by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
by rsv1cox Today at 3:38 pm
TeeDee .049 Break In Procedures
I spent some time today bench running two new TeeDee .049s. One was a brand new older (70's) version and the other was a rebuilt (new Cylinder/Piston and carb). I was running Sig Champion Fuel with 25% nitro. Did four engine runs at rich needle setting. How many times (how long) do I need to run the engines before I can take them up to full speed? What is the point of using two or even three head gaskets? The older TeeDee seemed to run rough with two head gaskets, and did better with only one.
I was really amazed at how easy these engines started and ran. Much nicer than the reed valves. I recently broke in two medallions as well, and the same with them. Very easy starting and very smooth running. Thanks, Andy
anm2- Gold Member
Re: TeeDee .049 Break In Procedures
After 4 rich runs, letting it completely cool between each one, I think you can start peaking it out for short periods, and then see if it'll hold peak for a full run. If so, fly it. Take it a little easy on really lean runs for a few flights. Sometimes they get too varnished when new, but I think the Sig 50/50 synthetic/castor will prevent that problem.
The old ones might not have good compression. You can take some 800 or so grit paper on apiece of glass and and twist the head against it making sure it's uniformly flat all the way around. Clean it thoroughly before re-installing it. Or try new glow plugs. If none of that works, if you have any pure castor fuel, maybe you can develop enough varnish to increase the compression. Bernie and Matt sell new Tee Dee Piston/Cylinder sets too.
The added head gaskets change the timing of the engine. it is a variable with fuel and prop choices to tune the engine for best performance.
RknRusty wrote:After 4 rich runs, letting it completely cool between each one, I think you can start peaking it out for short periods, and then see if it'll hold peak for a full run. If so, fly it. Take it a little easy on really lean runs for a few flights. Sometimes they get too varnished when new, but I think the Sig 50/50 synthetic/castor will prevent that problem.
Thanks. I ran both of them again today, and they held very nicely at peak and right off peak. I am very pleased with both ease of operation and speed. I did not have my tach, but I am pretty sure they were both over 20K RPM. Andy
anm2- Gold Member
The above alters ignition timing only. Shims under the barrel alter port timing and ignition timing simultaneously.pkrankow wrote:The added head gaskets change the timing of the engine. it is a variable with fuel and prop choices to tune the engine for best performance.
dinsdale wrote:The above alters ignition timing only. Shims under the barrel alter port timing and ignition timing simultaneously.pkrankow wrote:The added head gaskets change the timing of the engine. it is a variable with fuel and prop choices to tune the engine for best performance.
How does port and ignition timing effect the engine?
anm2- Gold Member
