5-40 x 1" socket head bolts Cox_ba12
5-40 x 1" socket head bolts Pixel
by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
5-40 x 1" socket head bolts Empty
5-40 x 1" socket head bolts Empty 5-40 x 1" socket head bolts
Post  warrenlead Sun Nov 06, 2011 7:16 am
Gee I never realized how hard these are to find. I have a box of engines that I'm doing up and will be putting Tee Dee spinners on them. I never have liked the standard screws and like to use 5-40 socket heads but they don't seem to be as readily available as one might have thought. Where do you guys get them?
warrenlead
warrenlead
https://www.facebook.com/groups/coxengines/
5-40 x 1" socket head bolts Empty Re: 5-40 x 1" socket head bolts
Post  nitroairplane Sun Nov 06, 2011 7:22 am
here.
http://pointe-products-inc.amazonwebstore.com/B000NE4M6Q/M/B000NE4M6Q.htm
or here
https://www.easupplies.com/CAMCAR-SDSC0050075CPPK100-Socket-Head-Cap-Screw-p/fa5cfi.htm
nitroairplane
nitroairplane
Post  warrenlead Sun Nov 06, 2011 7:45 am
Those are 3/4" long (too short) but I get the idea. Would nice to find some button heads that fit the Cox spinner too. I will search the google for a local supplier here.
Cheers
warrenlead
warrenlead
Post  nitroairplane Sun Nov 06, 2011 7:47 am
warrenlead wrote:Those are 3/4" long (too short) but I get the idea. Would nice to find some button heads that fit the Cox spinner too. I will search the google for a local supplier here.
Cheers
Ok so you need about 1" i will try and find some.
nitroairplane
nitroairplane
Post  nitroairplane Sun Nov 06, 2011 7:49 am
How about this set?
http://motorcycleproducts.co.uk/catalogue/screws-allen-5mm-160pc-kit-stainless-button-p-230898.html
nitroairplane
nitroairplane
Post  andrew Sun Nov 06, 2011 8:08 am
I use these folks for all kinds of hardware needs at work, shipping is very reasonable.
McMaster-Carr
Choose the size of socket head you want from the sizing chart on the left. They have both stainless and black oxide, 1", $3.82/50.
My preference is to buy in bulk in the sizes I need, but in the maximum length I might use; I then use a Dremel cutoff wheel to cut to desired length.
Post  warrenlead Sun Nov 06, 2011 7:12 pm
I would be happier if Bernie and Matt stocked them... HINT!
Not sure how I would go with Mcmaster Carr being that I'm in Australia and all.
Anyway I got a bag of 15 from a RC Car supplier for $2.00 so I should be right for now.
Cheers
warrenlead
warrenlead
Post  dckrsn Sun Nov 06, 2011 7:51 pm
I use socket head screws on reedy backplates with good results.
They give better torque feedback than a slot head. They do seat flush.
Don't mean to gloat, but those are KustomKraftmanship backplates.
Fine thread collet needles.
5-40 x 1" socket head bolts 00111
Post  warrenlead Sun Nov 06, 2011 9:17 pm
dckrsn wrote:I use socket head screws on reedy backplates with good results.
Very nice! What thread size and length are they?
warrenlead
warrenlead
Post  andrew Sun Nov 06, 2011 10:42 pm
The .049 (8cc tank) is 2-56 x 1". The .049 (5cc tank) is 2-56 x 3/4".
The .020 should be about 2-56 x 1/2".
I measured a BW with metal backplate and the threaded portion was just under an inch. Since most screws are sold by thread length, you may have to shorten them to get a good tank seal. Usually, I check the depth of the threaded hole in the crankcase and use that to judge how much I may need to cut off.
Post  warrenlead Mon Nov 07, 2011 5:55 am
Gday
I just had a look at some of my engines and checked the length of the screws. I think it's fairly important to get the length spot on because, as you mentioned, the tank will not seal properly if the screws are too long. (As mentioned and shown in Paul Gibeault's Mouse Race Program document, 1" tank screws are usually too long.)
So with that in mind, here are some revised specs and just in case anyone else is considering doing this, Socket Head Bolts are measured from below the socket head to the end of the thread.
BABE BEE 049 (5cc Tank)
Prop Screw = 5-40 x 1/2"
Tank Screw = 2-56 x 11/16"
BLACK WIDOW 049 (8cc Tank)
Prop Screw = 5-40 x 1"
Tank Screw = 2-56 x 15/16"
TEE DEE 049/051
Tank Screw = N/A
PEE WEE 020
Prop Screw = 3-48 x 1/2"
Tank Screw = 2-56 x 1/2"
TEE DEE 020
Prop Screw = 3-48 x 3/4"
Tank Screw = 2-56 x 1/4"
Cheers
warrenlead
warrenlead
Post  Kim Mon Nov 07, 2011 6:53 am
warrenlead wrote:Gday
TEE DEE 049/051
Tank Screw = N/A
PEE WEE 020
TEE DEE 020
Cheers
Hey Warren,
Thanks for this post..handy to copy and paste for quick reference!
Post  PV Pilot Mon Nov 07, 2011 7:07 am
http://www.tonysscrews.com/
Just recieved a order from Tony for 5-40x1" button heads (spinner screws), 2-56, 4-40 and 2.5 mm backplate engine mounting screws. Some 10-32 and 6-32 also. Been purchasing Tonys HD standard and metric black oxides for years. Extra deep tool sockets on each screw,,good stuff.
PV Pilot
PV Pilot
High Tech Balsa Basher
Post  andrew Mon Nov 07, 2011 7:14 am
I have found that many of the Surestarts have crankcase holes tapped to various depths. Consequently, out of 4 screws, 3 may seat properly and one will bottom out before tightening up. When cleaning the engine before running, I check the thread depth and trim the screws if necessary. Secondly, I've also noticed that almost all of the cases have tap burrs raised around the screw holes --- a little quick buffing on oiled 400 grit on a piece of glass knocks these off and trues up any low spots on the case back.
Post  dckrsn Mon Nov 07, 2011 4:18 pm
andrew wrote:I have found that many of the Surestarts have crankcase holes tapped to various depths. Consequently, out of 4 screws, 3 may seat properly and one will bottom out before tightening up. When cleaning the engine before running, I check the thread depth and trim the screws if necessary. Secondly, I've also noticed that almost all of the cases have tap burrs raised around the screw holes --- a little quick buffing on oiled 400 grit on a piece of glass knocks these off and trues up any low spots on the case back.
Whenever I'm "doing up" an engine, I usually run a 2-56 bottoming tap into the case threads.
Sometimes I find the threads haven't been cut all the way in. Also removes any crud
that may have acumulated at the bottom.
The mating surface almost always needs dressing. Surestarts always need it.
Post  andrew Mon Nov 07, 2011 5:03 pm
I've got to get me one of those -- it really is the best approach.
Post  dckrsn Mon Nov 07, 2011 5:58 pm
Andrew,
I bought a couple from McMaster-Carr with the heavy handed shipping cost Crying or Very sad , but
Dubro packages them with the appropriate drill included.
From Tower for less $ total.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXE213&P=7
A mini tap handle is almost a must with one this small. Don't forget
to use lube. Tap Magic for aluminum works well but $$$. 3 in 1 works.
Post  PV Pilot Mon Nov 07, 2011 9:04 pm
I ordered two each of those dubro sets,,and got two taps per package but no drill bits. Dont know how dubro missed that screwup. Gave a couple to my buddy. A very steady hand required when starting those in the hole.
PV Pilot
PV Pilot
