Thermal Hopper Package Insert Cox_ba12
Thermal Hopper Package Insert Pixel
» Engine choice
by 1975 control line guy Today at 9:51 pm
by 1975 control line guy Today at 7:29 pm
by GallopingGhostler Today at 7:10 pm
by GallopingGhostler Today at 7:07 pm
by LooseSpinner99 Today at 6:13 pm
by balogh Today at 5:08 pm
by rsv1cox Today at 3:44 pm
by Ken Cook Today at 2:54 pm
by 1/2A Nut Today at 10:34 am
by sosam117 Today at 8:15 am
by balogh Today at 7:42 am
Thermal Hopper Package Insert Empty
Wanted Thermal Hopper Package Insert
Post  Tee Bee Sat Mar 03, 2018 11:56 pm
I just aquired a Thermal Hopper from a local old-timer. It is in good condition and included the original blister pack, though it is cracked and very brittle. I am hoping to find the cardstock insert like the one that came with it. I would even be interested in a photocopied version on paper that I could cut out since this is simply for my own collection. Any help would be appreciated! Also, I'm curious to know what white Cox prop came with this engine originally. Mine has a Too Flite 5.25x4 mounted to it with an incorrect square nut. I plan to buy the proper spinner nut online.
My engine is pictured as is. The one with insert cardstock was found online. Thermal Hopper Package Insert Image118
Thermal Hopper Package Insert Image117
Thermal Hopper Package Insert Image116
Tee Bee
Tee Bee
Wanted Re: Thermal Hopper Package Insert
Post  getback Sun Mar 04, 2018 9:27 am
Nice Looking engine TeeBee It says a 6x3 prop in the instun. sheet but not what kind ? If someone comes up with the insert we should have it put with the Instruction sheet for future fer. ? https://dbabd7f0-a-62cb3a1a-s-sites.googlegroups.com/site/nitroengine/Thermal%20Hopper.pdf?attachauth=ANoY7coNXsYIPupZut9UJqMFxIVTIZHv-a0fJ9RwkydGnNGg-uQMD_Bl0u5MsxsaNlYt8AND-8JbZ7utQyl5HNqm7VEs0dTUq6pkpGNHx0NcchX3mTwXQDQe0JxLKjpnN8V575ly5Ns96sEtB9sOBMn9okcSC6TU0WRMjsqNLlHUE0ky2X58rRc6Und1_bCmwsIa-uqugp0kmy5frA4uxSigdAodfBFDkQ%3D%3D&attredirects=0
Post  Levent Suberk Sun Mar 04, 2018 10:45 am
Tee Bee, if you can send Thermal Hopper insert measurements, I can redraw it in high resolution.
Post  Tee Bee Sun Mar 04, 2018 11:56 am
Wow, that would be a fantastic! The dimensions for the insert card are 3 7/8" x 6 1/2". BTW, you did great work on those battery boxes.
I also wonder if all these Thermal Hoppers came with the bird cage mount. Most of the pictures I've seen online show it in the package without the mount.
Tee Bee
Tee Bee
Post  Levent Suberk Sun Mar 04, 2018 12:01 pm
Tee Bee wrote:Wow, that would be a fantastic!  The dimensions for the insert card are 3 7/8" x 6 1/2".  BTW, you did great work on those battery boxes.
Measurement noted, I begin to work Very Happy
Post  Cox International Sun Mar 04, 2018 4:02 pm
We can certainly high-res scan the insert here if that is what you would like.
Cox International
Cox International
Official Cox Dealer
http://www.coxengines.com
Post  Levent Suberk Sun Mar 04, 2018 4:31 pm
Cox Thermal Hopper insert. A4 size, 300 dpi. Laser print on heavy cardboard gives best result.
Because I haven't this engine so if any change in cut out area needed then let me know.
Download link: http://www.mediafire.com/file/tae3ae768kn9plg/Cox_TH_A4.png
Thermal Hopper Package Insert 2ui0paf7en4ir5u6g
Post  Tee Bee Sun Mar 04, 2018 5:46 pm
Great work! Thanks for the effort, Levent. I look forward to the opportunity to print that out and cut it to fit. Will show the results afterward.
Tee Bee
Tee Bee
Post  crankbndr Sun Mar 04, 2018 6:46 pm
Cox International wrote:We can certainly high-res scan the insert here if that is what you would like.
A good scan of the insert would be great, I had the same problem with a Strato Bug. I was able to copy a photo off of Marks site and work with it to make an insert.
You have a Strato insert also? My copy is OK but could be better.
Thermal Hopper Package Insert Img_2511
Thermal Hopper Package Insert Img_2512
The props that came on these early engines were made by KaySun, they show up on eBay once is a while.
Nice find!!!
Post  Mark Boesen Sun Mar 04, 2018 10:53 pm
Originally Thimble-Drome engines came with the Plasticoat wood prop made by K&B
Thermal Hopper Package Insert P2080110
Thermal Hopper Package Insert Cid_0013
Post  Levent Suberk Mon Mar 05, 2018 1:59 pm
Tee Bee wrote:Great work!  Thanks for the effort, Levent.  I look forward to the opportunity to print that out and cut it to fit.  Will show the results afterward.
Glad you like it.
Post  Tee Bee Tue Mar 06, 2018 6:15 pm
Levent Suberk is the man!  Here is the result.  I'll put up a thread in the engines section with more details.  I'm a happy guy. Hand Shake
Thermal Hopper Package Insert Image119
Tee Bee
Tee Bee
