Building a Kaman free flight helicopter
Hello all,
i want to build this Kaman free flight helicopter:
https://www.coxengineforum.com/t3341-helicopter-babe-bee-power
But i dont want to build it so big. I want to build it half as large as the original with a Cox PeeWee(.020).
Do you think that it will work with this engine and the size?
bnitram
bnitram
bnitram- Silver Member
Re: Building a Kaman free flight helicopter
Maybe someone knows the power of the 0.020 vs that 0.049, then scale the model directly? 0.020 / 0.049 = 40% scale?
Might be neat to go the other way too, put a Tee-Dee 0.09 on it and double it's size.
daddyo- Gold Member
Thanks for answer.
That would be the best way but i don't now anything about the power in detail.
But I think that the engine has enough power to fly with the helicopter. What would you think?
The engine has enough power to bring a rc airplane in the air. Then it should also get free flight hlicopter in the air right?
bnitram
bnitram
Hi bnitram,
And if I haven't said so, Welcome to the Forum! I'm not involved in a lot of rotorywing flying, but here are my thoughts:
Engine sizes/ratios between airplanes and helicopters don't transfer equally because of the different characteristics of the two...especially in THIS type where the engine is essentially dead-lifting the helicopter with it's little prop. An .020 on an airplane just pulls it forward and lets the wings do the lifting. The rotors on this type basically provide stability by spinning while the propeller does all the lifting. With the engine out of fuel, the rotors then do their thing in gently lowering it to the ground.
Cox marketed an .020 type called a "Sky Copter" which flew so well, there was a chance that it'd take off and leave you. Perhaps Mark or some other collector here would measure and weigh theirs to give you some workable numbers to shoot for. Hope this might help.
Good Luck with your project ! Kim
Thanks for answer.
So the size and weight are very important.
Do you think if I take the right size and weight it will work?
bnitram
bnitram
Does anyone here know the power output of these engines? I would wild guess that a Babe Bee is around 40 watts. There is at least one member at RCG that has done extensive power measurements on engines. I'll try to find one of his threads. I don't even remember his name right now. He built a device with a swing arm he mounts the engine to and measures how much it can pull.
If you know the watts per pound of the original, then yours will scale directly.bnitram wrote:Thanks for answer.
bnitram
Hello! Thank's.
I think I found a table with performance disclosures.
http://www.mh-aerotools.de/airfoils/cox_performance.htm
Can it help?
bnitram
Can it help?
bnitram
You could set the engine up on a balance beam and weigh the thrust...
With many models, the density decreases as volume increases. This means a larger model ends up with lighter loading due to proportions.
Re:
I remember as a kid putting an 0.020 on a scratch hovercraft and it just sitting there stuck to the ground... But the cox helo flew nice.
Show us your result! BTW anyone ever see an engine tied to a rag fly like a helo?
Looks like the horizontal axis is RPM so if you got the right prop on tweaked for max horsepower, you likely get 26 watts out of the 0.020, and roughly twice that out of a typical 0.049. So just go for 1/2 the weight I'd guess = 1/2 the size.bnitram wrote:http://www.mh-aerotools.de/airfoils/cox_performance.htm
daddyo- Gold Member
daddyo wrote: BTW anyone ever see an engine tied to a rag fly like a helo?
like this
https://www.youtube.com/watch?v=ph2PMs2-7G4
https://www.youtube.com/watch?v=67PUWyKdqjI
cheers
a
ado1974- Silver Member
So you think that it works well with a half size and the Cox PeeWee.
Just as I thought. But not with the power but the size of the engine.
bnitram
bnitram
Since things don't always scale exactly, you might consider building it with a bit longer main rotor blades. Then you can cut them back if needed to get the desired lift. Easier to cut them down than adding length....
ahrma_581- Gold Member
Ya! Haven't seen that in a while! Amazingly cheap, ultimate quick build haha.ado1974 wrote:daddyo wrote: BTW anyone ever see an engine tied to a rag fly like a helo?
like this
cheers
a
I'm sure things don't scale exactly but my thought is that were not going 1/20th scale or the like, just 50%. Looks like horsepower is kinda proportional to displacement, but that can sure vary alot depending on model/brand. Also since the helo is mostly made of material along the length of the body, which might likely be most of the weight aside from the motor, that cutting the length in 1/2 would be 1/2 weight. Might want to see what the weight of the motor is between the two sizes to see if that might affect things (are they 2:1 ratio?). If you want to be certain it'll have enough lift, maybe you would make it even smaller than 50%.
daddyo- Gold Member
Many thanks for the answers.
I think I will begin in a few weeks and i will build the blades a bit larger than normal to test it out.
bnitram
bnitram
» Help with Cox free flight helicopter
» Cox Skycopter Free Flight Helicopter
» Wanted rotory wires for free flight helicopter
» Free Flight 101
» F1a free flight
» Free Flight 101
» F1a free flight
