» Happy 77th birthday Andrew!by GallopingGhostler Today at 8:10 pm
by GallopingGhostler Today at 8:07 pm
by LooseSpinner99 Today at 7:13 pm
by balogh Today at 6:08 pm
by rsv1cox Today at 4:44 pm
by Ken Cook Today at 3:54 pm
by 1/2A Nut Today at 11:34 am
by sosam117 Today at 9:15 am
by balogh Today at 8:42 am
by roddie Today at 1:32 am
by roddie Yesterday at 7:17 pm
by roddie Yesterday at 11:43 am
TD .010 first run
TD .010 first run
Well I did it, I fired up the little Tee Dee, I didn't really want too but I was kind obligated to do so *Shrugs* Either way she fired right up with no problems. The only issue I had was the tank which had a crack that was in between the crankcase and the face of the tank (the sealing area) that branched out from one of the bolt holes this was due to the tank being removed and reinstalled too tight by the previous owner. I tore it down then cleaned the tank real good and wicked in some Testors liquid plastic weld for plastic model cars from the inside to try and hide the repair and it worked!! no leaks!! So here's the video which also includes a little info session on starting these little guys for those who never have run one so off to tick the giant gnat off. enjoy!! (Bandit)
Fuel: Sig Champion 25% with castor added
Prop: Cox 3x1 1/4
Temp at test time: 92F
Relative humidity: 72%
I've got Windows 10 along with new browsers so I've been having issues with videos posting properly and it appears that this vid is no different, don't know if it's just my end but just in case it isn't Here's a direct link to the vid.
https://www.youtube.com/watch?v=NqYa_bHcKko&feature=youtu.be
Prop: Cox 3x1 1/4
TDbandit- Platinum Member
Re: TD .010 first run
What big fingers you have Sounded good for a first run and started easily for you Thanks TD bandit !! Eric
Yup kinda shows how tiny it is even sounds tinygetback wrote:What big fingers you have Sounded good for a first run and started easily for you Thanks TD bandit !! Eric
Glad my fix worked i was kinda worried about the crack. They are easy to start as long as you use a little common sense
Anyway glad you liked the video!
(Bandit)
Yea I for got to say that was a good deal with the plastic Testor Cement , Have to make a metal note for laterTDbandit wrote:Yup kinda shows how tiny it is even sounds tinygetback wrote:What big fingers you have Sounded good for a first run and started easily for you Thanks TD bandit !! Eric
(Bandit)
Yup it supprized me on how well it worked out. BTW my new set of lines came in and since you asked about how I do my crimps I'll post up a video or some pics for ya when I get to making them up which will be in the next day or so:)getback wrote:Yea I for got to say that was a good deal with the plastic Testor Cement , Have to make a metal note for laterTDbandit wrote:Yup kinda shows how tiny it is even sounds tinygetback wrote:What big fingers you have Sounded good for a first run and started easily for you Thanks TD bandit !! Eric
(Bandit)
(Bandit)
I enjoyed that .010 run Bandit. Last time I heard one was in my back yard in Florida probably 15 years ago. Sounds the same. Wait until you lean it out though. The local bumble bees may try to mate with it.
I'm trying to think if that's the engine that traced scars across my wrist discussed previously here on our Cox war wounds thread.
Also that's a great engine stand!!!!
Nice run bandit, I enjoy wathing your engine runs.My wife says "whats so fun about watching an engine run."..I said " I dont Know but it is"... I guess that falls under the simpler things in life category Huh ? anyway thanks for sharing
akjgardner- Diamond Member
Hey, thanks for that Bandit. Thoroughly enjoyable video. +
Makes me wanna break out my late(black/ bare) version, and put
some fuel and a glow clip to it.
dckrsn- Diamond Member
Ran nice! I have to get the Worlds Smallest Traveling Engine running sometime in the next few days. I guess it hasn't been run yet since Jason got it.
Admin wrote:Ran nice! I have to get the Worlds Smallest Traveling Engine running sometime in the next few days. I guess it hasn't been run yet since Jason got it.
Wanted to get it out to you so the other stuff could be created for the TE II. It will come back to me to run and sign the card. It should run. Each engine I get is fully disassembled down to each individual part and cleaned. If it needs any parts they are replaced at that time.
Jason_WI- Top Poster
Jason_WI wrote:Admin wrote:Ran nice! I have to get the Worlds Smallest Traveling Engine running sometime in the next few days. I guess it hasn't been run yet since Jason got it.
Oh, I'm sure it'll run!
(Bandit) Be looking fore ward to it man Thanks , Eric
