Base coat options
Base coat options
I have stated before than Minwax Polycryllic is a suitable base coat. It can be "stripped" with denatured alcohol on a scrub pad: meaning there is no sanding dust (anyways Polycryllic does not sand very easily). The product is slightly fuel tolerant by itself, and is not instantly dissolved by glow fuel. With a fuel proof coating over it I have had decent performance, although I feel the product is heavy, especially compared to dope.
Roddie prodded me about using Killz primer, I thought I had some but I don't. Instead I have Zinser Bullseye water-based primer. I applied it to some wooden skewers for testing, about an hour later (topcoat cure time) I took one skewer and placed it into a plastic bag with a paper towel and a splash of Sig Champion 25% fuel. After 1 hour the results are promising as the coating was not immediately stripped. The coating was significantly softened, and tore in places with rubbing.
Zinser Bullseye is supposed to be easy sanding (I have a sample made up for that too) and seems more lightweight than Minwax Polycryllic. While sanding means dust (and working where I can make dust, which is outside) a better looking finish that is lightweight is better.
So far my favorite method of sealing, priming, and grain filling is using thinned dope with cornstarch as the results are excellent and fuel proof. However I cannot use this method in the house as it has a very strong solvent odor.
Re: Base coat options
Thanks for posting your thoughts on base coats, as I'm trying to muddle through the possibilities. Hopefully after my next couple of projects I'll have some useful experience. Other than spray primer and hit and miss sanding, I've never paid much attention to it. I hope to up the quality on my current and future projects. I have to order some Sig fuel and I've been trying to get my list over $25 to reduce shipping, so some butyrate dope and thinner will be on the ticket. If I don't have it in time for the Yak, I will for the Skyray and the P-51. I've already saved over an ounce off of the Yak, so there's some room for the weight of the Poly.
» Lockheed "Tee-33-Dee" for CEF Speed Contest
» T-Bee-D1 (a Rod-de-sign)
» Sanding the primer coat
» Scratch build BRM - a first
» My Fancherized Twister build; 3 days til Huntersville
