Cox powered ultimate bip new .15 engine Cox_ba12
Cox powered ultimate bip new .15 engine Pixel
Cox powered ultimate bip new .15 engine Empty
Cox powered ultimate bip new .15 engine Empty Cox powered ultimate bip new .15 engine
Post  davidll1984 Thu Oct 29, 2020 6:04 am
M'y engine nead piston conecting rod reset after long time now is time To get him back To work plane ready for winter flight tink of using tee dee .15 in future as the plane is under powered wit its old engineCox powered ultimate bip new .15 engine 16039610
Cox powered ultimate bip new .15 engine Empty Re: Cox powered ultimate bip new .15 engine
Post  getback Thu Oct 29, 2020 6:16 am
Dust her off ready for the snow it is ? Cold
Post  NEW222 Thu Oct 29, 2020 6:46 am
I keep saying ill fly in winter, but have yet to brave it! Snow here, but saying Temps will be in the 50's and low 60's early next week.
Post  davidll1984 Thu Oct 29, 2020 2:31 pm
Engines ready for winter Cox powered ultimate bip new .15 engine 16039910
Post  roddie Thu Oct 29, 2020 3:47 pm
Hi David, What is the wingspan measurement on that model? Was the model a kit or built from plans? What brand/size is the engine that you're replacing?
Post  roddie Thu Oct 29, 2020 4:23 pm
.. also.. the skis look nice. Do you have a close-up image of them? I have made pairs of 1/2A size snow skis of my own design using .010" aluminum sheet for the ski and a shock absorbing craft-stick design for the binding to the strut.
Post  davidll1984 Thu Oct 29, 2020 7:22 pm
M'y plane wing size mesurent 33.5 in 850mm fuselage lenght 37 in 935 mm powered wit .15 rc modified sportsman it weight 824 g To hevy for its power for wing ok ring is like 32 \ 36 g\dm2 y tink of over size its wing Not the tail
Post  davidll1984 Thu Oct 29, 2020 7:25 pm
Ski buy in hobby shop like 10 years from now is made of lexan sort of light plastiques tink it work fine tink was for 450 traîner of som sort
Post  getback Fri Oct 30, 2020 7:15 am
NEW222 wrote:I keep saying ill fly in winter, but have yet to brave it! Snow here, but saying Temps will be in the 50's and low 60's early next week.
That weather should not bee a problem for you with the lows y'all get Leaves
Post  davidll1984 Fri Oct 30, 2020 11:30 am
Snow alredy in Québec look Smile Cox powered ultimate bip new .15 engine 16040710
Post  roddie Fri Oct 30, 2020 5:57 pm
Thank you for the information on your model. Thumbs Up Here are some photos of my skis.
Cox powered ultimate bip new .15 engine Skis-110
Cox powered ultimate bip new .15 engine Skis-w10
Cox powered ultimate bip new .15 engine Skis-111
Cox powered ultimate bip new .15 engine Dsc02414
Post  modelbuilder49 Sat Oct 31, 2020 1:07 pm
What the heck is that stuff on your plane and your car? Dandruff?? Soot from the CALI fires??? lol! lol!
modelbuilder49
modelbuilder49
Post  OhBee Sat Oct 31, 2020 10:03 pm
We've had that white sh...tuff 3 times already here in Mn! Warmed up some and finally all melted.....not a fan!
OhBee
OhBee
Post  davidll1984 Sun Nov 01, 2020 6:16 am
Is it hard To take of on Snow wit control Line plane ??
Post  davidll1984 Wed Nov 04, 2020 10:37 am
After litle test wit engine tink of change engine for Good performance of that modèle sur m'y engine is Good runer just tink m'y plane need power like if 13000 rpm of m'y old sportsman Not enough for god expérience of flight dont want To batle wit the plane To berly fly
Post  davidll1984 Wed Nov 04, 2020 11:01 am
Y just did modification To m'y enya .15 , carburateur from ae .15 cars engine Cox powered ultimate bip new .15 engine 16045011
Cox powered ultimate bip new .15 engine 16045010
Engine setup upgrades parts os tuned pipe carb from team ae cars .15 engine ventury modification To fit carb carburateur is also machined To fit y have To dril and tap hole for Bolt and its done dont no how engine wil react To new spec size ventury carb is very precise part now can adjust both low hi fuel mixture wit hope for insane power from him tink of change its piston and sleve wit os parts if it fits inside like wit m'y fraken.35 enya maxs os mixed engines modification very powerful use boat carburateur os.35 plane engine part cant remember Witch part was used y made him like 17 years from now hard To remember Witch part used for. The two engines parted wit
Post  davidll1984 Wed Nov 04, 2020 11:23 am
Comparaison of plane and cars carburator size venturyCox powered ultimate bip new .15 engine 16045111
Cox powered ultimate bip new .15 engine 16045110
Intake port very similar wit first look.. on inside port big change in size y dont have test engine yet wit fix on a .15 plane for testing
Post  Surfer_kris Wed Nov 04, 2020 2:18 pm
It is not only the the intake and ventury area that matters...
The air/fuel mixture also has to travel through the crank and up via the transfer ports.
Modern car engines in general have larger crank diameter and larger crank bore, compared to old-school airplane engines. They were/are designed to work at lower rpms and do not need or even benefit a large venturi diameter.
Surfer_kris
Surfer_kris
Post  davidll1984 Wed Nov 04, 2020 3:33 pm
Hum Not agree wit if look at spécifiques engine os .15 la rc engine and enya .15 ||| cl is Not big différence wit both ae cars engine Not mutch To Cox powered ultimate bip new .15 engine 16045210
Post  davidll1984 Wed Nov 04, 2020 4:15 pm
M'y previous test wit same type engines giving very Good result using os .32 marine carburateur on enya .35 modified with os part engines in m'y test y find the casing of both engines is very close excep Front and lower casing sleeve lenght and porting very litle difrent but never y was tinking of get that mutch power of that old engine at the time just wanted Good rc engine ending wit a insane rpm gain Not power To run larger prop just huge gain in rpm no exact rpm number now at the time no tool for rpm reading sound like over way over 28000 now y have tach wil try in future Not now engines is in crashed plane nead fix engine is Not damaged from the crash just never use from that time like 16 years from now y used engine only once crashed first flight wel je just hard landing riped of m'y weels nose litle its prop intact plane ended part donor for servo Reciver
Post  davidll1984 Thu Nov 05, 2020 8:52 am
Litle work brain storming on new setup look like engine fit Cox powered ultimate bip new .15 engine 16045812
Post  davidll1984 Thu Nov 05, 2020 8:58 am
Y have To tink of next step To take build new engine mount weight engines wit plane look for cg hope Not To heavy
Post  davidll1984 Tue Nov 10, 2020 10:50 am
Ok Good new m'y enya engine compare To its oem spec ventury now performance is very close To enya ss.15 bb tn sound very hi rpm for old schnurled port .15 engine y dont tach rpm m'y tach meter batry dead engine can run slow To very hi rpm in second respond very fast test on 8x4 nilon prop y have To change for bether one that is Not flexibles engines lost track prop flex To mutch for people ho tink oversize Intake did noting wil tach m'y engine take picturs of reading and no y dont change timing on m'y engine just air flow dynamique inside very litle To internal its the carburateur giving better air fuel ratio result gain of rpm over size Intake without carb its Not Good e engine can become very hard To tune and start tuned pipe help get gain in rpm
