» Roger Harris revisitedby rsv1cox Yesterday at 7:34 pm
» Engine choice
by roddie Yesterday at 9:27 am
My first Cox, a Peewee 020
Hi all,
as I mentioned in my forum intro I've just popped my Cox cherry after 38yrs modelling with a poor old 020 I spotted on ebay. No doubt I payed too much, let this be a lesson not to drink and Ebay, but it is what it is so now I need to give it a birthday with yet more money spent (this time it will be with Bernie or Matt though....).
Can anyone give me a run down on the approximate age of the engine and if it's correctly complete or whether it's a bitsa?
Many thanks in advance, this could be a looooooong journey.
Matt G- Moderate Poster
Re: My first Cox, a Peewee 020
Hi Matt,
This looks to be from 1971-1975 based on the crankcase shape. Cox used the very 'thin-neck' during the early production then switched to this design which has a little less taper than the early ones. The last versions has no taper to the driveplate. At first glance, obviously without seeing the inside, it looks to be in good shape. The fins on the glow head can be straightened out. Could be a slight bend in the needle valve but could also just be the picture angle. Most importantly, the backplate lugs all look good!
Good Luck with the engine!
Matt
Matt
Last edited by EXModelEngines on Wed Sep 09, 2020 9:19 am; edited 2 times in total
Based on the component production periods in Dan Sitter's COX MODEL ENGINE HANDBOOK I would put it between 1969 and 1972. The enlarged neck nose and this type of backplate appears on engines from this period only. Also, e.g. the cylinder was thin walled before 1969 and the crankcases had straight and not tapered nose from 1973.
I repair head fins by prying the blade of a kitchen knife between dented parts and rolling the head along the blade edge until the dent is straightened.
Excellent! Thanks gents, so it's a little older than I am.
Balogh, I did read your post on straightening head fins and will certainly do it that way.
Matt, how is shipping out of the U.S. at the moment? I'll need to place a parts order with yourself or Bernie in the next day or so.
Matt G wrote:Excellent! Thanks gents, so it's a little older than I am.
We have the full array of shipping options available. Standard shipping to your area has been averaging about 20 business days (sometimes up to 30), but we have seen this trending back to the normal range of 7 to 10 business days as of late.
Your first Pee Wee? I was a kid when it first came out and thought it was adorable then and still do today. It will run for about 2 minutes on a full tank of fuel. The printed instructions state: "Close needle valve and open 2 1/2 turns to start". Be VERY careful when closing the needle valve as it is really easy to break off the fragile tip inside the backplate if closed too tightly. If you make this mistake the engine will only run on prime.
(Speaking from experience)
706jim- Gold Member
Awesome, thanks Matt!
So it should have a starter spring fitted by the look of that, added to the list.....
Jason_WI- Top Poster
Jason, you tease!
Jason, is that like a Swear Jar?...
I guess 42 engines LOL >>> WE had some contest at one time whee you would guess the content of engines in a jar or setup and the winner would well win one Engine !
» Davis Diesel Conversion for PeeWee and Davis Diesel Head for PeeWee
» More PeeWee’s!
» *Cox Engine of The Month* Submit your pictures! -September 2024-
» [solved]Black Widow to trade
» .020 PeeWee
» More PeeWee’s!
» .020 PeeWee
