Muffler/pipe for TD, Medallion controlline use ??  Cox_ba12
Muffler/pipe for TD, Medallion controlline use ??  Pixel
by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
Muffler/pipe for TD, Medallion controlline use ??  Empty
Muffler/pipe for TD, Medallion controlline use ??  Empty Muffler/pipe for TD, Medallion controlline use ??
Post  beachfv14 Mon Feb 18, 2019 12:48 pm
Hi, I am modifying a few TD,s for use in competitive
1/2A C/L stunt, contest use.
I'm still experimenting with different piston/cylinder combos and test running with different heads and fuels..
I want to install the finished engine in a rather large full fuselage 1/2A stunt plane.
My question is what type of Muffler/pipe is available too direct exhaust flow outside of an enclosed fuselage??
Has anyone had experience with this ?
I am more concerned with diverting exhaust and oil residue away than reducing noise..
anything available,??
Thanks, Tom
beachfv14
beachfv14
New Member
New Member
Muffler/pipe for TD, Medallion controlline use ??  Empty Re: Muffler/pipe for TD, Medallion controlline use ??
Post  balogh Mon Feb 18, 2019 1:56 pm
Hi Tom welcome to the forum. I also wanted to control castor splashed on the fuselage and used this COX muffler with a silicone extension.
Muffler/pipe for TD, Medallion controlline use ??  15505110
This is not fully castor-tight and will allow some castor to make it to the engine cowl but keeps away at least 90% of what an unmuffled TD would dump on the fuselage. You may improve it with thin 13mm orings added to the neck of a stepped wall cylinder and on top of the black annulus ring on the muffler top. Also wrap the sliding ring of the muffler in sylicon tape used by plumbers to diminish leakage through the muffler door covered by the slide ring..unfortunately this muffler is a performance robber on SPI cylinders.
Post  Ken Cook Mon Feb 18, 2019 3:55 pm
Tom, are you a member of the H.A.M.S club?
Post  beachfv14 Mon Feb 18, 2019 4:33 pm
I started the HAMS club,,
But because I objected to the way the treasury was being deleted for Combat contests. that brought No income...
Imwas voted out... It is Now a Combat club...
beachfv14
beachfv14
New Member
New Member
Post  beachfv14 Mon Feb 18, 2019 4:36 pm
Thanks for your reply,, I will pass it on to my friend who has purchased a Similar, But aftermarket muffler.
Tom
beachfv14
beachfv14
New Member
New Member
Post  aspeed Mon Feb 18, 2019 8:07 pm
A number of years ago there was a simple piece of silicone tubing with a hole punched in the middle that was a tight fit over the cylinder exhaust ports. I think Ace made it. It was just a bit bigger diameter than the base of the cylinder, maybe 5/8" ID thin wall tube. You could squash or plug the ends to muffle a bit. It was probably a couple inches long.
aspeed
aspeed
Post  getback Tue Feb 19, 2019 7:08 am
wElcome to the Forum Tom !! There are some pipes and other stuff in the making for this year some things as in mounts are available now ck this thread out you may want to skip around some its long but worth the interest say page 16 ... https://www.coxengineforum.com/t9540p375-cox-01-02-05-engines-mods-nano-speed-planes?highlight=1+2a+engine+mods Small Cox Logo
