About Oils I Used in Engines Cox_ba12
About Oils I Used in Engines Pixel
by batjac Today at 10:05 pm
by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
About Oils I Used in Engines Empty
About Oils I Used in Engines Empty About Oils I Used in Engines
Post  Levent Suberk Sun Oct 24, 2021 7:22 am
My experiences about several kinds of oils:
It is clear that oiler-cleaner-antirust kind of oils attack rubber gaskets and plastic parts on Cox engines other than Delrin.
I think that only 100% silicone oil is safe as after run oil for rubber gaskets and all plastic parts including Delrin for a long time storage. But because silicone oil softens silicone fuel lines, then remove any silicone fuel line on engine before storage. I didn't see any attack on vinyl fuel lines by using silicone oil after a long term.
100% mineral oil (sewing machine oil) can also be used for a long time storage excluding polypropylene (PP) and rubber gasket parts. I experienced that sewing machine oil oozed and attacked a small toolbox made from PP. It softened and caused a bulge on toolbox after several months.
Using ordinary petroleum grease is a disaster for nylon and most other plastic parts. Petroleum grease attacks most plastics including Delrin and break them. Silicone grease is OK for all kind of plastics other than silicone fuel lines as mentioned at above.
About Oils I Used in Engines Empty Re: About Oils I Used in Engines
Post  Cribbs74 Sun Oct 24, 2021 5:21 pm
Well shoot, if you just used them every day you wouldn’t need after run oil! Very Happy
Post  Lukemiester Sun Oct 24, 2021 6:07 pm
i use ACF-50 samples as after run oil. they're free, they're small, my dad has a ton of em, and acf-50 fits the description of after run oil well- its a rust protecting oil.
Lukemiester
Lukemiester
Post  ffkiwi Tue Oct 26, 2021 3:52 pm
ATF = automatic transmission fluid is a good after run and long term storage lubricant for model engines....its biggest advantage seems to be its lack of any tendency to dry out or congeal with long term storage of the engine-I've seen engines stored for over 2 decades with ATF, still be loose and quite 'normal' when removed from storage and turned over with a prop on.
ChrisM
'ffkiwi'
ffkiwi
ffkiwi
Post  Levent Suberk Tue Oct 26, 2021 6:00 pm
Thanks. I didn't try ATF for a long time storage. ATF has too much ingredients if I am not wrong. I couldn't find a reference about ATF is compatible with rubber and delrin. But because you say that it is safe to use, then there's no problem Very Happy
Post  NEW222 Tue Oct 26, 2021 6:23 pm
Well, another great topic that can bring up a good debate! As I know and also trust ffkiwi, and would believe him, levent brings up an absolutely good point that I had not ever thought about before. I had also read that there is proper ATF to use, and one not recommended. As I type, I cannot look this up. Very Happy But regardless, of which type, the great point levent had brought up is the compatability with rubber and delrin. Rubber I am not so worried about, but the delrin had me thinking. Back a long time ago, I had crock-potted a postage stamp engine, backplate too........ It got all white and hazy and brittle after its bath. I had dared NOT try this ever again, even with regular antifreeze unheated and see if it was due to antifreeze in general, or was it heated antifreeze that caused this? Hence why I may be a bit aprehensive of using ATF in a Cox engine, but only any having any delrin parts. A standard Bee, or any variant thereof, I may try it one day. But as of now, I have just started to use air tool oil, and it already has me liking it better than the 3-in-1 I had been using till now.
Post  ffkiwi Tue Oct 26, 2021 6:29 pm
I suspect there is quite a variation in ATF blends and components across the world....much like brake fluid-what is available where you are might differ significantly from what I use here.  All I can say is that I've had no trouble with it-nor the others I know of who suggested I try it as an engine preservative for long term storage. There is some anecdotal stories that glows can be a little hard to start after storage on it if the ATF is not flushed out before attempting to start-but I mainly use it on diesels in any case-which are especially prone to gumming up over time-and it doesn't worry them...in fact give them a quick quirt of CRC 5-56 after storage and they quite often fire on it when you flick them over-and run in you hand for about a second or two-before seeing any normal diesel fuel.
ChrisM
'ffkiwi'
PS others elsewhere swear by gun oil....a lot depends on what you have sitting around available I imagine-air tool oil mentioned by new222 above also has its adherents-others I know-with aviation connections swear by turbine oil
ffkiwi
ffkiwi
Post  ffkiwi Tue Oct 26, 2021 6:40 pm
NEW222 wrote:Well, another great topic that can bring up a good debate! As I know and also trust ffkiwi, and would believe him, levent brings up an absolutely good point that I had not ever thought about before. I had also read that there is proper ATF to use, and one not recommended. As I type, I cannot look this up. Very Happy But regardless, of which type, the great point levent had brought up is the compatability with rubber and delrin. Rubber I am not so worried about, but the delrin had me thinking. Back a long time ago, I had crock-potted a postage stamp engine, backplate too........ It got all white and hazy and brittle after its bath. I had dared NOT try this ever again, even with regular antifreeze unheated and see if it was due to antifreeze in general, or was it heated antifreeze that caused this? Hence why I may be a bit aprehensive of using ATF in a Cox engine, but only any having any delrin parts. A standard Bee, or any variant thereof, I may try it one day. But as of now, I have just started to use air tool oil, and it already has me liking it better than the 3-in-1 I had been using till now.
A further point arising from new222's post-I am not entirely convinced that Coxes DO use Delrin for the plastic parts-Delrin (and I use the stuff extensively in my modelling) has excellent machining properties and is generally tolerant to hydrocarbons, solvents and neutral chemicals. Secondly it is normally supplied in rod and sheet form only-not generally moulded-and AFAIK is only available in natural 'off white' and in black. I think the material used in Cox engines is closer to a modified nylon than Delrin-which is an acetal polymer.
That being said-there is no doubt that the plastic used in Coxes is susceptible to ageing in use-and perhaps accelerated ageing as a result of some solvents...eg glycol. This might be the time-if anyone has any broken or 'past usable service' plastic components ex Coxes...to do a bit of experimenting vis a vis ATF, etc
ChrisM
'ffkiwi'
ffkiwi
ffkiwi
Post  Levent Suberk Wed Oct 27, 2021 5:31 am
I read somewhere that some Cox plastic parts are moulded delrin. Perhaps some of them are moulded nylon or another kind of plastic. Once I tried to mend a red plastic fuel tank with soldering iron but it didn't melt and smelled bad. So I think that it is made from delrin.
Post  ffkiwi Wed Oct 27, 2021 5:40 am
Levent Suberk wrote:I read somewhere that some Cox plastic parts are moulded delrin. Perhaps some of them are moulded nylon or another kind of plastic. Once I tried to mend a red plastic fuel tank with soldering iron but it didn't melt and smelled bad. So I think that it is made from delrin.
Yes I've read that too-but it was written a long time back-the early 60s IIRC...and I suspect the writer had no familiarity with the feel and texture of real Delrin then. Unless I hear to the contrary from someone who actually worked at Cox, and was in a position to know exactly what plastic WAS used, I'm continuing with the view that whatever the plastic used by Cox for mouldings on the TD series and other Cox engines was, it wasn't Delrin...
ChrisM
'ffkiwi'
ffkiwi
ffkiwi
