint looks like.  The only effort will be in making it fly decently, nothing more.   Then, when I can do the maneuvers I want to be able to do, THEN I’ll risk my pretty planes.
So, to inaugurate the Built to Crash Series™,  I’m introducing my BTC-1 trainer.  It’s a simple plane with no flaps, a monowheel, and a keel and crutch fuse.   The engine will simply bolt to the crutch for an upright engine mount, and crutch will glue to a spruce keel that runs the length of the fuse.  It should build in a couple of evenings.  The fuse is ¼ balsa, the tail surfaces are 3/32 balsa.  The wing is also ¼” balsa with a 20” span, and chord of 4 ½” at the root and 3 ½” at the tips.  I’ll spend an extra half hour or so sanding a sorta-airfoil into the wing.  The plane won’t be pretty, but it’ll be mine.  I’m going to try it with a Medallion .049 and see how she does.
Here’s the kit as it’s been drawn so far, and a couple of parts cut out.
Built to crash BTC1kit_zps69ede663
As you can see, I changed my mind about the fin shape, and the nose length while I was drawing it out.  I’m still not sure it won’t be tail heavy, but we’ll see.
The Emotionally Distant Mark
LOL Re: Built to crash
Post  JPvelo Thu Feb 20, 2014 7:42 am
Great idea Mark! You need something you can bash around until you get the hang of that inverted thing. My personal trainer was a Little Satan. That plane took a lickin' and kept on tickin'.
JPvelo
JPvelo
Post  pkrankow Thu Feb 20, 2014 8:51 am
Stop the knife!
Have you looked at the simple set of plans called "white lightening"?  I think this plan is in the ballpark of what you are looking for.
http://hippocketaeronautics.com/cl_sp_white_lightning.htm
Now, if you are starting with this basic geometry and making it easier to build then go for it!  I am just suggesting you not reinvent the wheel.
ps making the "canopy" glue-on after the fact might make cutting it all out easier.
Post  duke.johnson Thu Feb 20, 2014 10:01 am
Or make something out of coroplast. I made a coroplast combat wing for a TD that flies pretty well. And it never breaks anything but a prop.
duke.johnson
duke.johnson
LOL Built to crash
Post  RK Flyer Thu Feb 20, 2014 10:25 am
Mark,
Your plan sounds like the "Firebaby" as drawn by Frank Macy & Jim Cameron with the hardwood stringer dowm the fuse. The  other "Mark" flies his at Delta Park and he is able to do everything with it!
I am just finishing a 1/2A Nobler to add to the Sig. Dewybird & Firebaby that I've been flying. The Nobler will be powered by a 049 Tee Dee with a tank & later a bladder.
I am still working on the Mid Engine AiraCobra for the race but not sure yet if it will work out.
See you soon at Delta Park, RK Flyer   Flying
RK Flyer
RK Flyer
Post  Cribbs74 Thu Feb 20, 2014 11:38 am
Mark,
Whatever you choose to build just make sure it is more capable than you are. What I mean is you don't want to be fighting the plane while trying to develop your skills.
I flew 1/2A first and tore up my planes a lot. Then I flew a full size Ringmaster and suddenly I was able to fly without crashing. The larger plane and longer lines allowed me a lot more time to react.
Now I can fly 1/2A a lot better as well because the full size helped me to develop the muscle memory.
Post  roddie Thu Feb 20, 2014 12:02 pm
I like your idea a lot Mark (I feel as though you read my mind  Shocked ) I like making my own designs as well, rather than buying a kit... and I've never built a model from a plan (yet...) The only problem (like Phil said) is in reinventing the wheel. A SIMPLE strong/proven design should fly correctly, without too much trimming. A Stuntman 23 or Sig Skyray design come to mind for a "Reedie" at least. I have no experience with "Coroplast"... but I'd like to at least "try" building with it once. Balsa is expensive to experiment with.
I'm sure you'll get some advice to build "bigger" Stunters... as they're much easier to fly and learn maneuvers with. A Ringmaster with a Fox .35 gets high praise here... but there's a lot of time involved with building a straight "built-up" wing... and covering it.
All said... I'm with you, and have the same desire to build a "fleet" of 3 or 4 simple/quick 1/2A airframes to knock around. If you can learn the Stunt pattern using decent performing, small "expendable" airplanes... then you'll definitely feel more confident later on with the bigger models.
One suggestion though...  Two Cents  shoot for closer to 100 sq. for the wing.. and roughly 25% of that for the stab./elev. area for a 1/2A stunt ship. The Sig Skyray's wing/stab.-elev. has approx. 115"/27" sq. in. proportions... with a 23"/9" spans respectively... and close to constant-chord on both surfaces.
Post  batjac Thu Feb 20, 2014 1:09 pm
pkrankow wrote:Stop the knife!
Phil, I already built a White Lightning. But, I spent so much time prettifying it that I don't want to mess it up too much. Besides, this is the plane that I moved my electronics to to try my hand a eC/L flying.
https://www.coxengineforum.com/t5631-a-traveling-engine-plane?highlight=my+travelling+engine+plane
Now, the idea of the canopy glued on afterwards didn't occur to me. That should only add a few minutes.
The  Huh... Mark
Post  batjac Thu Feb 20, 2014 1:23 pm
roddie wrote:One suggestion though...  Two Cents  shoot for closer to 100 sq. for the wing.. and roughly 25% of that for the stab./elev. area for a 1/2A stunt ship. The Sig Skyray's wing/stab.-elev. has approx. 115"/27" sq. in. proportions... with a 23"/9" spans respectively... and close to constant-chord on both surfaces.
Roddie, the wind size was more dictated by the size of the piece of 1/4" balsa sheet that I had on hand, trying to get both the wing and fuse out of it.  Using Phil's idea of a add-on canopy rather than cutting it into the fuse might enable me to get a bigger wing out of the piece of balsa I have.  Looking at it, I should be able to get 100 sq.in. out of it. But another reason I like the dimensions that I have now is that I can sand leading and trailing edges into the 1/4 balsa and have a sorta-symmetrical wing. It probably wouldn't have any real advantage over a typical slab wing with rounded L.E./T.E. surfaces, but it'd have SOME shape to it.  If I add another 25% to the wing area, the relative thickness of the wing drops that much more.  I'll think about it over lunch.
I have a Skyray kit in the closet. I just like to design for myself. If it breaks, oh well...
The Thick Mark
Post  roddie Thu Feb 20, 2014 2:47 pm
The Thick Mark
 lol!  I get it! My slab-wing designs don't have any airfoil at all... They are all 1/8" sheet balsa.. as well as the tail-feathers. I use 1/4" balsa for the fuse usually. This is the only "conventional" construction method I follow... along with attempting to get the proportions in the ballpark I mentioned previously.
I have had good success when building a 1/8" sheet slab-wings... with using multiple "full-span" pcs. of stock "edge-glued" together. I cut the pieces to the maximum span length, place a long enough sheet of wax paper on a large-flat surface.. and apply a thin bead of thick CA glue to one edge of the wood and slide them together over the wax paper, keeping both pieces flat.. all the way across their length.. and hold them tightly together for about 10-15 seconds. The wax paper pulls right off the glue-joint afterward.
This method has it's advantages... #1. it's quick.. #2. it allows you to use pieces of stock that would otherwise be too narrow to make-up the chord of a one-piece sheet-wing.. #3. I personally believe that it makes a sheet-wing more resistant to warping vs. a one-piece sheet.
Using this method, you can also install a harder-wood spar.. not that you'd need one with a 1/4" sheet-wing... but I have used 1/8" x 1/4" full-span Spruce leading-edge strips.. or a 1/8" x 1/2" full-span Spruce wing-spar that also doubles as a solid bell-crank mount.
My speed model's sheet-wing is comprised of 6 pieces edge-glued together, to make it's 6" root-chord... including a hardwood flat-spar that doubles as a L/G mount.
Built to crash 11-11-13
I did have to increase the span... after re-reading the rules...  DAMMIT!
Built to crash 11-14-10
Built to crash 11-15-12
My fuse uses the same edge-gluing technique.. with Spruce rails top/bottom.. and the canopy and belly contours added later.
Built to crash 11-16-10
Built to crash 11-17-10
Not that my Speed contest model was a quick-build... (and yes... I am nervous to fly it...) but it's an example of how you can conserve stock by edge-gluing.
Post  JPvelo Thu Feb 20, 2014 5:52 pm
Mark,
If you have a Skyray kit I would definitely use  that as a template. Mine flys much better than a sheet wing 1/2a ought to.
JPvelo
JPvelo
Post  Cribbs74 Thu Feb 20, 2014 6:18 pm
Mark, don't you have a beginners Ringmaster? The one I have flies exceptionally well for a slab wing. I have no doubt that with a TD or Medallion, it would fly a passable beginners pattern.
It's very rugged, just a thought.
Of course what you are building looks good too.
Post  getback Thu Feb 20, 2014 8:58 pm
Mark I think that's a great idea as to fly with out attachments too just have FUN and not so much worrying about the outcome , just the learning = experience . was that german duggedtvuding ? when I looked it up [ duggen   digging  } the slow Eric   Built to crash Baby_r19 just something I threw together not knowing what it would do with a enya 09 on it >>>>>>>>> Flying  shot she lived through the first 2 flights then I was happy I guess !!
Post  batjac Wed Feb 26, 2014 10:53 pm
Finally got some time to get back to the plane.  As suggested earlier, I went ahead and made the canopy separate, which allowed me to increase the wing area.  It’s now 99 sq.in. with an aspect ratio of 4.9:1.  The tail area is 27sq.in.  Fuse length is 20 inches.
As you can see, I re-drew the wing over the old outline and cut it out.  Then I drew some lines that would help me in sanding the leading and trailing edge shapes I want.  Maybe it’ll help over just rounding the edges of a sheet wing, maybe not.  At the very least, it takes a lot of weight off the wing.  That’s no small issue, as this is going to be a relatively heavy plane.
Built to crash DSCN1191_zps47e29b59
Built to crash DSCN1185_zps6f2eefcd
Built to crash DSCN1186_zpsf06441b0
Then I sanded the wing to the shape I wanted, sort of.
Built to crash DSCN1201_zps29ac7e4d
[URL=https://s32.photobucket.com/user/batjac/media/DSCN1203_zps20ef90e1.jpg.html]Built to crash DSCN1203_zps20ef90e1[/URL
Post  batjac Wed Feb 26, 2014 10:56 pm
Since I was going to use my patented Ease-O-Flex™ Monokote hinges, and since I anticipate building many more planes after this, I decided to cut a few long strips of Monokote and make a couple lengths of hinge sheet.  Now I can keep them in my building supplies, and just cut off hinges as needed.
Built to crash DSCN1193_zps020de261
Built to crash DSCN1195_zps10f86158
Built to crash DSCN1198_zps05f3d1a6
Built to crash DSCN1208_zpsf62b9bc7
Before I made any major cut in the fuse, I wanted to get a rough balance, so I taped everything I had so far in place, and then put it on top of a small cylinder to find the balance point.  So far, it balances at about 15% of the chord.
Built to crash DSCN1209_zps9a835b2d
And, of course, I just had to tape it all together to see how it’s starting to look.  It’s not too close coupled, so it should make nice, smooth maneuvers.
Built to crash DSCN1215_zps9122dc67
The Balanced Mark
Post  roddie Wed Feb 26, 2014 11:11 pm
Looking GREAT Mark!!! Making extra Mono-Kote hinges is a good idea. I like to have stuff ready to build too. I try to be as organized as I can. There's nothing worse than searching for something when you're motivated to build.
Are you drawing a plan-set for the model? It's pretty sharp looking!  Thumbs Up
Post  batjac Thu Feb 27, 2014 5:20 am
I don’t know how Y’all like to do your bellcrank linkages, but what I find I like is to hinge the elevator, determine about where I want the bellcrank to be, then cut and bend my wire to that length first.  Then I put the control horn on the elevator, hook up the pushrod, and then with the elevator neutral and the bellcrank neutral, I mark the center of the bellcrank hole for the spot to drill.  It’s easier for me to match the bellcrank to the pushrod, than to measure and bend the pushrod to the exact length to match the bellcrank and control horn.
Built to crash DSCN1216_zps8bdbd5a0
Built to crash DSCN1218_zpsc4bd93c7
Built to crash DSCN1224_zpsd44ad602
So, it’s almost done.  I just have to make up the line guide, glue the keel in place, drill the motor mount screw holes, and strategically add some ¼” triangle wood braces.  I changed my mind on the monowheel and went for two wheels.  I wanted a little more weight forward.  I’m still debating whether I want to add more fin area with a rudder, or just leave it as-is.  What do Y’all think?
Built to crash DSCN1226_zpsb6f267d7
Built to crash DSCN1228_zpse2558e02
The Mostly There Mark
Post  batjac Thu Feb 27, 2014 5:38 am
roddie wrote:Looking GREAT Mark!!! Making extra Mono-Kote hinges is a good idea. I like to have stuff ready to build too. I try to be as organized as I can. There's nothing worse than searching for something when you're motivated to build.
Thanks, Roddie.  It didn't come out too bad for an off-the-cuff design.  Most of it was driven by necessity.  The wing and fuse had to fit the one leftover piece of 1/4" sheet I had.  The tail surface also were from leftovers in the scrap box.  That's why the stab taper doesn't exactly match and the fin looks a little funky.  The landing gear length was determined by how much wire was left after I cut the pushrod from it.
The only plans I'm drawing are the pen and pencil lines I draw on the wood.  It's mostly TLAR, but I kinda like the long lines of it.
The Cuffed Mark
Post  JPvelo Thu Feb 27, 2014 7:16 am
 Tired w/ Coffee Read Mark,
Looks great! This is what I use for pushrod adjustment, best thing ever:
Built to crash DdWXk3o
JPvelo
JPvelo
Post  pkrankow Thu Feb 27, 2014 8:23 am
If you are at 15% MAC now, after paint it will be tail heavy... Should be minor though, especially if the engine mount holes are not drilled.
Looking good. I like the crutch and upright engine design.
Post  batjac Thu Feb 27, 2014 2:52 pm
pkrankow wrote:If you are at 15% MAC now, after paint it will be tail heavy...  Should be minor though, especially if the engine mount holes are not drilled.
That's why I changed my mind about a monowheel just forward of the wing L.E. and went to two wheels just behind the prop arc.  To get as much necessary weight forward as I can now, to account for the paint. Besides, I still have to put in the triangle stock to brace the crutch to the fuse. That'll add a few grams forward also.
I like the crutch idea also, as it gives a nice shelf if I want to try a square uniflow tank or something later.
Jim, I have a few E-Z connectors in my hardware box, but for some reason I just like Z bends on control line planes.  Just a personal quirk I guess.  But I do use E-Z connectors on all my servos in 1/2A R/C planes.
The Quirky Mark
Post  roddie Thu Feb 27, 2014 5:39 pm
The Cuffed Mark
Hey Mark, great looking plane there!! You did an awesome job with limited materials you had. The fin on a self-designed model, has always been the hardest thing for me to design.. where I felt it looked good. I almost always end up modifying or changing it. IMO.. it's the deal-breaker in the "looks department" on a model. It's shape can flow beautifully upward as an extension of the fuse's profile... or it can look like it just doesn't belong there. I think that yours fits the shape of the other flying surfaces pretty well.
I also like z-bent pushrods. If it's a 1/16" music wire pushrod, I have also used an "L" bend, and the little spring wheel retainers that Sig and Goldberg used to sell.. with a 1/16" i.d. washer in between. This works nice on a bell-crank as well, with the rod end facing up for access/removal.
Here's an example on an elevator horn. (that little brass washer is from a pkg. that I bought a long time ago.. I liked them because they were thick, had a .063" i.d. and a .125" o.d.)
Built to crash Pushro10[/quote]
Post  RknRusty Thu Feb 27, 2014 7:39 pm
roddie wrote:......I find I like is to hinge the elevator, determine about where I want the bellcrank to be, then cut and bend my wire to that length first.  Then I put the control horn on the elevator, hook up the pushrod, and then with the elevator neutral and the bellcrank neutral, I mark the center of the bellcrank hole for the spot to drill.  It’s easier for me to match the bellcrank to the pushrod, than to measure and bend the pushrod to the exact length to match the bellcrank and control horn.
I like that idea since the location of the bellcrank isn't super critical. It's now added to my list of building tips.
Post  getback Thu Feb 27, 2014 8:34 pm
yo Mark that s looking pretty darn good for no more time than it has taking you , I think it will fly well, it has a good daddy  lol! Jim that's rc and cheating  Laughing  ; but NICE and easy!
Post  roddie Thu Feb 27, 2014 9:49 pm
 Huh... Laughing I didn't write that... Mark did! Have you been running engines inside again Rusty?  lol!
