Defective Glowhead? Cox_ba12
Defective Glowhead? Pixel
by Admin Today at 1:35 am
» Engine choice
Defective Glowhead? Empty
Defective Glowhead?
Defective Glowhead? Empty Defective Glowhead?
Post  Levent Suberk Sat Feb 05, 2022 5:29 am
I tried a new current production Cox glowhead but no glow any. I tried another glowhead and it glows with same glowhead clip and battery. Have you experienced this before?
Post  pman1111 Sat Feb 05, 2022 4:00 pm
Sounds like you may have received a bad glowhead, so far, I have not come across a bad new one, but it is not unheard of. If you have access
to an Ohmmeter, you could test for continuity from the nipple on top of the head to the fins, the reading should be very low, 1 ohm or less would be
my guess, if the head is bad the reading will be very high or OL
pman1111
pman1111
Silver Member
Silver Member
Defective Glowhead? Empty Re: Defective Glowhead?
Post  Levent Suberk Sat Feb 05, 2022 4:08 pm
Yes, I tested with an ohmmeter and it reads around zero ohm. I suspect a short circuit between glow head body and top, in other words between negative and positive poles. Must a tiny aluminum dust perhaps and cleaned it with alcohol and brush, but I couldn't find a particle any. Went to junk, alas.
Defective Glowhead? Empty RE:Defective Glowhead?
Post  pman1111 Sat Feb 05, 2022 4:27 pm
Well, curiosity got the best of me, so I tested a couple heads with my digital meter, .4 or .5 ohms seems to be the norm.
pman1111
pman1111
Silver Member
Silver Member
Post  944_Jim Sat Feb 05, 2022 11:29 pm
Levent,
Considering where you are,.you may want to keep the dead.ine and convert it to a turbo plug adapter. There are posts here and RCUniverse for that. At least it won't go to waste.
