» Engine choice
Fuel Mixing question
My LHS has 35% car fuel with a 9% oil content, how much castor should I add to make this fuel usable in?a Tee dee .049? A second question, what is the formula to calculate the additional amount so I can calculate the correct amount for a different blend if necessary
fargophil- Bronze Member
Re: Fuel Mixing question
kevin king- Silver Member
crankbndr- Top Poster
The fuel blend mixtures for Cox engines are here:
https://coxengines.ca/engine-and-fuel-guides.html
A really good fuel/oil calculator is available that allows for mixing two fuels, and takes into account synthetic/castor blends. Play the calculator with only one fuel by using the same numbers in both fuel "spots." I'll let the webpage guide you:
http://web2.murraystate.edu/andy.batts/ps/fuel.htm
fargophil wrote:My LHS has 35% car fuel with a 9% oil content, how much castor should I add to make this fuel usable in?a Tee dee .049? A second question, what is the formula to calculate the additional amount so I can calculate the correct amount for a different blend if necessary
I like this calculator. Simple to understand.
http://www.nitrorc.com/default2.asp?Introduction=http://www.nitrorc.com/fuelws/
Levent Suberk- Diamond Member
» Widow Fuel Mixing Question
» Fuel mixing
» Mixing 15% and 35% Glowplugboy fuel
» mixing fuel for these engines
» Question on fuel.......
» Fuel mixing
