Will a pee wee .020 run decent on a bladder? Cox_ba12
Will a pee wee .020 run decent on a bladder? Pixel
by batjac Today at 10:05 pm
by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
Will a pee wee .020 run decent on a bladder? Empty
Will a pee wee .020 run decent on a bladder? Empty Will a pee wee .020 run decent on a bladder?
Post  wmazz Mon Feb 25, 2019 10:44 pm
I am concerned about using the stock fuel tank with a short fuel
pick-up hose to limit run time.
The model is a Sniffer, which may as well be a Pee Wee 30 FF.
Normally they would use a small glass eye-dropper as a fuel
tank. But recently I saw a Sniffer photograph using a bladder.
Unfortunately using the stock tank with the short pick-up hose
creates a problem filling the tank and adjusting the needle because
it is too close to the windshield.
Is a bladder too much fuel pressure for a reed-valved engine?
Thanks
Bill M.
wmazz
wmazz
Bronze Member
Bronze Member
Will a pee wee .020 run decent on a bladder? Empty Re: Will a pee wee .020 run decent on a bladder?
Post  Cribbs74 Mon Feb 25, 2019 11:17 pm
Bill,
It’s all about the needle. Fine threads work well on pressure and standard threads do not. In your application You may have some trouble.
Some interesting things have been happening lately that would really enhance the .020
Most notably the .020 product backplates that would allow a fine thread needle.
For now your best bet would be a TD .020 with a KK needle.
Post  ticomareado Tue Feb 26, 2019 7:22 am
A Pee Wee will run fine with a drilled out tank plumbed to an external tank on suction. On the Sniffer you could install a large tank inside nose for long R/C runs and you can also provide an external mount on side of fuselage for an eyedropper for short test flights and/or F/F work.
ticomareado
ticomareado
Account Under Review
Post  balogh Tue Feb 26, 2019 5:07 pm
Try using a balloon if the pressurized fuel supply from a bladder is not a must. I fly R/C and all my COX engines in the 010...09 size range are fed from balloons (simple party balloons sold in toyshops). Resistant to nitro fuel. Light.No need for vent pipe and heavy clunk inside the tank, no foaming, no bubbles in the feedline. Cheap and reliable.
Post  wmazz Tue Feb 26, 2019 5:10 pm
Any idea on how long a eye-dropper will run for?
Was there a special .020 needle, or was it just a modified KK .049 128tpi needle?
Can a Pee Wee back-plate be modified to fit a 128tpi needle?
Thanks
Bill M.
wmazz
wmazz
Bronze Member
Bronze Member
Post  ticomareado Tue Feb 26, 2019 5:49 pm
An eye dropperful with about 4 to 5 inches of fuel line ought to go from 35 to 50 seconds on a Pee Wee. I have a Dakota FF with a cox .049 single port horseshow that will run about 25 to 30 seconds on 12 ml eyedropperful with out 4 inches of fuel line. I never launch it full however.
ticomareado
ticomareado
