What I've been doing... - Page 2 Cox_ba12
What I've been doing... - Page 2 Pixel
by 1975 control line guy Today at 7:29 pm
by GallopingGhostler Today at 7:10 pm
by GallopingGhostler Today at 7:07 pm
by LooseSpinner99 Today at 6:13 pm
by balogh Today at 5:08 pm
by rsv1cox Today at 3:44 pm
by Ken Cook Today at 2:54 pm
by 1/2A Nut Today at 10:34 am
by sosam117 Today at 8:15 am
by balogh Today at 7:42 am
What I've been doing... - Page 2 Empty
Page 2 of 2 Previous  1, 2
What I've been doing... - Page 2 Empty Re: What I've been doing...
Post  WingingIt74 Wed May 23, 2012 1:22 pm
At least you didn't say 33s Smile
WingingIt74
WingingIt74
Post  SuperDave Wed May 23, 2012 2:29 pm
Travis:
How does a SYE (slip yoke eliminator) function when the driveshaft goes over rough terrain? I would think the articulation would be greatly reduced if not eliminated.
SuperDave
SuperDave
Post  PV Pilot Wed May 23, 2012 2:30 pm
WingingIt74 wrote:At least you didn't say 33s Smile
Lol. Oh yeah, the sicko's that put on 33's also,, tongue Wink
PV Pilot
PV Pilot
High Tech Balsa Basher
Post  WingingIt74 Wed May 23, 2012 2:32 pm
SuperDave wrote:Travis:
You replace the stock drive shaft with a double cardin drive shaft. It has a double u-joint similar to a CV joint and the slip is on the shaft instead of on the yoke. This will greatly increase the articulation from stock. I also have to put on adjustable control arms and track bars.
WingingIt74
WingingIt74
Post  SuperDave Wed May 23, 2012 2:36 pm
So in essense, the slip-joint function isn't so much elimated as moved to a different location.
Thanks,
SuperDave
SuperDave
Post  WingingIt74 Wed May 23, 2012 2:40 pm
SuperDave wrote:So in essense, the slip-joint function isn't so much elimated as moved to a different location.
Thanks,
That would be correct, in a simple term. The DC drive shaft is capable of greater angles, which also means I can eliminate my transfer case drop and gain ground clearance.
WingingIt74
WingingIt74
Post  SuperDave Wed May 23, 2012 2:58 pm
Travis:
The reason I'm asking is that I helped my son build his '76 Jeep CJ-7 with 350 Chev/Turbo-Hydromatic 400 w/33" tires. The SJE must be a fairly new idea on the Jeep scene. We had the driveshafts cut and balanced to meet the application and he runs his Jeep at Moab, Utah to do some serious "crawlin'".
(I can't even watch him to do it!) What I've been doing... - Page 2 221949261
SuperDave
SuperDave
Post  WingingIt74 Wed May 23, 2012 3:01 pm
Depends on the transfer case. Mine is a NV231. We have mild stuff compared to out there.
I plan on swapping my puck lift for a 2.5" OME lift and doing a 1.5" body lift. With that I can raise my engine and transfer case and have a smooth skid plate for more ground clearance (ie: tummy tuck), instead of the hanging down stock skid plate. I really don't want larger then 33" tires.
WingingIt74
WingingIt74
Post  PV Pilot Thu May 24, 2012 1:00 pm
Tom Woods is the man to see for high angle or any angle driveshaft stuff. Used his services in the past. If you need some quick answers to driveshaft problems, give him a buzz. He can tell you all about proper angles of gear cases, ect, and the required pieces to make it all work and live. He does it for a living and is a plethora of info that you or me will never know.
http://www.4xshaft.com/
PV Pilot
PV Pilot
Post  WingingIt74 Thu May 24, 2012 1:05 pm
Both of my drive shafts are from him, I ordered them, just need to get him dimensions.
WingingIt74
WingingIt74
Post  WingingIt74 Sat Aug 04, 2012 10:48 pm
My buddy Charlie and I spent ~12 hours on it today and I am happy to say it's alive!!!
What I've been doing... - Page 2 25632910
WingingIt74
WingingIt74
Post  WingingIt74 Sun Aug 05, 2012 9:45 pm
Took the family out for dinner tonight Smile
What I've been doing... - Page 2 25181810
WingingIt74
WingingIt74
Post  WingingIt74 Sun Mar 31, 2013 8:06 pm
Finished up the rear axle swap ( Ford 8.8 ) and 3" Teraflex lift about 12pm today. T-case still bangs a little, but I'm not in the mood to drop it just yet.
Happy Easter!
What I've been doing... - Page 2 5565_10151299724785947_403526899_n
WingingIt74
WingingIt74
Post  WingingIt74 Fri Oct 11, 2013 6:59 pm
Checked out my max flex for the first time today Smile
What I've been doing... - Page 2 539622_10151609464595947_1446462393_n
What I've been doing... - Page 2 1375182_10151609464660947_1725801093_n
WingingIt74
WingingIt74
Post  pkrankow Fri Oct 11, 2013 7:37 pm
Maybe having too much fun?
I remember putting my boss' Miata on fork one day. (I used a skid to protect the under body.) She was amused. Not every day you get to mess with the boss' car and get away with it.
Post  WingingIt74 Wed Mar 19, 2014 9:47 pm
WingingIt74
WingingIt74
Post  Cribbs74 Wed Mar 19, 2014 9:56 pm
Well dang Travis, you are pretty good at that stuff. I thought you were going to high center on the banks. I also really respect the fact you are not afraid to wreck your Jeep. I see a lot of posers. You are not one of them.
Good job man! Greenie for you!
Post  Mark Boesen Wed Mar 19, 2014 11:29 pm
yep, I flipped you a greenie a well, pretty cool!
