magnets for modelling
Magnets... are great tools. Share some uses you have for them.
"Rare-Earth" magnets (Neodymium and Samarium Cobalt) are very powerful and more expensive. They are becoming more easy to find now. Retailers that have an "assortment" of ceramic (reg.) magnets may have them. They are generally small in size... "round" and most commonly 3/16"-5/16" in diameter. Thickness is usually less than the diameter...
Attach one to the end of a long thin stick/dowel, and you have a handy tool to retrieve metal parts that have; fallen on the floor, under the table, under the washing machine, down the drain.
A short (6"L.) version of the above can be kept in your flight-box and/or on your work bench in a "handy tools" mug. (a great use for an old "retired" coffee mug... I keep an assortment of items in mine)
Clips/washers/screws etc. can be tough to "fish-out" of bins in organizer trays. The magnet tool works better than tweezers, because... even if it picks up "more" than intended... your not going to drop/lose any of it.
Keep a large ceramic disc-magnet handy. If you drop a tiny metal part on the floor/carpet... and can't see it, just scan the area with the magnet. You'll find the part...
Magnets can be used in construction for holding parts in alignment, and if powerful enough; can even be used as clamps; when gluing small/thin pieces together.
A magnetic dry-erase white board is an excellent thing to have in the shop, for notes/reminders.
Re: magnets for modelling
I use a Crasftsman (Sears) magnet with an extendable shaft handy for retrieving all sorts of ferris metal objects from all sorts of places like furnace ducts.
I have two: one for my flight bag and the other with my automotive tools.
SD
SD
SuperDave- Rest In Peace
True !
You can even use them as quick-attach for wings on some models! Henry Pasquet, a regular at the Little Rock S.M.A.L.L. Fly-Ins, designed his tiny "Bat" Co2 biplane to use a set as keepers for the lower wing!
Carefully assembled, they confidently SNAP! together, with no chance of separating in-flight. The one in the photo has it's lower wing glued, but original packed an Albin Receiver with a coil-actuator on the rudder.
There was one year at the S.M.A.L.L. Fly-In when these things seemed thick as flies !
I want to build one of those!!!!!!!!! (note to self: build a "Bat"!!!) Thanks Kim!Kim wrote:True !
One of the most amazing things for me was the GLIDE of this little turkey! I finished my first one on a rainy Sunday and of course HAD to at least hand-glide the Bat. I bunched up a comforter in the hallway and launched the plane toward it. It flew OVER the comforter and slide to a stop on down the hall.
A larger, painted version would be about as perfect a plane as you could ask for hanging an .010 out front. A sheet of 1/16th builds it, with some ply scaps...and you're ready!
I collect old dead hard drives and disassemble them for the magnets. Some of the older ones are quite big and extremely powerful. Standard old 3.5" HDD magnets will stay top and bottom of my hand. Great clamps for holding stuff whilst glue sets.
Rare earth magnets
When I moved into my house, oh 13 years ago, the previous owner had left 4 very small RE magnets stuck to the wall inside my closet. I found a great use for them.
They now hold the hatch down on my ACE Whizard (aka 'The Green Hornet'). I glued two to the bottom of the hatch, and two to the underside of the front cowl. The other end of the hatch is held in place with gussetts and a tab. Then just a piece of green wrapping ribbon sticks out of the seam to grab and lift off!
The magnets were very small (maybe 1/4" diameter and 1/16" thick), but they hold on real tight!
VUgearhead- Gold Member
