.049 Stationary Engine Cox_ba12
.049 Stationary Engine Pixel
by batjac Today at 10:05 pm
by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
.049 Stationary Engine Empty
.049 Stationary Engine Empty .049 Stationary Engine
Post  Motra Thu Jan 24, 2013 2:08 pm
Here's an interesting one. It's a homemade bottom end using a Cox cylinder with a homemade sub-piston intake system and a full crankshaft. I didn't build it and it's unfinished. I'm thinking of building a stand for it and putting a flywheel on one side.
.049 Stationary Engine DSCF0004
.049 Stationary Engine DSCF0005
Motra
Motra
.049 Stationary Engine Empty Re: .049 Stationary Engine
Post  RknRusty Thu Jan 24, 2013 2:20 pm
That's an odd one. Does the piston go all the way to the top at TDC? Is there a check valve in that SPI pipe?
Post  tubebass Thu Jan 24, 2013 2:43 pm
That would be side port induction like the old Ohlssen .23 had.
The piston skirt blocks and unblocks the port.
tubebass
tubebass
Silver Member
Silver Member
Post  Motra Fri Jan 25, 2013 11:37 am
Here are some more pictures. The builder of this engine didn't finish it so there isn't anything in the intake tube. I suppose he would have used a spraybar from another engine. As was stated, the position of the piston controls the intake. As it approaches TDC it uncoveres the intake port in the cylinder. I got this engine on eBay from somebody who was selling off his deceased uncle's collection or something like that. It was listed with a run-of-the-mill Babe Bee and the picture was very fuzzy so nobody else bid on it. I think I got both engines for like $11.00.
.049 Stationary Engine DSCF0008
.049 Stationary Engine DSCF0013
.049 Stationary Engine DSCF0012
Motra
Motra
Post  Cribbs74 Fri Jan 25, 2013 11:50 am
What I don't understand is what was the original application? The builder must have had something in mind as I see no reason to run the crank out of both ends.
Post  RknRusty Fri Jan 25, 2013 12:52 pm
Positrack! I don't know, but that's a heavy crank assembly for one little piston to spin.
Post  Cribbs74 Fri Jan 25, 2013 12:58 pm
Lol, maybe. Or perhaps a mini generator.
Post  pkrankow Fri Jan 25, 2013 3:11 pm
Could run just about anything off the drive shaft. I bet it is sized for a standard size.
I don't see any reason it won't run with a spray bar added to it.
Post  WingingIt74 Fri Jan 25, 2013 3:16 pm
That'd be cool. Just make sure you have some sort of weight on the shaft... prop or fly wheel.
WingingIt74
WingingIt74
Post  mitchg95 Fri Jan 25, 2013 3:42 pm
hope to see it run, i like how unique the engine is
mitchg95
mitchg95
Post  ado1974 Fri Jan 25, 2013 6:19 pm
with crank out both sides...
...my guess would be a tether car engine??
a
ado1974
ado1974
Silver Member
Silver Member
