» Night flying at Walters RC parkby 1975 control line guy Today at 7:29 pm
by GallopingGhostler Today at 7:10 pm
by GallopingGhostler Today at 7:07 pm
by LooseSpinner99 Today at 6:13 pm
by balogh Today at 5:08 pm
by rsv1cox Today at 3:44 pm
by Ken Cook Today at 2:54 pm
by 1/2A Nut Today at 10:34 am
by sosam117 Today at 8:15 am
by balogh Today at 7:42 am
The troublesome Corsair engine, the gruesome twosome, another Hero Testors McCoy .049 and the yellow prop returns.
Page 2 of 2
Page 2 of 2 • 1, 2
Re: The troublesome Corsair engine, the gruesome twosome, another Hero Testors McCoy .049 and the yellow prop returns.
I have fiddled with quite a lot of COX engines and found that if stubbornly refusing to start -and the glow head, compression and reed valve are ok and carb is clean - the loose fit of crankshaft in the crankcase is a very likely problem that simply kills fuel draw and charge capabilities of the engine. Elongated use by previous owners with unbalanced props typically leads to this problem. In such instances the radial play of the shaft is already manually sensible.
You may want to check it as this will lead to symptoms similar to the untight gasket on the crankcase back.
P.S.: I just saw that Oldenginerod had suggested the same checking of the crank to case fit..sorry for my repetition
balogh wrote:I have fiddled with quite a lot of COX engines and found that if stubbornly refusing to start -and the glow head, compression and reed valve are ok and carb is clean - the loose fit of crankshaft in the crankcase is a very likely problem that simply kills fuel draw and charge capabilities of the engine. Elongated use by previous owners with unbalanced props typically leads to this problem. In such instances the radial play of the shaft is already manually sensible.
But, it runs fine with the attached 5cc tank. Of course the fuel supply is right there and doesn't have to be drawn from a remote source.
It's Ron's problem now.
Well that just tells you right there You said it ,, If it runs with a tank on it it the backplate/gasket !?!? Hey Bob you getting any this rain and 69* weather ? .> nice here But wet!!
getback wrote:Well that just tells you right there You said it ,, If it runs with a tank on it it the backplate/gasket !?!? Hey Bob you getting any this rain and 69* weather ? .> nice here But wet!!
I have tried it with no gasket, gasket between the case and the reed retainer, and the gasket on the back side of the retainer, no difference. Would not run.
Mailed it to Ron this afternoon.
A little cooler here today, cloudy and rain this morning, sunshine this afternoon. Cloudy now. Still humid. Corn is tasseled.
Troublesome corsair engine
Seems you have tried most options put a killer bee backplate or surestart
Will do your problem will be solved the black backplates are well known
To shrink & crack ( with ) agethe crack will extend from the compression
Side or the n/v spraybar assy to the reed seat almost invisible but opens
When tiightened hence your insurmountable problem thumb over the
Intake & blow or suck always seems ok have seen this twice
Good luck rex or send it to me (postage would cost ) however i can
Fixit rexf.
Fixit rexf.
rex f.- Banned
Page 2 of 2 • 1, 2
» Testors McCoy Product .049 w/ firewall, spinner and prop
» Getting ready to get ready - Running the CW Testors/McCoy engine
» Wen-Mac Corsair
» New shoes and decals for the yellow Prop Rod
» Cox Thimble Drome Prop Rod Yellow with metal bottom
» Wen-Mac Corsair
Page 2 of 2
