by roddie Today at 9:22 pm
by rsv1cox Today at 3:38 pm
Thermal Hopper twin needle
Hi all, i'm Francesco, from Italy, i'm collecting cox engines after found a medallion 0.9 in a box sleeping by 25yrs
i just bought this beauty thermal hopper, good conditions, good compression, probably polished by seller or prev owner, i try to start it, but it does few fires and not runs...i opened it to clean and i didn't found any gasket between cranckcase and rear plate and reed valve not close good.
- someone knows as disassembly reed valve? it is locked
- someone can do a picture of it in good condition?i would check if mine is damaged or flexed or other
- someone has a wrench / prop/ rear bid cage or other parts unuseful to sell?
thanks in advance for all your helps and sorry for my poor english
Cescoturbo- Bronze Member
Re: Thermal Hopper twin needle
Hello Francesco! Welcome to the Forum !! The reeds you speak of are no longer available , bee very careful not to fold these .. but the gaskets are https://coxengines.ca/cox-.049-thermal-hopper-space-bug-jr.-crankcase-gasket-2.html You have a bad air leak with out them and is most likly your problem .. From the instructions sheets to the left <<<< https://dbabd7f0-a-62cb3a1a-s-sites.googlegroups.com/site/nitroengine/Thermal%20Hopper.pdf?attachauth=ANoY7cr9l4U-vptMXMD4HNZXZ0vulbgYtF4VXL0VC3HVqfOcL8rwTsmW_7bcv4kVgkMl3nSFsPOlUVia8-vHvgd66ZkFdUzGR6n1UAORib8hcVwqD6hf3fqqv6Qc57EEPB4blK03UQXMfl_wcQjjoaBh_MnITWLgqGsDlYRoz_LGaw3K-XtfnmbGg2-zMchfpncHlGEDR8TqQW3HcENDFf-yfe01SZogIw%3D%3D&attredirects=0 There is more info here i will see if i can find it in a few min.s
More of the same reed setup .. https://www.coxengineforum.com/t8967-space-bug-jr-question?highlight=space+bug+jr
getback wrote:More of the same reed setup .. https://www.coxengineforum.com/t8967-space-bug-jr-question?highlight=space+bug+jr
wow thanks, i tought in was a monolitic part with reedle retained by a locked plate..
Wow that is pretty dirty looking , but not stuck ! The thin reed goes in First then second reed , Top retainer (note slot ) MAKE SURE THE RETAINER FITS SNUG if not when running it will come off and destroy it
yep, i have a doubt about shape retainer, i hope nobody mod it before, blowing inside inlet with my mouth not easy to flow, reversing it close.getback wrote:Wow that is pretty dirty looking , but not stuck ! The thin reed goes in First then second reed , Top retainer (note slot ) MAKE SURE THE RETAINER FITS SNUG if not when running it will come off and destroy it
another quick info...how set twin needle?? and why twin lool, better spray? inside they are the same
The Bird Cage are found now and then for sale but U have to bee patience https://www.ebay.com/itm/NEW-IN-BOX-COX-049-THERMAL-HOPPER-MOUNT-MODEL-AIRPLANE-ENGINE-THIMBLE-DROME/383417419829?hash=item5945758835:g:VFwAAOSwUrxeQ15m Usaually 20-25 US dollar New
getback wrote:The Bird Cage are found now and then for sale but U have to bee patience https://www.ebay.com/itm/NEW-IN-BOX-COX-049-THERMAL-HOPPER-MOUNT-MODEL-AIRPLANE-ENGINE-THIMBLE-DROME/383417419829?hash=item5945758835:g:VFwAAOSwUrxeQ15m Usaually 20-25 US dollar New
are you the ebay seller you link?... wow td 0,010 in bid from 96dollars.... here +200dollar for new one...
i'm following also space hopper <3
i got it!!
https://vod.ebay.it/vod/FetchOrderDetails?itemid=274285414594&transid=2256873783017&ul_noapp=true
» engine wanted - twin screw Thermal Hopper
» Thermal Hopper Question.
» Space Hopper .049/Thermal Hopper .049
» Thermal Hopper
» Dreamer....
» Thermal Hopper
» Dreamer....
