» Looking For Comet Tri-Pacerby DanMc Yesterday at 7:25 pm
by 944_Jim Yesterday at 7:04 pm
by 944_Jim Yesterday at 4:31 pm
by balogh Yesterday at 4:08 pm
by rdw777 Yesterday at 3:58 pm
by rdw777 Yesterday at 3:46 pm
by roddie Yesterday at 3:07 pm
» Removing old decals
by latole Yesterday at 3:06 pm
by rsv1cox Yesterday at 2:29 pm
» Cox Ryan ST 2.0
by 944_Jim Yesterday at 11:52 am
by getback Yesterday at 6:46 am
by GallopingGhostler Yesterday at 6:33 am
My Cox Minibike
Page 2 of 2
Page 2 of 2 • 1, 2
My Cox Mini Motorcycle Frame Design
roddie wrote:I perused quickly thorough this thread this morning before leaving for work. I really love the frame and front-end! Is this being modeled with a particular full-scale bike in mind.. maybe one you've owned or would like to own?
It looks like you have some room to make decisions on the back-end.. to maybe fit your primary-drive on the output-shaft side.. and final-drive on the opposite side.. sort of like a torque-converter/snow-mobile drive. This might help to balance the bike and give you more options with the final-drive ratio. You'd need to prepare the frame for a pair of bearings to support a cross-shaft. I'll bet you've already though about that.
The centrifugal clutch that Cribbs (Ron) spoke of.. would be an item to seek/source. Try searching Cox/Jerobee engine-drive parts on eBay.. and see if you can find anything. One of our members "overlord" (Lieven.. from France) has recent experience with the Jerobee clutch set-up.. and its' associated parts.. dis/re-assembly.. tuning etc. on a scale-model Corvette that he has, with a similar Cox .049 reed-valve engine. I'm sure he will find your project fascinating!
Please keep us up to date with your progress!
I checked out a few generic style frames over the web to get a general idea, nonetheless the frame is my design. I ride a Yamaha mt-03 and it's nothing like that.
At the moment the frame is made from hollow and weak alloy/aluminum tubing, which i will eventually replace when i fine tune the layout, dimensions, and work on my soldering skills with this blow torch. I wanted to keep that look with the top portion of the frame extending to the rear with no extra support. I think with strong material this frame design could be done at 1/1 scale, and if not i don't mind at all. I could just pretend it's a new super metal
My Cox Bike- Moderate Poster
Re: My Cox Minibike
roddie wrote:
That "looks like" an idler.. but it's actually a band-brake that actuates when the throttle is closed. It's linked to the throttle-servo and wraps-around a groove in the clutch-bell set-up. Try searching Cox GTP Nissan/Maples throttle.. just to see what comes up. I'm not sure if the "Jerobee" models used the same clutch-system.. but I'd bet on it.
How will your cooling-system work? It looks real good.. with all that plumbing and all.. but what will you use to pump the coolant through it? The boat-modelers use a water-jacket that delivers fresh-cool water around the head, via a pick-up tube placed behind the prop for circulation. The associated plumbing carries the fresh-water in-around the head.. and expels it. A closed-system might not provide enough cooling.
Cox Hobbies used "heat-sink heads" on many of there non-aero powered models to help keep the engine cool. They look similar to the one in the above photo.. except they are totally-flat. You might be able to forego the liquid-system completely.. if it will fit within the bike-frame's perimeter.
Here's a photo of the Cox part#8477 heat-sink, designed for their "Sandblaster" model.. and used on many others.
Mounting-options are a linear 360 degrees around the glow-head. It measures 1-11/16"L x 1-1/16"W.. with the furthest point from the center of the head being 1-1/8".
I think you'll need to find a compromise between an exhaust-throttle sleeve.. and that box-header design that you currently have. An .049 exhaust-throttle sleeve will only fit an .049 cylinder that's been "milled" for it. They're usually obtained in pairs. Boxing the header could still be done.. but the sleeve would need to move within the stationary box. It may be better to keep it simple.. with reliable exhaust-throttle/open-header and air-cooled heat-sink head. You could then concentrate more on the centrifugal-clutch drive.
There are other reed-valve engine throttle-systems.. but they wouldn't lend themselves well to your 90 degree engine-layout for this bike. Those can be discussed when you build a shaft-drive bike!
Hey Roddie,
Thank you and others for the feedback and interest in My Cox Minibike.
Firstly, i'm never getting rid of my cooling system hahaa Enough work went in to hacking a graphics card and that's part of the look, even though there there might be a more practical method. That heat sink might work well on my next model if i get there. I'm hoping to get the coolant flowing through using a similar system they use on RC cars i think - that is having an outlet from the exhaust feeding back into the coolant chamber (which i'm yet to make) and that will hopefully force the coolant through the tubes and cooler head and heat sink at the front. I hope to get that system working, but if not i have a back up plan, which is a tiny electric pump i could fit under the front heat sink. It will inevitably be a closed system, but as with a real bike i'm going to use proper high quality coolant, so there's no over heating, not that that should be a problem anyway. Might start it up for a few to demonstrate my handy work on occasions.
As for all the other very useful info on the exhaust setup and so on, i'll have to get back to that depth with the engine. The clutch might be difficult.
Daniel
Re: My Cox Minibike
Maybe you could make the coolant circulation work with thermosiphon?
http://what-when-how.com/automobile/thermo-syphon-water-cooling-system-automobile/
Re: My Cox Minibike
Good to see you back , sometimes people fall off the grid and projects forgotten . Hope things are getting worked out and the seat looks great !
Re: My Cox Minibike
Nice work Dude
akjgardner- Diamond Member
Re: My Cox Minibike
Hey, thanks for checking in. We're still here, still interested.
Re: My Cox Minibike
So are you going put some outriggers on it and try to run it on a tether? That would be cool. Very nice work.
Re: My Cox Minibike
What kind of critters do y'all have in the outback that might be trainable to drive your creation?
Re: My Cox Minibike
ticomareado wrote:What kind of critters do y'all have in the outback that might be trainable to drive your creation?
Too small for a Tazzie Devil!
Cox sandblaster parts
Hi I'm working on a cox sandblaster and need a couple of parts the right side head light and roll cage. I need help can't find nowhere. Thanks Jeff
doggonebules- New Member
Re: My Cox Minibike
Hello jef I think you should publish in the wanted section I remember this post it is very old I wonder what became of this bike project It was a very nice projectdoggonebules wrote:Hi I'm working on a cox sandblaster and need a couple of parts the right side head light and roll cage. I need help can't find nowhere. Thanks Jeff
davidll1984- Diamond Member
Re: My Cox Minibike
Maybe he will pop in @myCoxBike ?? It was cool project !
Page 2 of 2 • 1, 2
Page 2 of 2
