» 12 string guitar suggestions by 1/2A Nut Today at 1:58 pm
by Admin Today at 1:11 pm
by roddie Today at 10:48 am
by rsv1cox Today at 10:26 am
by getback Today at 9:55 am
by rsv1cox Today at 7:32 am
Hydro Boat
Re: Hydro Boat
Check the Dumas "Lil Swamp Buggy" .049 pusher kit.
A nice air boat that travels over water, snow or wet grass. Made of mahogany sheeting it's a sharp looker with a clear finish. Mine is running two channel RC powered by a throttled Sure Start .049.
SuperDave
SuperDave
SuperDave- Rest In Peace
Re: Hydro Boat
Also check this site for model hydroplanes:
Model Hydroplane Laser Kits - A Cut Above Boat Works
(1/2A's are 1/16 scale)
SD
SD
Re: Hydro Boat
SuperDave wrote:Also check this site for model hydroplanes:
(1/2A's are 1/6 scale)
SD
SD is there a website you wre thinking of or should we google "Model Hydroplane Laser Kits - A Cut Above Boat Works "?
duke.johnson- Diamond Member
Re: Hydro Boat
Duke:
A Cut Above Boat Works is the site but it didn't send as "clickable".
Don't know why or how to make it so.
SD
SD
Re: Hydro Boat
Thanks
Re: Hydro Boat
Fantastics Hidroplanes !
http://www.acutaboveboatworks.com/
But I´m looking for a plan for a simple home made Hidroboat.
I think to cut the middle of ...
Re: Hydro Boat
What are you going to make with a plastic jug?
SD
SD
Re: Hydro Boat
I'm sureou'll not find plans for a boat made from a plastic jug. You are on your own on that one.
How large do you want your hydroplane to be?
What will power it?
SD
What will power it?
SD
Re: Hydro Boat
Sounds like something in the 20" LOA range.
What type of propeller? Air or water?
SD
SD
Re: Hydro Boat
I've mentioned this before but you said that you wanted to build one from a plan.
Tower Hobbies # LXE383 Dumas Li'l Swamp Buggy Kit 18"
Accessories Needed Add to Wish List
34.99 In Stock
SD
34.99 In Stock
SD
Re: Hydro Boat
If it's any help I used Sullivan "Gold-n- Cable" #507 controls on my Dumas "Lil'Swamp Buggy". You'll need two sets; one for the rudder and one for the throttle.
Further I used Futaba S3114 micro-servos concealed under the deck hatch.
SD
SD
Re: Hydro Boat
The Dumas "Lil Swamp Buggy" has a single rudder which seems plenty adequate on mine because it is located directly behind the pusher APC prop.
The boat performs best when running at full-throttle and also because of the semi-V hull.
What would be the advantage of two rudders? (They would make starting the engine more difficult because the rudders would get in the way and could become damaged)
SD
SD
Re: Hydro Boat
Take a look over here - http://www.rcairboats.net/phpBB/index.php
They have hyooj resources for airboat enthusiasts.
At the bottom of this page - http://ozzietraders.com/Pacific_Balsa/DIE_CUT_SERIES/die_cut_series.html
There are 3 boats. I'm in the throes of modifying a Challenger and a Dictator to use Surestarts, probably as pushers.
I've been playing with airboats for years. I no longer muck around with air rudders. I use only water rudders, easily available on E-Bay, beautifully CNC machined parts. This just 1 example. There are many out there.
http://www.ebay.com.au/itm/RC-Model-Ship-55mm-Silver-Aluminium-Cooling-R-C-Hobby-Boat-Rudder-HR275-/281110228095?pt=AU_Toys_Hobbies_Radio_Controlled_Vehicles&hash=item417379ac7f
Re: Hydro Boat
Something I should mention: Dumas' kits are little better than fire wood! As there are no importers of Dumas kits in Oz I bought a "Big Swamp Buggy" kit, figuring that for the over-inflated price it'd at least be OK. Alas and alack, not so!! I was so disgusted that I left it on the shelf for over a year. I've since begun to use the kit parts as templates and am slowly building a modified "BSB" using plywood which is better than the scrap pieces of sub-standard fire wood supplied by Dumas.
I could not possibly recommend a Dumas kit to anyone.
» Hydro Blaster pictures and manual scans .
» Boat people
» Norvel .061 in RC boat
» Cox .049 boat engine
» Boat people
