Ebeneze Gee Bee R1
Ebeneze Gee Bee R1
Hi, I am planning to build an all balsa profile, 21 inch span, freeflight Gee Bee R1. (Ebeneezer)
Will a Cox 0.49 be too powerfull?
Second question. Although a profile design I plan to a have a full cowl. Is there a some kind of extended glo clip I can use.The cowl is 4 inches in diameter.
If not, my plan is to fix the two wires to the head somehow. Then fix the other end of the two wires to a jackplug socket on the outside of the cowl. Any ideas?
Thanks.
Thanks.
ebeneezer- Gold Member
Re: Ebeneze Gee Bee R1
With a 21 inch span a .020 would probably be a better choice. You could affix leads to the head or just snap a standard cox issue glow clip in place and run the leads as you suggested.
Thanks. The 0.49 I'm planning to use is the one out of my sons Cox PT 19 controliner circa 2000
Its one I've got and it doing nothing. I dont think its a very good one. It seems too have a lot of end float on the prop shaft. If it's run for an hour thats all it has ever run
ebeneezer wrote:Thanks. The 0.49 I'm planning to use is the one out of my sons Cox PT 19 controliner circa 2000
Well, it will fly it if all is balanced well. I would run it a tad rich or that FF may get away from you.
As to the float as long as the crank pin is not rubbing the backplate then it should be ok. All Cox engines have this to a varying degree. It can be corrected by adding a thrust washer behind the driveplate.
I thought about a thrust washer. Where would the best place be to get one?
Can you put enough prop on it to blow past the 4" cowl?
ebeneezer wrote:I thought about a thrust washer. Where would the best place be to get one?
Thrust washers can be found at http://coxengines.ca/
or
http://www.exmodelengines.com/home.php?cat=250
Bernie and Matt are both are members here.
Thanks, I'll get some
I'd say go for it, 5x3 prop on backwards and running rich.ebeneezer wrote:Hi, I am planning to build an all balsa profile, 21 inch span, freeflight Gee Bee R1. (Ebeneezer)
Thanks.
If it need more power flip the proper over and lean it out.
Do not over fill the tank!
nitroairplane wrote:I'd say go for it, 5x3 prop on backwards and running rich.ebeneezer wrote:Hi, I am planning to build an all balsa profile, 21 inch span, freeflight Gee Bee R1. (Ebeneezer)
Thanks.
One problem I foresee, 5" dia prop + 4" dia cowl = 1/2" of effective prop! sorry, dat aint gonna fly, Man!
Ivanhoe- Diamond Member
Maybe with a 'normal' size firewall with 3 or 4 narrow struts to support the back edge of the cowl: airflow/thrust thru the inside of the cowl. Pseudo ducted fan. (patent pending.... )
ahrma_581- Gold Member
ahrma_581 wrote:Maybe with a 'normal' size firewall with 3 or 4 narrow struts to support the back edge of the cowl: airflow/thrust thru the inside of the cowl. Pseudo ducted fan. (patent pending.... )
Now, THAT'S an idea!!
OR...with a nod to Indra...a Diesel conversion, turning a larger prop....
Just a thought re- end play. Have you checked that the prop driver is properly seated on the shaft? you may be able to knock it back a little to take up some of the play
Wilf
Me again.
That front cowl/ducted fan idea sounds like an interesting idea. I 'm excited enough to want to try it.
I'll post some pics and flying report if anyone intrested. I just need to tissue cover my Slicker Mite first
Yes but imagine a (Roughly) 7oz plane with a 21" WS and a 7x4 doing 11k, corkscrew moment lol.Kim wrote:OR...with a nod to Indra...a Diesel conversion, turning a larger prop....
Well only one way to find out for sure.....
I mean depending it all depends on the final weight doesn't it?
Wilf:
This was talked aout in another thread involving a large cowl and eventually we figured it should work, I think it was Ron's Dumas build or something.
nitroairplane wrote:Yes but imagine a (Roughly) 7oz plane with a 21" WS and a 7x4 doing 11k, corkscrew moment lol.Kim wrote:OR...with a nod to Indra...a Diesel conversion, turning a larger prop....
Wilf:
Yeah it was mine. Except the Dumas Laird has a 24" span and two wings. It's stubby but, not as stubby as a GeeBee. Plus the vertical stab is a biggun.
I was tinkering with the idea of drilling holes through the back of the nose block area as well. Glad to know others have done or considered it so it's not some crazy hair-brained idea.
Wilf:
It was my build, and it does work, but not very well! But mine wasn't as extreme as a 4" cowl and a 5" prop! that gives you 1/2" of prop outside the cowl, and the least efficient bit of the prop as well.
Hi, me again. I've been routing through my Dads Cox spares, I've had his Cox engines. I've come across a diesel convertion or bits of one. What I have is a new barrel and anodised red head with a black knurled compression screw. There is also a piston down the barrel that seems very tight. Does it need some freeing oil and then, just pulling out? Do I just then just Change the head and piston on my 0.49 and run on ordinary diesel fule. Or is ther a lot more to it than that. If I can do it what size prop could I use?
first of all, soak the thing in fuel for about an hour or so.
then, gently try to pull that piston out of there (without the head being screwed on, otherwise it'll pull a vacuum )
if that doesnt work, carefully heat the outside of the cylinder up with a lighter, so the gummed up stuff loosens.
if you plan on running that thing, you should get a reenforced crank shaft (check bernies diesel/killer cranks), and then you should be just fine. fuel-wise, use a mixture of ether (obtainable through starter spray), gasoline, and castor oil.
welcome to the forum, mate
Beez
Beez
GermanBeez- Platinum Member
Thanks Bees I'll do that, I've never seen or heard a Cox diesel.
What size prop can I use?
Do I need a speacial tool to seperate the conrod from the crank shaft?
ebeneezer wrote:Thanks Bees I'll do that, I've never seen or heard a Cox diesel.
Over here Ebz you want Model Technics D1000.
Prop? ask Nitro I think he'll say 8X4
Once the head, cylinder and back plate are off the con rod just lifts away from the crank pin/big end.
If you don't have a cox wrench, get one.
If you don't pM me your addy and I'll stick one in the post.
John Goddard- Diamond Member
Pretty much any prop 6x3-8x4 just get a head and a HD crank.
Both available from Cox internationals website.
Then head to your local hobbystores and pick up some D1000 fuel.
It's a Gee Bee isn't it?
