Cox/Estes X Wing Canard CL Kit Cox_ba12
Cox/Estes X Wing Canard CL Kit Pixel
Cox/Estes X Wing Canard CL Kit Empty
Cox/Estes X Wing Canard CL Kit Empty Cox/Estes X Wing Canard CL Kit
Post  Godsey3.0 Thu Mar 29, 2012 8:17 pm
Just finished building my X Wing. I am curious though as to how it stays outside the circle. It has no wingtip weight and no actual rudder all together. The only thing I can imagine doing anything is that the outboard elevator is fixed in slightly down position. Will this be enough? I do not want this plane to be like my (once) tail heavy Lil Jumpin Bean and high five me in the circle.
Godsey3.0
Godsey3.0
Cox/Estes X Wing Canard CL Kit Empty Re: Cox/Estes X Wing Canard CL Kit
Post  dckrsn Thu Mar 29, 2012 8:49 pm
To answer none of your questions, here's this.
Cox/Estes X Wing Canard CL Kit X-wing10
There might have been some missing info in the instructions regarding faith.
Hope someone chimes in.
Bob bounce
Post  RknRusty Thu Mar 29, 2012 10:44 pm
The outboard side of the elevator being low sounds wrong to me if the engine runs as a conventional tractor. Have you held it between the nose and tail to see if it's heavy on the outside? Is it a pusher? Which way does the engine spin?
Post  Mark Boesen Thu Mar 29, 2012 11:30 pm
Godsey3.0 wrote:Just finished building my X Wing. I am curious though as to how it stays outside the circle. It has no wingtip weight and no actual rudder all together. The only thing I can imagine doing anything is that the outboard elevator is fixed in slightly down position. Will this be enough? I do not want this plane to be like my (once) tail heavy Lil Jumpin Bean and high five me in the circle.
Hi Godsey,
It's centrifugal force that keeps your lines tight, engine offset and rudder help (look at a combat ship) tip weight is used to help counter balance the weight/drag of the lines.
Mark
Post  Godsey3.0 Fri Mar 30, 2012 5:46 am
Rusty: The engine runs conventional and is a pusher.
Mudhen: Which way would I offset engine? To the outboard side?
Godsey3.0
Godsey3.0
Post  John Goddard Fri Mar 30, 2012 5:55 am
C'nard
Isn't that French for Extremely Very Happy Difficult ?
lol!
John Goddard
John Goddard
Post  microflitedude Fri Mar 30, 2012 5:59 am
I never had much luck with them. Probably because I couldn't balance it properly.
microflitedude
microflitedude
Post  nitroairplane Fri Mar 30, 2012 9:29 am
John Goddard wrote:C'nard
lol!
Oddly enough it means duck.
nitroairplane
nitroairplane
Post  RknRusty Fri Mar 30, 2012 10:45 am
Godsey3.0 wrote:Rusty: The engine runs conventional and is a pusher.
So it's pointed backwards and rotating in the conventional direction with a pusher prop. That means the torque is twisting to lift the inboard wing. Weighting the outboard wing would make that worse.. In that configuration you want the offset to be toward the outboard side. Think of driving a boat and outboard motor with just the handle on the motor. Think which way you point the prop to make the boat turn right.
Post  sdjjadk Mon Apr 09, 2012 5:41 pm
I built one back in 2000 and powered it with one of the weak running Estes series Black (Silver) Widows. It flew okay and looked really neat in the air. You'll want to put some engine offset in for sure! You'll want to the offset to the left (meaning if your looking at the airplane front to back, the prop will be offset to the left.) As far as wing tip weight goes, I don't remember using any.
Shawn
sdjjadk
sdjjadk
