» Roger Harris revisitedby rsv1cox Today at 10:46 am
by MauricioB Today at 10:29 am
by getback Today at 7:48 am
by getback Today at 6:39 am
by Kim Yesterday at 9:18 am
by Admin Yesterday at 1:35 am
» Engine choice
"I Did It My Way" (cutting mach. screws shorter)
I had originally cut four 3-48 size machine screws too short for my Cox TD .049/.051 engine mount application; preventing the full engagement of the 3-48 "lock-nuts".
I had a stock of 1" length spare screws and needed four of them to be cut to a length approx. the thickness of a lock-nut longer than my first ones.
I cut a piece of med. size silicone fuel tubing to the screw-length that I needed... plus the thickness of a #3 flat-washer.
of course; the cutting-wheel on the tool shattered right away... (add 10 min. to locate and replace cutting-wheel... I did it my way)
The screw gets HOT while cutting... ... so I doubled-up on the silicone tubing.. which worked quite well.
The silicone tubing protects the threads of the screw.. and guages the approx. length required.
I used my cordless VSR screw-gun set to reverse with the proper hex-driver installed to remove the studs from the tubing.
Re: "I Did It My Way" (cutting mach. screws shorter)
I use a variation to your method roddie, however your's might be the better option as a Dremel cut-off disc gives a smoother cut.
For odd sizes like the 2/56 and 5/40 so common to our hobby, I use a Vaco tool at the next larger position marked with a nut positioning the proper length and make the cut. Then I back out the nut which dresses the threads.
» Another proposed design by Roddie
» A Quick and Dirty CA Hinge Installation
» Anyone know what size Cox Medallion this muffler is for?
» Davis diesel head improvement
