» coreflute helpby Levent Suberk Today at 10:03 am
» *Cox Engine of The Month* Submit your pictures! -June 2024-
by Levent Suberk Today at 9:54 am
by Levent Suberk Today at 8:54 am
by HalfaDave Today at 7:15 am
by rdw777 Yesterday at 5:08 pm
by Levent Suberk Yesterday at 4:04 pm
» S.M.A.L.L. 2024
by balogh Yesterday at 12:21 am
by rdw777 Fri May 31, 2024 4:24 pm
» Feed Station Zebra.. Spring 2024
by roddie Fri May 31, 2024 4:10 pm
by Cox International Fri May 31, 2024 1:08 pm
» Cox Mustang repair
by getback Fri May 31, 2024 7:29 am
by batjac Thu May 30, 2024 10:52 am
Custom Cox 049 with spark ignition
I got this at the Perry Georgia swap meet this past March.
The seller didn't know who built it.
I really like the spoke head & that tiny spark plug.
Cylinder is a number 1 that has been modified. The exhaust
ports are a bit taller and the thick wall has been turned down
some creating the fins between the exhaust ports.
It has been run but not yet by me.
iamplanecrazy2- Silver Member
Re: Custom Cox 049 with spark ignition
Pretty neat setup. The crankcase looks to be an Aurora Tornado. The tank and backplate are Cox although the tank itself has been turned down some.
You should run it!
You should run it!
When I first saw it I also thought it was a Tornado case.
After another look I realized it is a Cox cast case that has been smooth out and polished.
The cylinder threw me at first because of the two short fins between the exhaust ports.
I definitely need to run it.
So, how does that work, is there a cam lifting a push-pin to contact the points? And the curved extension coming out of the cam housing(if that's what it is)? A timing adjustment, maybe?
RknRusty wrote:So, how does that work, is there a cam lifting a push-pin to contact the points? And the curved extension coming out of the cam housing(if that's what it is)? A timing adjustment, maybe?
Exactly right Rusty, there is a flat spot ground on the crank shaft that the push pin
runs over. When the pin hits the flat spot the points close causing the spark plug
to fire. The pin is located under the arched part of the moving points.
The curved extension is called the timer arm and you are right again, that
is how the timing is adjusted. Just needs a coil, condensor, battery pack,
and fuel to run.
Very interesting, did I understand right that you can change the timing of the ignition while running or is it static?
coxaddicted- Gold Member
coxaddicted wrote:Very interesting, did I understand right that you can change the timing of the ignition while running or is it static?
You can (and have to) adjust the timing on all spark ignition engines, you normally have to retard the spark for starting, then advance it as the engine picks up speed, too far advanced on starting can result in a very nasty kick-back and a VERY sore finger!
Ivanhoe- Diamond Member
I know what you mean. On 4 cycle engines it is standard with a variable ignition but for 2 cycle engines you can use a static-ignition position I think (of course a variable ignition is better for starting and peak performance).
From my understanding:
Starting - early ignition (high torque and hot combustion)
peak - late ignition ( combustion gets colder, torque is low)
Tell me if i am wrong. I also know that it is not easy to compare 4 and 2 cycle engines.
The cox motor is something between 2 cycle and diesel engine I would say .
coxaddicted wrote:From my understanding:
Tell me if i am wrong...
Yeah, actually the other way around. For spark igntion engines, ignition is/should be retarded for starting/slow running, so you don't have combustion/max pressure before TDC ('kick back' when starting a m/c for example). Then ignition needs to be advanced at higher rpm as the burn rate (and time to reach maximum pressure in combustion chamber) stays more or less constant, so you don't have maximum pressure way after TDC, which is inefficient (less power) and leads to other bad things. In a nutshell.
Historically, two strokes could get away with fixed timing, because it made the ignition system cheaper/more reliable (no advancer needed), and at low rpm the two stroke has less energy per revolution (but twice as often) as an equivalent (whatever that means) four stroke. So kick/pull starting was less of a problem.
ahrma_581- Gold Member
ahrma_581 wrote:coxaddicted wrote:From my understanding:
Yes, as I said, but I must admit that I had a momentary doubt as to if I'D got it backwards, despite always starting model spark ignitions with the ignition retarded after the first time I got a sharp rap on the finger!
Wilf
» Spark ignition coils
» .010 4/Stroke Spark Ignition!
» SPARK Ignition Queen Bee!
» Otto Bernhardt TD 15 Special Ignition engine
» Low Spark... Traffic
