» Happy 77th birthday Andrew!by roddie Today at 9:22 pm
by roddie Today at 8:58 pm
by rsv1cox Today at 3:38 pm
Questions for the better informed.
Is the splined portion of the Killer Bee crank (offered by both Bernie and Matt) the same length as the standard crank and will this crank fit any of the Surestart cases?
I've seen two different thrust plates advertised for the KB crank. One is the standard thin no-drag plate used on the majority of COX engines and the other, listed as a KB thrust plate, is thicker, much like the Tee Dee thrust plates. Is there an advantage of one over the other?
Lastly, I'm a believer in minimizing rotating mass when trying to maximize RPM. What's the group's opinion in using spinners --- my experience has been that while they may smooth out the engine a bit, they tend to knock some off the top end. Does the gain in streamlining offset the RPM drop. Any comments would be appreciated.
Re: Questions for the better informed.
I would tend to think that parasitic/rotating mass drag would be almost insignificant in the grand scheme of things. I look at them more as a means of more uniform clamping pressure on the prop and usage of a electric starter, as I use those.
As far as streamlining,, definitely.
PVP --
I don't think that parasitic drag is as much of a player as the actual mass of the spinner, i.e., much like using an aluminum ultralight flywheel rather than steel. I realize that light flywheels are used to improve acceleration in vehicles, but near the upper RPM range, these smaller engines just lack the torque to drive the spinner and prop together.
Our (and Matt's) KB cranks are identical in dimensions to the Surestart crank and will fit any post 1956 Cox .049 reed valve engine.
However, for reason's unbeknownst, our manufacturer made the actual shaft a tiny bit longer and we now include 2 spacers that buyers can (optionally) use if that bothers them.
Bernie
Bernie
Cox International wrote:Our (and Matt's) KB cranks are identical in dimensions to the Surestart crank and will fit any post 1956 Cox .049 reed valve engine.
Bernie
That's odd do the spacers got before the drive plate?
Live chat?
They go between the drive plate and the crankcase so there's no front to back slop. It'll keep it from galling the reed retainer. Is that what you mean?nitroairplane wrote:That's odd do the spacers got before the drive plate?
RknRusty wrote:They go between the drive plate and the crankcase so there's no front to back slop. It'll keep it from galling the reed retainer. Is that what you mean?nitroairplane wrote:That's odd do the spacers got before the drive plate?
Yes bevause I have a pee wee in need of those their is so much slop in it.
nitroairplane wrote:RknRusty wrote:They go between the drive plate and the crankcase so there's no front to back slop. It'll keep it from galling the reed retainer. Is that what you mean?nitroairplane wrote:That's odd do the spacers got before the drive plate?
Send me a measurement for the Pee Wee and I can see if it is easily sourced.
These Killer Bee spacers fit over the crankshaft between the driveplate and crankcase. You can still use a thrust washer with it. They were a custom project.
Matt
That's one thing the PeeWee's never had was a thrust washer and I think they help a motor by not letting aluminum wear and float when flipping them. Theres also the occasional backward start too that can chew on them.
I am aware the aluminum of the case is meant for long wear, but not so sure of the soft driveplate.
jetpack- Gold Member
Bernie
How much is a tiny bit longer? A couple of thousandths?
Ok then youvmean from the drive plate-the braised when they are furthest apart.EXModelEngines wrote:nitroairplane wrote:RknRusty wrote:They go between the drive plate and the crankcase so there's no front to back slop. It'll keep it from galling the reed retainer. Is that what you mean?nitroairplane wrote:That's odd do the spacers got before the drive plate?
Matt
One thing that will absolutely kill top end rpms is a out of balance prop.
I use this little guy from Heads Up RC. I found it more accurate for small props than anything else. One of my ultra secret websites that I don't share that often, lol.
http://www.headsuprc.com/servlet/the-1498/Magnetic-Prop-Balancer/Detail
Anywhere from 5 to 10 thousands.
The length does not necessarily play much of a role unless one want to use an electric starter or run the engine in pusher mode.
Bernie
www.coxinternational.ca
Bernie
Bernie,
Is there a recommended procedure for shortening them. I am thinking about just taking it to a sanding disc and going easy and rechecking the lenght often. I will be sure not to over temp it. Am I just being foolish to think I can do it so easily? I have one that I polished and installed in a new crankcase and went through several drive plates until I came across this thread.
Thanks for the help,
fit90- Diamond Member
Bernie may want to jump in and correct me on this one.
The drive plate seats against the shoulder just behind the splines. The problem likely is not the OAL of the crank, but the length of the shaft between the bearing surface on the face of the web and the shoulder. The purpose of the spacer is to fill in the gap between the back of the drive plate and the nose of the case.
I don't think you will be able to easily face off the front of the shoulder without a lathe and some effort since the shaft is hard. You would have better luck counter boring the backside of the thrust plate to allow it to seat further back.
Matt
Just checked Matt and the difference at the furthest point is 1.65mm but it is fine as the engine still runs well enough.
But thanks anyway.
You are correct, Andrew, it is the bearing shaft that is sometimes a bit longer and not the spline. The only "fix" is using the spacers we provide (if you even want to use them). It reaally depend on te crankcase; some are shorter, some longer.
Bernie
Bernie
Andrew,
Thank you! I never even thought to look at that . I like your idea of counter boring the drive plate. Fast, simple and should be completely effective if done carefully.
Thanks again to all for the education. I obviously haven't finished all my schoolin' yet.
fit90 wrote: I like your idea of counter boring the drive plate. Fast, simple and should be completely effective if done carefully.
Before I would go to the trouble of counter boring, I would just try it FIRST with the shims that have been posted about.
Just a thought.
PV Pilot wrote:Before I would go to the trouble of counter boring, I would just try it FIRST with the shims that have been posted about.
Just a thought.
That's certainly the quickest, easiest and most practical approach. It would take some care in initial measurament and fairly decent equipment to get the correct counterbore depth -- a little too deep and the crank will bind. OTOH, for some, the enjoyment is in the tinkering.
However, for both approaches, you'll have a limited number of tries to "get it right". The thrust plate is an interference fit on the shaft and I don't know how many remove/reseat cycles it will stand before loosening, so preliminary measurament is imperative.
Probably for almost all flying, shimming is really the way to go. If you're going for "hair on fire" top end, the counterbore may be advantageous. Apparently, the relieved area between the splines and front bearing shoulder is prone to stress fractures. If the nose of the case were faced off slightly and the thrustplate were counterbored to allow an interference fit over the very front of the crank bearing, it might provide enough added support to reduce separation in this area. Gibeault has indicated that a stud is preferable to a prop bolt in alleviating this problem.
yep, you would have to get it correct on the first or second try, after that I would imagine that tolerances are being lost due to just working the pieces. then start over, ect.
If you go the counter-boring route, it would probably best to use an end mill and make the hole slightly larger than the OD of the crankshaft bearing.
Regards, Matt
Regards, Matt
I didn't follow completely the debate, but what is the purpose of those two spacers you sell? Are they apparented to thrust washers? And which one would I choose with an hex plate?
Thanks for your help
Manu
Manu
Personally, I would say don't use them at all. But, if you do use tehm they slip on before the thrust washer (if you are using a thrust washer) and the.
The crankshaft can, depending on the crankcase, stick out a few thousands of an inch more that OEM specs and one (or 2) of the spacers will take up that space.
Bernie
Bernie
Oh, I tough they served as thrust washers... Should have asked it first before making the order... My Venom will be without it then
» Cox .020 Tee Dee Questions
» Tee Dee questions
» Several Questions
» The R/C Bee, new to me and questions
» Some td 0,49 questions
» Tee Dee questions
» Several Questions
