» Consolidated half-A C/L Sonic Starby GallopingGhostler Today at 1:54 pm
by rdw777 Today at 1:52 pm
» Jim Walker Bonanza etc.
by rdw777 Today at 1:47 pm
» Betty Skelton
by roddie Today at 12:56 pm
by rsv1cox Today at 9:52 am
by roddie Today at 9:30 am
by roddie Today at 9:02 am
by TD ABUSER Today at 8:25 am
» 1940's?...............
by rsv1cox Today at 6:46 am
by akjgardner Today at 6:19 am
» Lesson learned
by TD ABUSER Yesterday at 5:22 pm
by GallopingGhostler Yesterday at 4:21 pm
August-2024
Rotating needle valve
In my quest for MORE power for the Old Timer I've now put a new td top end on it.
I'm going to take a little more time running this one in (at least 4 tanks Ha) but
the NV appears to be seeking a career of it's own so even if I wanted to lean it down
the blinking thing keeps rotating anti clockwise.
!, I'm counting my blessings it ain't going the other way.
2. What's the best way to make it stay put?
'Power M M Mad I tell ya' Johnnie
John Goddard- Diamond Member
Re: Rotating needle valve
Balance the prop!
Just kidding, either the spring is worn or the NV itself. That would be my guess
I always remove the spring and replace it with a washer and a short piece of silicon fuel tube, It keeps the needle from moving and it seals the inevitable air leak around the threads.
I use a thicker tube now. It lasts longer and seals better. Here it is in the background
Here it is with the needle closed
I wouldn't even run an engine with the spring. This is the only way to go. It will run much better without air trickling past the threads
John Goddard wrote:In my quest for MORE power for the Old Timer I've now put a new td top end on it.
yeah get rid of the spring for the needle valve, and replace it with a #4 washer and medium size fuel line as rknrusty suggested
mitchg95- Diamond Member
Great advice as always gents.
I'll balance prop just in case (engine's had less than 10 tanks so not old) and I'll Rustyise the needle
then report back.
Best
J
then report back.
Best
J
John Goddard wrote:Great advice as always gents.
then report back.
Best
J
i have done the needle valve+medium fuel line with good results, good luck
I have read that you should always run-in the engine with the prop and fuel you intend to primarily use in the field. I've found my engines don't like changing fuel.John Goddard wrote:Great advice as always gents.
then report back.
Best
J
» metal tank mount for the 049 td suggstion/ request
» TD .09 - Something interfering with the rotating assembly
» Contra vs Counter Rotating Props
» Need a needle valve
» Reed Valve
» Reed Valve
