.049 motor difference  Cox_ba12
.049 motor difference  Pixel
by Admin Today at 1:35 am
» Engine choice
.049 motor difference  Empty
Help! .049 motor difference
Post  reptile Sun Jun 09, 2013 9:40 am
Hi anyone know what the difference is between the cox car motors that have the cylinder with the two big open slots on each side or the ones with the 2 slits on each side?
thanks
reptile
reptile
Help! Re: .049 motor difference
Post  SuperDave Sun Jun 09, 2013 10:12 am
It has to do with the way cylinders are configured interally.
See the references at: Cox Cylinder Identification on forum header.
SD
SuperDave
SuperDave
Post  RknRusty Sun Jun 09, 2013 10:30 am
The later cylinders on all Cox .049s were made with the slits instead of the open exhaust ports. These are actually more aggressively ported internally and the slits are a fire prevention measure. The slits don't seem to inhibit performance much, if any, because the old style ports were extremely oversized for the job. The new type exhaust ports are all the same height, whereas the old ones had a lower height on the high performance ones to create an SPI gap at TDC. With the slit ones, SPI is achieved by way of a short piston skirt. If you have a slit cylinder with SPI, you'll see the gap under the skirt at TDC through the bottom slit.
Post  reptile Sun Jun 09, 2013 11:00 am
RknRusty wrote:The later cylinders on all Cox .049s were made with the slits instead of the open exhaust ports. These are actually more aggressively ported internally and the slits are a fire prevention measure. The slits don't seem to inhibit performance much, if any, because the old style ports were extremely oversized for the job. The new type exhaust ports are all the same height, whereas the old ones had a lower height on the high performance ones to create an SPI gap at TDC. With the slit ones, SPI is achieved by way of a short piston skirt. If you have a slit cylinder with SPI, you'll see the gap under the skirt at TDC through the bottom slit.
O ok.
so it's safe to use a exhaust on the newer 2 slit models then?
reptile
reptile
Post  fredvon4 Sun Jun 09, 2013 12:12 pm
Safe?...Yes
Hurt performance? Maybe
Better to marry up a exhaust collector / muffler with a NON SPI cylinder piston set for max RPM and Torque in my opinion
The Sub Piston Induction (SPI) is intended to introduce a final fill of fresh air to the crank case as the bottom of the raising piston un-shrouds the exhaust port
When a exhaust collector, or muffler is surrounding the exhaust ports with SPI, the final fill to the crank case is now hot oily exhaust instead of fresh air
So far this is Theoretical for me as the few SPI engines I test ran with and without the car exhaust collector Bernie sells needled and sounded the same to me... I don't fuss with a tachometer on my little engines, so I can not say if or if not there is a RPM drop... I suspect in the air the torque and RPM would be lesser for this combination
Post  pkrankow Sun Jun 09, 2013 5:46 pm
The 2 slit ones are more likely to have no SPI (Sub-Piston Induction) so they will potentially perform better than the one that is milled out with SPI...if you are buying new.
To check for SPI hold the engine up to a "strong" light source (don't hurt yourself) when you slowly rotate the engine through look through the exhaust ports, specifically the bottom slit. If light passes at top dead center the engine has some SPI. No light, no SPI.
Post  reptile Sun Jun 09, 2013 6:28 pm
Thanks guy's very helpful. Very Happy
so all the 2 slit models are no spi and the ones with one large opening are spi models?
reptile
reptile
Post  reptile Sun Jun 09, 2013 7:20 pm
well just looked at 2 motors and the big single slot version seems to only have one port inside the sleeve and the 2 small slit cylinder has 2 of the ports each the same size as in the one big slot cylinders.
so the 2 slit version seems to be s better ported motor from my experience with modern day nitro motors in rc's.
reptile
reptile
Post  pkrankow Sun Jun 09, 2013 7:52 pm
reptile wrote:Thanks guy's very helpful. Very Happy
no.
Sure start motors were built to NOT have SPI, however manufacturing tolerances being as they are some have SPI and some do not.
If the lower slit is wider than the upper slit the cylinder is probably machined to have SPI.
Post  RknRusty Sun Jun 09, 2013 8:37 pm
There have been some slit cylinders that are different, like the pre-Estes Killer Bee. Surestarts are the most common and are the ones Bernie sells and they are all the same. Any Surestart slit cylinder can have SPI if you use an SPI piston, i.e. a short skirted piston. Look at the slit cylinder/piston sets Bernie sells, and you have the SPI or non-SPI option. Only the piston is different. And just because older ones have wide un-slit ports doesn't mean it's SPI. Re-read my earlier post; it depends on the height of the exhaust port. The position of the bottom of the port is slightly lower in the cylinder so the piston skirt rises above it at TDC opening the SPI gap.
Post  RknRusty Sun Jun 09, 2013 8:41 pm
reptile wrote:well just looked at 2 motors and the big single slot version seems to only have one port inside the sleeve and the 2 small slit cylinder has 2 of the ports each the same size as in the one big slot cylinders.
Other than the Tee Dee #4, that is correct.
