by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
by rsv1cox Today at 3:38 pm
Texaco duration slow race
Page 2 of 3
Page 2 of 3 • 1, 2, 3
Re: Texaco duration slow race
I was meaning the same thing as you said. Ya, any engine can enter, but not all can run slow.
OK, so as I understand it
Cox based .049 engine of any vintage
has Cox fuel tank either 5cc or 8cc
any fixed porting changes as desired to the intake and exhaust (if something falls out or slips in shipping you are screwed)
adjustments to anything other than the needle is outside the scope of the competition
tuned to swing this prop
http://coxengines.ca/cox-.049-.15-texaco-propeller-grey-8-x-4.html
The fuel used will be 15% nitromethane
This thread took off!
So it looks like there is interest.
From the comments:
1) Set up 2 classes - 5cc Texaco Jr, and 8cc Texaco
2) Determine when the clock starts. I was thinking get the engine running and then refill the tank and start the timer. Thoughts on this approach?
3) Fuel used: SIG Champion 15% nitro
4) Cox grey 8x4
5) Any cylinder combination can be used
6) Limit to tanked engines only? They are consistantly the same volume so it would be fair for all that way unless someone hogs out a tank to be wafer thin toi increase volume.
I don't think there should be any expert or novice classes. Just the 5cc and 8cc class for simplicity sake.
Need to set a date for this. May is out for me as my weekends are all used up. Either mid April or sometime in June.
From the comments:
4) Cox grey 8x4
Jason_WI- Top Poster
I am good with tanked only, never thought about removing material to holld more fuel. Thanks for the idea! (just kidding)
April or June works for me.
duke.johnson wrote:Wish I had a Texaco.
Texaco II
http://coxengines.ca/cox-.049-engine-texaco-ii.html
Texaco Jr. II
http://coxengines.ca/cox-.049-engine-texaco-jr.-ii.html
WingingIt74 wrote:Are we doing duration or slowest RPM? Actual or Virtual?
Slowest RPM should be accounted for too.
I would suggest to video the entire engine run, then use the video time to figure the duration. If you have more than one camera and test stand you can run multiple entries at the same time.
If you have a dozen engines to run, 7+ minutes of duration expected, this makes for a long time.
Well I'll be darned Phil, they really do run 7+
I have a Texaco that I have never ran and decided to fire it up after you said they would run over 7 minutes. I didn't have a Cox 8x4 so I used a TF. It ran 7:18! Probably would have run longer as it took a while for the old goo to cycle out and I had to fiddle with the needle.
Pretty cool little engines.
They are cool little engines. Jeremy is going to build be a RC plane for mine.
WingingIt74 wrote:They are cool little engines. Jeremy is going to build be a RC plane for mine.
It would make for a lovely little floater. Think it would throttle well?
I don't think I'd worry about a throttle. That test we did last weekend, I think, went well.
WingingIt74 wrote:I don't think I'd worry about a throttle. That test we did last weekend, I think, went well.
It did look cool, I've always liked hovering into the wind. If I ever get over the CL bug I would like to make something for my Texaco.
20-fin you say.... You have a special glow clip for that? You planning on swinging a Hartzell or McCauley prop?
Waiting for someone to point that out! Just solder a little piece of insulated wire to the contact post on the insert and have it extend out the top of the head body.
With your prop choices, you would need a much larger prop spacer!
Measured amount of fuel going into tank (say 7.5 & 4.5 cc)? : eliminate differences in runtimes due to inadvertently over/under filling tank. Wouldn't be surprised if differences between plastic and metal backplates affect capacity, too.
ahrma_581- Gold Member
Never thought about that, that's a good way to fix the variable.
You could carefully fill the tank and see what it holds then after needling top it up for duration. After the run divide the duration by volume for the score.
I suspect the volume will be rather similar for all the engines though.
I think the duration would be a pain to do... to be honest. I think the slow tach race would be the way to go.
WingingIt74 wrote:I think the duration would be a pain to do... to be honest. I think the slow tach race would be the way to go.
I'm inclined to agree with this
I think I have an engine to run in this. I just need the correct prop so I can tune it.
It is an old baby bee with a "Thimble Drome" fuel tank on it.
Has Jason firmed up the rules yet? I think he has been busy with his latest Ebay haul.
Nothing is set in stone yet. The more I think about how to be fair with a duration race I think I will just limit this to the slowest RPM acheivable on a Cox grey 8x4 prop and 15% Sig Champion fuel. The duration part of the race could take days to complete if many engines were sent in. This way there is no need to have a specific size tanked engine.
2 classes can be held then. One for completely stock engines like the Babe Bee, Golden Bee, Texaco, Texaco Jr, Venom
The other class for modified engines with custom intake venturi sizes, cylinder types, crankcase types (car)
NO throttle rings allowed!
So no exhaust restriction or just no adjustable throttle rings?
Exhaust restrictions would have to be fixed in place somehow. Could use a Tatone muffler and plug the exhaust hole up but this would remain in a fixed position. There is no way to have an ajdustable throttle ring that moves around. It has to be fair to everyone.
» How to make reed valves out of a floppy disk
» Texaco 049 and the Texaco 1/2A rules
» Cox Texaco and Texaco Jr. built with Kustom Kraftsman's parts.
» Killer bee exhaust duration
Page 2 of 3
