by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
by rsv1cox Today at 3:38 pm
Cox Propellor
Cox Propellor
Be careful.
Interesting incident today, Propellor blade sheared off while bench running my Hiscott Medallion! Can't find the blade that sheared off!
It seemed very flexible and not brittle in anyway.
It has 'Cox Hobbies Inc' on it - I have quite a few!
Re: Cox Propellor
Black Cox "rubber duckie" props are intended for general use; gray are for competition flying. It's quite usual to have one shear.
SD
(If you were thinking of finding the missing blade then glueing it back on FORGET IT!)
SD
SuperDave- Rest In Peace
Re: Cox Propellor
ian1954 wrote:Be careful.
If those are original Cox props they may not be safe to use.
Bernie has new props at bargain prices. My favorites are the rubber ducky flexible props, and I've yet to break one.
Bill
Last edited by smooth_bill on Sat Jun 29, 2013 5:25 pm; edited 1 time in total (Reason for editing : Lost the text I meant to post,)
smooth_bill- Gold Member
Re: Cox Propellor
check the ceiling......
Re: Cox Propellor
I have a number of Top Flite propellers that are suffering the same fate. I have not tried boiling them in water yet, but simple soaking did not change the failure mode.
The nylon is supposed to absorb water improving its pliability and resilience. In fact, soaking NEW propellers does improve the durability of them. I soak nylon props overnight then keep them in a zip lock bag. The new propellers are more supple after soaking. The treatment is also supposed to be good for glass or polyester filled nylon props.
Re: Cox Propellor
pkrankow wrote:I have a number of Top Flite propellers that are suffering the same fate. I have not tried boiling them in water yet, but simple soaking did not change the failure mode.
If the props absorb water wouldn't affect the balance?
JPvelo- Diamond Member
Re: Cox Propellor
Did you purchase them from us?
Re: Cox Propellor
Cox International wrote:ian1954 wrote:Be careful.
I did but I am not seeking any redress. Just a warning to be careful where you stand when close to a running engine.
Plastic, nylon etc. are strange materials and anything that is cast or moulded is suspect. There is no way of checking for perfection unless you have X-Ray vision. One in many hundreds of chances of this happening.
This did not hit me, I didn't even see where it went (haven't found it yet either!). In front or behind the propellor is probably the safest position. I once took a splinter in the back of my hand from a wooden propellor. I was smoking a cigarette - it could have been my jaw!
Re: Cox Propellor
There have actually been issues with those props as they are old Cox stock.
We test-bend each one and have about 25% failure rate. Only a few hundred left and we are getting new ones moulded.
Please identify yourself to us by email to support@coxengines.ca with perhaps either an order # or order date. We will then send replacement props.
Re: Cox Propellor
JPvelo wrote:pkrankow wrote:I have a number of Top Flite propellers that are suffering the same fate. I have not tried boiling them in water yet, but simple soaking did not change the failure mode.
In principle it will absorb water evenly, so balance should be minimally affected.
Re: Cox Propellor
....along those same lines, an old thought/theory/belief was that wooden props should be stored horizontally as storing vertical the moisture would migrate to the bottom.
I gotta wonder if that concept came from '1:1 scale' wood props
Re: Cox Propellor
Cox International wrote:There have actually been issues with those props as they are old Cox stock.
Bernie,
I thank you for the offer and your exemplary service but these things happen and a $1.95 prop (£1.28) is of little consequence to me. You are also to be acknowledged for conceding these props lack of perfection and for testing them before you ship.
Buying "old things" is always a risk, not everything stands the test of time and things that spin at 5-30,000 revolutions per minute have to be treated with caution - new or old. It could happen with any propellor - just don't stand in line with the blades!
Thank you again.
Re: Cox Propellor
Ian,
We really need to replace them, as we have done for others in the past, as they were evidently defective before we shipped and you can expect to receive non-defective merchandise.
We insist ...
We insist ...
Re: Cox Propellor
Haha, Ian you're gonna get new props and by dang, you're gonna like it! And that's that.
Re: Cox Propellor
I will drop a note with my next order!
"Oh yes you will, oh no I won't" - British pantomime sketch!
Re: Cox Propellor
Mark Boesen wrote:....along those same lines, an old thought/theory/belief was that wooden props should be stored horizontally as storing vertical the moisture would migrate to the bottom.
I'm sure it did. On fulls size props, the moisture migration is a real issue. I always keep my prop horizontal when not flying, and store wooden props horizontal on the shelf. For model props, I wouldn't worry about it. The moisture content isn't that high, and migrating two to three inches is improbable unless the prop's been resting on one blade for 20-30 years. But, a 60" prop sitting vertical in changing weather is different.
The Aeronaut Mark
batjac- Diamond Member
» Propellor Performance Question
» 1/4A-1/2A propellor mounting food for thought.
» Fashion model walks into spinning propellor
