by rsv1cox Today at 10:26 am
by getback Today at 9:55 am
by Ken Cook Today at 8:06 am
by rsv1cox Today at 7:32 am
» Looking For Comet Tri-Pacer
Plastic Prop Driver
Plastic Prop Driver
A couple of years ago, I purchased a parts lot off of ebay. The lot contained several .049 prop drivers and a few of them appear to be made out of plastic. Has anyone seen or heard of anything like that? Does anyone know what they were for? Thanks for any information. Andy
anm2- Gold Member
Re: Plastic Prop Driver
By prop driver do you mean drive plate? I have never seen a plastic one, a picture would be helpful if you can muster one up.
Never heard of a plastic drive plate, but some of the thrust washers that go behind it are plastic. I always use the steel ones if I need one at all.
Yes, I meant plastic drive plate. It is identical to the hex drive plate, except it is plastic. I can not imagine what it was used for.cribbs74 wrote:By prop driver do you mean drive plate? I have never seen a plastic one, a picture would be helpful if you can muster one up.
anm2- Gold Member
Are you sure it's not a plastic spring starter clutch?anm2 wrote:Yes, I meant plastic drive plate. It is identical to the hex drive plate, except it is plastic. I can not imagine what it was used for.cribbs74 wrote:By prop driver do you mean drive plate? I have never seen a plastic one, a picture would be helpful if you can muster one up.
JPvelo- Diamond Member
JPvelo wrote:Are you sure it's not a plastic spring starter clutch?anm2 wrote:Yes, I meant plastic drive plate. It is identical to the hex drive plate, except it is plastic. I can not imagine what it was used for.cribbs74 wrote:By prop driver do you mean drive plate? I have never seen a plastic one, a picture would be helpful if you can muster one up.
I am unfamiliar with the term plastic spring starter clutch, so I wouldn't know. The item I am talking about is identical to the .049 hex drive plate that is common to the drive plate found on the sure start engine, and the latter engines that were designed to not allow the propellor to turn clockwise.
anm2- Gold Member
I guess we're going to need a picture Andy, so
we can all say we've never seen one.
dckrsn- Diamond Member
dckrsn wrote:I guess we're going to nee a picture Andy, so
Fair enough. I will try to post one. "Try" being the keyword.
anm2- Gold Member
I bet you have something that was produced by someone with a 3D printer or was practicing molding parts. I sure wouldn't use it.
RknRusty wrote:I bet you have something that was produced by someone with a 3D printer or was practicing molding parts. I sure wouldn't use it.
Yes, I tried to mount one to an engine, and it split. Unless I am mistaken, it can't be used. It is an excellent copy. If they used a 3D printer, it did a great job.
anm2- Gold Member
» K&B greenhead Torpedo 19/23 prop driver
» My ball-driver set
» When did the Prop Rod convert from aluminum pan to plastic?
