» Looking For Comet Tri-Pacerby DanMc Today at 7:25 pm
by 944_Jim Today at 7:04 pm
by 944_Jim Today at 4:31 pm
by balogh Today at 4:08 pm
by rdw777 Today at 3:58 pm
by rdw777 Today at 3:46 pm
by roddie Today at 3:07 pm
» Removing old decals
by latole Today at 3:06 pm
by rsv1cox Today at 2:29 pm
» Cox Ryan ST 2.0
by 944_Jim Today at 11:52 am
by getback Today at 6:46 am
by GallopingGhostler Today at 6:33 am
Thermal Hopper restore
I have an original Thermal Hopper and want to replace the burnt glow plug with the original. Some suggest to change to a larger more standard dimension but that would entail changing the cylinder and not keeping with the original engine. does anyone know where I can get the smaller dimension glow plug? If I remember correctly the original diameter is 10 mm and the current plugs are 13 mm.
Thank you for any help or suggestions
oldfreeflight- New Member
Re: Thermal Hopper restore
Welcome to the forum Oldfreeflight! Unfortunately that glow head is no longer made. You will need to scour eBay.
JPvelo- Diamond Member
The early glowheads are pretty scarce, if you're planning to run it you can drill it out and tap for a glowplug, or find a early Herkimer Cub head, its the same diameter and use that with a glowplug.
The early glow heads are very scare and when they come up on Ebay they run around $25. Not bad given current manufactured glow heads run $10, and the early cox glow heads haven't been made in around 50 years. I have seen that Valentine makes a glow head for the thermal hopper that accepts regular Glow Plugs. He sells them from time to time, and this would be the least expensive route (other than making it yourself). Otherwise, you will need to keep your eye open on Ebay and snag one when they come up. You might get lucky and get it cheap. Andy
anm2- Gold Member
You might want to try flyfreeflight.com. They used to take old heads and glow plugs and modify them for different plugs. Good luck.
fit90- Diamond Member
Thank you for the suggestions. I will look into all of them. I want to keep the Thermal Hopper as original as possible
Welcome to the Forum oldfreeflight !!! I have some of these glows but am not able to turn loose of them at these time , spares are expensive and I don't think you can change the cyl/pis assy out for it want fit the case if I remember correctly . If you are going to bee purchasing I would look for the same style engine in lots , that way you get extras . The 302RH glow is what you are wanting .
Left: #302RH Right: #302
Cox #302RH 1953 Racing Head - Hemispherical shape - High Compression - Smaller dia. threads as used on Space Bug, Thermal Hopper, Space Bug Jnr and Strato Bug Only.[30]
Art Johnson has tons of Cox parts and engines; vintage to current. art_johnson36@comcast.net
He's always at Toledo up on the rail with the MECA guys
GWILLIEFOX- Rest In Peace
Thank you GWILLIEFOX for the E mail address. Waiting for a reply from Art
getback wrote:Welcome to the Forum oldfreeflight !!! I have some of these glows but am not able to turn loose of them at these time , spares are expensive and I don't think you can change the cyl/pis assy out for it want fit the case if I remember correctly . If you are going to bee purchasing I would look for the same style engine in lots , that way you get extras . The 302RH glow is what you are wanting .
Photos????
» Two new in package Pre 1955 glow heads Space hopper/ Thermal hopper etc
» Space Hopper .049/Thermal Hopper .049
» Screw sets for Cox 049 Thermal Hopper - Space Hopper - Space Bug
» Thermal Hopper
» Thermal Hopper Question.
» Thermal Hopper
