Changing the crankshaft? Cox_ba12
Changing the crankshaft? Pixel
by Admin Today at 1:35 am
» Engine choice
Changing the crankshaft? Empty
Changing the crankshaft? Empty Changing the crankshaft?
Post  duke.johnson Sun Jun 02, 2013 2:01 am
Ok, don't laugh. I just took the crankshaft out of the engine I plan to run in the contest and I can't remember how to get the new thrust washer back on. I also noticed that the new heavy killer bee type thrust washer has no splines to match the crankshaft. Is there someone still online that can help? Trying to get this ready to fly Sunday afternoon.
duke.johnson
duke.johnson
Changing the crankshaft? Empty Re: Changing the crankshaft?
Post  duke.johnson Sun Jun 02, 2013 2:30 am
Well, I think I remember just putting it on with a prop and prop nut.
duke.johnson
duke.johnson
Post  pkrankow Sun Jun 02, 2013 8:51 am
duke.johnson wrote:Well, I think I remember just putting it on with a prop and prop nut.
Yes, that is pretty much it. Use a stud and nut so you don't overstress the end of the crank.
The crank "cuts" the splines since it is a press fit.
Post  duke.johnson Sun Jun 02, 2013 11:02 am
Thanks Phil
duke.johnson
duke.johnson
Changing the crankshaft? Empty Re:Changing the crankshaft
Post  66 Malibu Sun Jun 02, 2013 12:42 pm
duke.johnson wrote:Ok, don't laugh. I just took the crankshaft out of the engine I plan to run in the contest and I can't remember how to get the new thrust washer back on. I also noticed that the new heavy killer bee type thrust washer has no splines to match the crankshaft. Is there someone still online that can help? Trying to get this ready to fly Sunday afternoon.
There was a large number of new KB prop drivers that came on the market a few years ago that never had the splines cut from the factory. Be careful if you have one in that you can shear off your prop bolt or stud before the crank can cut the splines.I know this because I bought a lot of the Cox R&D replacement parts and I got about a dozen of the "blank" prop drivers. You'll be better off if you buy a new one from Matt or Bernie.....FWIW...Steve
66 Malibu
66 Malibu
Post  ian1954 Sun Jun 02, 2013 1:18 pm
I always remove crankshafts using a vice, a hammer can produce some unwanted results.
For replacement ther are several methods I use.
The best one I have found is using the hub from a rubber spinner.
First I use my little finger to steady the crankshaft and get everything lined up. Tighten up finger tight and then if the back of the propellor is serrated it will grip and it is ready to tighten fully.
Changing the crankshaft? Cranks10
Remember to grip the propellor and remove your little finger from the crankcase!
Use the flat edge of the wrench to tighten up
Changing the crankshaft? Cranks11
The hub works on all the 049s.
Changing the crankshaft? Cranks12
Another method uses an allen headed bolt.
Changing the crankshaft? Cranks13
If you are desperate - use a screwdrive with a slotted screw - but be warned! It is easy to slip with the screwdriver and gouge little bits of finger. The screws are also quite soft and the effort turning them to refit the driver can distort the slot
Changing the crankshaft? Cranks14
ian1954
ian1954
Changing the crankshaft? Empty What am I doing wrong?
Post  batjac Sun Jun 02, 2013 8:03 pm
I have a Medallion .049 that I got off of eBay, and the thrust washer isn't seated well in the crankshaft, giving lots of end play. I tried using the install setup I bought from Bernie. I threaded the stud in, put a prop on, then the washers, and the hub. I used a drop of light machine oil between the washers to minimize friction, and started tightening using a glow plug wrench. Instead of tightening the thrust wsher on the crank, the stud broke. What did I do wrong?
Post  duke.johnson Sun Jun 02, 2013 9:15 pm
Thanks guys. I remembered a little more after I got a little sleep. I took a couple off and on today.
duke.johnson
duke.johnson
Post  RknRusty Sun Jun 02, 2013 9:55 pm
batjac wrote:I have a Medallion .049 that I got off of eBay, and the thrust washer isn't seated well in the crankshaft, giving lots of end play. I tried using the install setup I bought from Bernie. I threaded the stud in, put a prop on, then the washers, and the hub. I used a drop of light machine oil between the washers to minimize friction, and started tightening using a glow plug wrench. Instead of tightening the thrust wsher on the crank, the stud broke. What did I do wrong?
Did the stud break and leave a piece inside the crankshaft that you can't remove? I can't imagine why the stud would snap off if the drive plate wasn't even pressed on. They're pretty soft metal and usually press right onto the splines without much force. Certainly not enough force to break a steel stud. I've been using those studs forever to mount drive plates and never had such a thing happen. I'm not sure why the instructions say to only screw it in 1/4 of the way. I put it in as far as I can leaving enough threads out to get the prop and screw on. I've never used one of those tools, but my prop nut and stud are just the same as Bernie's tool, actually the same parts, minus the washers. I just put the nut down right onto the prop face.
E-mail Bernie and ask him to read your post in this thread and see what he thinks.
Post  ian1954 Mon Jun 03, 2013 9:59 am
I broke a stud some time ago on an engine I was restoring. The drive plate wasn't seated on the splined crankshaft squarely. Rather than take it off and reseat it - I thought it would just be quicker to use the hub to tighten and square it up at the same time.
Wrong!. The angle had well and truly jammed the driveplate tight. As I tightened the hub - the stud snapped!
ian1954
ian1954
Post  Cox International Mon Jun 03, 2013 10:58 am
Depending on how difficult it is to get the drive-plate back on, the studs can break. That is why we include a couple of spares with each "assembly tool".
Here, at the office we do as in the pics. Machined one bolt to fit regular cranks and one for the Killer Bee cranks. Insert into vise and tighten. Stand assembly upright and gently tap drive-plate with a hammer to straighten if required.
Changing the crankshaft? Crankc10
Changing the crankshaft? Crankc11
Changing the crankshaft? Crankc12
Cox International
Cox International
Official Cox Dealer
http://www.coxengines.com
Post  duke.johnson Mon Jun 03, 2013 11:49 am
After changing a few this weekend, I think I'm going to use a vise both on and off from now on. I broke two stud this weekend.
duke.johnson
duke.johnson
Post  batjac Mon Jun 03, 2013 8:03 pm
Bernie, what size/diameter bolts do you use?
Mark
Post  Mark Boesen Mon Jun 03, 2013 10:50 pm
you can also use wood, piece of dowel, etc., less chance of damage. Be sure to recess front for crank counterweight. When done trimming soak up with thin CA to help strengthen wood and minimize oil soak.
Changing the crankshaft? 20130610
Post  Cox International Tue Jun 04, 2013 12:26 pm
batjac wrote:Bernie, what size/diameter bolts do you use?
Mark
Diameter is 13.5 mm (.53") and 25 mm (1") shaft below the head.
You will have to grind down the OD on the bottom half to 12.5 mm (.49") and then take a dremel tool with a ball-shaped grinder and grind a groove for the crank pin.
For the KB crank the mating surface can be straight and for the regular cranks grind the surface to match the crank faceplate.
One does not have to use a vise. Standing the crankcase on its head and tapping with a hammer also works well.
Cox International
Cox International
Official Cox Dealer
