Power Pod for my 3-Meter Bird of Time Sailplane Cox_ba12
Power Pod for my 3-Meter Bird of Time Sailplane Pixel
» COX .020 POWERED SPEEDSTER
by 1/2A Nut Today at 1:00 am
» *Cox Engine of The Month* Submit your pictures! -November 2024-
by rdw777 Today at 12:53 am
» Cox extra 300s
by 1975 control line guy Yesterday at 9:57 pm
by Ken Cook Yesterday at 7:53 pm
» Took an engine out last week
by rsv1cox Yesterday at 6:41 pm
by Ken Cook Yesterday at 4:16 pm
» Throttle control for Cox .010 "Viking" engine.
by ffkiwi Thu Oct 31, 2024 9:12 pm
by roddie Thu Oct 31, 2024 8:33 pm
by roddie Thu Oct 31, 2024 7:50 pm
by 1975 control line guy Thu Oct 31, 2024 9:54 am
» The Wood Shovel
by getback Thu Oct 31, 2024 5:27 am
by crankbndr Wed Oct 30, 2024 7:08 pm
October-2024
MauricioB's
"Cox .049 Circa 1975, custom."
Power Pod for my 3-Meter Bird of Time Sailplane Empty
Power Pod for my 3-Meter Bird of Time Sailplane Empty Power Pod for my 3-Meter Bird of Time Sailplane
Post  Kim Fri Dec 14, 2012 2:34 pm
I was gonna copy Travis on the details of the engine pod I made for my 3 Meter Bird of Time Sailplane, but decided to just post it here in case someone else could also make use of it. So far, I've used it equipped with Medallion and Olympic .15's (which pull it to altitude with authority, even when packing cameras), and my trio of Cox RR-1's.
Enlarging the drawing to get the tips of the base 5 1/2 inches apart will get you the size I use on the Big B.O.T.
Power Pod for my 3-Meter Bird of Time Sailplane Pod111
The skins are 1/16th ply, as are the base plates, and have been plenty strong for their purpose.
The core is 1/2" balsa (a great opportunity to use up stray chunks of balsa that are bouncing around in the bottom of your scrap box). You can use odd-shaped pieces arranged to fit closely together and epoxied to the left skin. Let them extend beyond the ply side and, then trim them back when it's all glued together. The top engine bearer contours to the shape of the top of the pylon.
Power Pod for my 3-Meter Bird of Time Sailplane Pod_211
I moved the pylon back to provide elbow room for all the cameras I'd intended the B.O.T. to carry. It could be redesigned and moved forward, but I often fly it with the cameras replaced by ballast, and have had extended thermaling flights right at the limits of my eyesight. I don't know the angle of the engine verses the wing, but just employed TLAR (That Looks About Right) principles which have mostly served me well over the decades. Besides, I believe that is why God created elevator trim !
The rear of the pylon is secured by the stock wing bolts that come with the kit. The base is cut out to accept the ply plate on the top of the trailing edge, with another piece of ply capping it.
Power Pod for my 3-Meter Bird of Time Sailplane 1_11
The front is secured by internally epoxying a dowel to the side of the wing's center ribs, with a hole large enough for a wood screw long enough to pass through and catch the pylon base (probably be a good idea to imbed a receiving dowel here, but I haven't done it yet). It's capped on the bottom with a piece of ply, and uses a slightly bent fender washer to match the wing's dihedral. (make sure that this will all fit inside the B.O.T.'s narrow fuse opening.)
Power Pod for my 3-Meter Bird of Time Sailplane 5_10
Power Pod for my 3-Meter Bird of Time Sailplane 4_10
Of course, the whole thing can be "prettied up" with some paint and streamlining instead of troweling on epoxy and hanging the tank out in the breeze with rubber bands, but I like seeing the wood, and getting at the tank and other stuff with ease.
Power Pod for my 3-Meter Bird of Time Sailplane 410
Power Pod for my 3-Meter Bird of Time Sailplane Empty Re: Power Pod for my 3-Meter Bird of Time Sailplane
Post  daddyo Fri Dec 14, 2012 2:49 pm
Wow what a great in-flight photo, not to mention countryside
daddyo
daddyo
Post  pkrankow Fri Dec 14, 2012 2:57 pm
I'd like to see the camera mount too, please.
Post  Kim Fri Dec 14, 2012 2:59 pm
Thank You! It's a frame-capture from one of those tiny, High Def Key Chain Video Cameras.
Post  Kim Fri Dec 14, 2012 8:29 pm
pkrankow wrote:I'd like to see the camera mount too, please.
Sorry I missed your post Phil,
Here are photos of the camera I used to get the inflight photo. It's mounted to an Icon servo, which is in turn mounted to an aluminum arrow shaft. The servo is plugged into the unused throttle channel on my transmitter.
Of course, the plane has to be balanced back to it's original CG ( I use small ziplock bags with lead shot, taped where they are needed). Another caution is to make sure that the wing structure will not twist under the load of the shaft and camera.
Power Pod for my 3-Meter Bird of Time Sailplane 8_10
Power Pod for my 3-Meter Bird of Time Sailplane 7_11
Power Pod for my 3-Meter Bird of Time Sailplane B_11
Power Pod for my 3-Meter Bird of Time Sailplane 510
Post  pkrankow Fri Dec 14, 2012 9:19 pm
That is really neat! Simple too.
