Jig for engine mounts Cox_ba12
Jig for engine mounts Pixel
by batjac Today at 10:05 pm
by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
Jig for engine mounts Empty
Jig for engine mounts Empty Jig for engine mounts
Post  RK Flyer Wed Sep 11, 2013 10:06 pm
Berni,
I always have to spend a lot of time drilling holes for engine mounts. How about a simple jig to mark & drill the holes for the cox engines?
RK Flyer
RK Flyer
RK Flyer
Jig for engine mounts Empty Re: Jig for engine mounts
Post  Cribbs74 Wed Sep 11, 2013 10:16 pm
Good idea!
Post  pkrankow Wed Sep 11, 2013 10:30 pm
Stickers are simple.
I have to agree, this would be nice. Heck even a PDF that has scales on it so it can be printed properly would be very helpful.
Post  duke.johnson Thu Sep 12, 2013 9:03 am
There's a mounting pattern on a few drawings I have. If you look you may find a pattern. I just copied one and I'll use a glue stick to put it on the mount, drill, then peel it off before the glue sets.
duke.johnson
duke.johnson
Post  JPvelo Thu Sep 12, 2013 10:08 am
Watch for a beat up babe bee on eBay and use the metal backplate for a jig. I use an old product backplate and a worn out Tee Dee case for jigs as well.
JPvelo
JPvelo
Post  duke.johnson Thu Sep 12, 2013 10:19 am
I like the idea of the paper copies off the plans, they have both tank and backplate patterns all in one. I usually set it up for both, just in case I want the change engines.
duke.johnson
duke.johnson
Post  roddie Thu Sep 12, 2013 10:50 am
duke.johnson wrote:I like the idea of the paper copies off the plans, they have both tank and backplate patterns all in one. I usually set it up for both, just in case I want the change engines.
I've done this too... but you have to re-balance for C.G.; depending on your engine/tank set-up.
Paper template(s) with "X's" at the 4 mount-points would be a lot easier and result in a more accurate means of marking the holes for drilling. I usually do it with an "unused" backplate of the candidate engine; trace the holes with a sharp pencil and use a small SHARP "awl" or "pin-vise" with a sewing needle, to punch the starter holes for drilling.
Post  SuperDave Thu Sep 12, 2013 11:30 am
Extremely helpful also is the tool from Great Planes. It allow the user to drill perectly centered mounting holes every time.
I got mine at a swap meet for $1.00. (IIRC)
SuperDave
SuperDave
SuperDave
Post  duke.johnson Thu Sep 12, 2013 12:14 pm
Yes, I have one of these. I use it for the larger engines.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXK378&P=SM
Jig for engine mounts Great_10
duke.johnson
duke.johnson
Post  RknRusty Thu Sep 12, 2013 3:09 pm
I really need one of those. No matter how careful I am, I always get one off center.
Post  JPvelo Thu Sep 12, 2013 4:05 pm
RknRusty wrote:I really need one of those. No matter how careful I am, I always get one off center.
When I use a backplate for a jig I drill the first hole and then screw the backplate to the firewall. I then drill the hole opposite the first one, using the screwed down backplate as the jig. Install the screw in the second hole and then drill the other two. It's not completely foolproof but it works pretty well for me.
JPvelo
JPvelo
Post  RknRusty Thu Sep 12, 2013 7:36 pm
These folks make some nice drill guides, bending tools, etc. I'd love to have a drawer full of their doodads.
http://www.harryhigley.com/index.htm
Post  duke.johnson Thu Sep 12, 2013 8:03 pm
I have some benders from Harry Higley. The bender for 1/8 wire landing gear is great.
duke.johnson
duke.johnson
Post  pkrankow Thu Sep 12, 2013 9:14 pm
RknRusty wrote:These folks make some nice drill guides, bending tools, etc. I'd love to have a drawer full of their doodads.
Wow, what a treasure of doodads!
Post  RknRusty Fri Sep 13, 2013 1:05 am
They make a nice tube bender. I only have the cheap spring benders and they are nothing special.
Post  roddie Fri Sep 13, 2013 1:44 am
duke.johnson wrote:I have some benders from Harry Higley.  The bender for 1/8 wire landing gear is great.
I bought the "Harry Higley" 1/16" "Z-bender" back in 1992; for forming the Z-bends in my 1/2-A  C/L bell-crank to elev. horn linkages. My literary library includes Harry Higley's; "Flying Around", "Harry's Handbook... for miniature engines", "There Are No Secrets" and "Master Modeling".
The books are a  "wealth" of information for the modeler... "Harry's Handbook... for miniature engines" has a section; (chapter 12) on 1/2-A engines... that is very useful to the novice; for understanding how the "Cox" engines work, and how to care for them. "Master Modeling" contains a chemical "compatibility chart" which helps with "finishing" your model... and "Flying Around" discusses the "elements" of "control-line (or U-control) flight to the "novice"; in an "easy to understand" manner. A perfect guide for someone just beginning; who has little or no help from others.
I would highly recommend their reading; for anyone interested in getting involved with the flying of model airplanes.
Post  SuperDave Fri Sep 13, 2013 10:55 am
duke.johnson wrote:Yes, I have one of these. I use it for the larger engines.
Me too Duke.  A very useful tool for centering all sorts of holes.
Used mine to center the holes for kitchen cabinet hinges a while back.
Did a PERFECT job!     Clapping
SD
SuperDave
SuperDave
