How does one check to see if the crankshft is worn out? (TD .49) Cox_ba12
How does one check to see if the crankshft is worn out? (TD .49) Pixel
by Admin Today at 1:35 am
» Engine choice
How does one check to see if the crankshft is worn out? (TD .49) Empty
How does one check to see if the crankshft is worn out? (TD .49) Empty How does one check to see if the crankshft is worn out? (TD .49)
Post  Matt1967 Sun May 26, 2013 6:40 pm
Matt1967
Matt1967
Moderate Poster
Moderate Poster
How does one check to see if the crankshft is worn out? (TD .49) Empty Re: How does one check to see if the crankshft is worn out? (TD .49)
Post  Ken Cook Sun May 26, 2013 7:00 pm
The TD crankshaft doesn't wear out. It breaks. The case is what wears out. The break occurs either on the crankpin or across the cutout in the front of the shaft typically out of the square edge corners due to not being properly radiused. Ken
Post  JKinTX Tue May 28, 2013 6:41 pm
Ken Cook wrote: The TD crankshaft doesn't wear out. It breaks. The case is what wears out. The break occurs either on the crankpin or across the cutout in the front of the shaft typically out of the square edge corners due to not being properly radiused. Ken
Yep! If you have crank rock then the case is shot. If the crank goes then you usually don't have to worry anymore if the case bearing was any good or not.
JK
JKinTX
JKinTX
New Member
New Member
Post  pkrankow Tue May 28, 2013 9:04 pm
I suspected as such.
Anybody try re-anodizing to get a case back to tolerance? Anodizing in dilute sulfuric acid causes aluminum parts to "grow" and thick layers are relatively hard too.
Post  ian1954 Wed May 29, 2013 4:02 am
pkrankow wrote:I suspected as such.
I am afraid that re-adonising will not get the case back to tolerance. In order to re-adonise the old adonising needs stripping first to get back to native aluminium. There is always some loss of dimension.
It is easier, if you have the equipment, to rebush the case.
ian1954
ian1954
