» Retail price mark-up.. how much is enough?by rsv1cox Today at 1:23 pm
by 1/2A Nut Today at 11:34 am
by rdw777 Today at 11:04 am
by sosam117 Today at 9:15 am
by balogh Today at 8:42 am
by Coxfledgling Today at 5:46 am
by roddie Today at 1:32 am
by roddie Yesterday at 7:17 pm
by TD ABUSER Yesterday at 3:13 pm
by roddie Yesterday at 11:43 am
by roddie Fri Nov 22, 2024 2:13 pm
by rdw777 Fri Nov 22, 2024 10:24 am
Medallion 09 and 15 needle threads?
Anybody know what the actual needle thread is on a Medallion .09 and .15.....the supply of NVAs for these is almost non existent these days....and the Med 049/09 ones not a lot better.....yes you can find the needles...Matt has them....but the spraybars are several orders of magnitude scarcer than hen's teeth...!
It strikes me that if I knew the needle thread, I could machine up a few spraybars....its nothing particularly challenging...just tedious-assuming I can find a tap in the appropriate-no doubt fairly obscure-thread. For me the 15 size is a more pressing need than the 049/09 one.
And when I say tedious...do this little exercise...sit down with a piece of paper...draw a piece of hex brass stock and work out how many individual machining and threading operations it takes to convert that piece of hex brass into a spraybar ....it can be up to 16 or so, depending on the fine detail-not including any fixtures you may have to make...
Suggestions for a tap source-assuming someone knows the thread-are also welcome.
ChrisM
ffkiwi'
ChrisM
ffkiwi'
ffkiwi- Gold Member
Re: Medallion 09 and 15 needle threads?
ChrisM @ffkiwi , I don't know about the Medallion .15, but for the Medallion .09, Bernie already has the answer. I know this from earlier research, because I was considering installing my Medallion .09 in an aircraft where I needed a longer needle to pass through the cheek cowl. These I believe are the same needles on the Cox .049 Sure Starts. See:
https://coxengines.ca/back-end/cox--049-needle-valve-brass-long-3.html
Cox International wrote:Features:
Thread size : 2/80
Total length: 41.5 mm (1.6")
Includes matching spring
Brand new Original Cox itemsApplication:
Most Cox .049 reed valve engines with hoseshoe backplates
All Cox .049 Medallion engines
All Cox .09 Medallion engines
Well that's steer worth following up...on that basis the 15 thread might be something like a 3-80 or 4-80....and that led me to the HD Chasen Co-where they stock a lot of taps and dies in threads I'd never even heard of....a quick check of a Med .15 needle reveals the thread diameter to be 0.1095....so that makes it a slightly undersize #4 screw diameter...and they do offer 4-64 and 4-80 threads..not exactly cheap though-the taps $30+ and the corresponding die $60+ ......I'll explore other sources and see what's out there from other suppliers....
The hex size-on the spraybar is 3/16"-so that's an easy size to source....
ChrisM
'ffkiwi'
ChrisM
'ffkiwi'
ffkiwi- Gold Member
I have samples of both engines, and I have some pretty fine thread pitch gauges. I also have some antique micrometers so I can get a gentle check on external thread diameters. Sorry, I won't have any taps that fine so I can't verify beyond the above measures. Expect them in the next 36-48 hours.
No hurry Jim-this is a back burner project....
ChrisM
ChrisM
ffkiwi- Gold Member
Sorry that I don't have any bigger Medallions to check. I made a bunch of needles and spray bars for regular motors, some remotes. It was slow going, but I have a Hardinge turret lathe, so it combines a few operations to save time and keep the concentricity. State of the art in 1952. Anyway, I used M2 pushrods for the needle valve and just made the spray bars as needed. It took a split threaded collet to grab on to the pushrod thread and two plunge cuts to get the taper. I have tried a couple out and they seem to work OK, but have not put them on a plane yet. There is a long story to go with that....MAAC.... The only down side that I can see is that I noticed some rust after a while, likely because I rinsed a set with water, not fuel. I don't think that you would need to match the thread size and pitch of the original. Just use something that works. I think I somewhat copied a Rossi size or whatever I had lying around.
aspeed- Platinum Member
