» Feed Station Zebra.. Spring 2024by roddie Today at 5:53 pm
by balogh Today at 5:17 pm
by cstatman Today at 1:59 pm
by cstatman Today at 1:41 pm
by Myk Yesterday at 10:26 pm
» Scientific Gulfhawk
» Memorial Day 2024
Ohlsson & Rice Restoration
Well, here's my new project, I must be mad!
Ohlsson & Rice 23, Spark Ignition, circa 1947
I have always wanted an old spark ignition engine, and when this one came up for $10.00 on EBay I couldn't resist it!
As you will see from the photo, there is a lot missing! Including the whole circuit-breaker assembly, whether I ever manage to find the parts (at least at sensible prices!) remains to be seen!
It would appear that the front induction was an after-market add-on, which could be bought to convert the engine from it's original rear side-port induction, the rear intake was plugged with a cork when it was used!
Until the engine arrives I don't know how this worked, but it will be interesting to find out!
If anyone knows anything about these engines (Sparkers) I'd be grateful for information,
and pointers to useful websites would also be appreciated.
This engine is from before even MY time, and I know very little about them, like I say, I must be mad!
Wilf
Wilf
Ivanhoe- Diamond Member
Re: Ohlsson & Rice Restoration
Don't know if it's "Madness" or "Passion"...or if it matters...but it sure is fun !
Nice Find Wilf,
Hope you get it up and running. I passed on an old K&B this week for $15. I was thinking of buying it and selling for Cox stuff. Box, papers,decals. There are still good deals out there as you've found.
Admin wrote:I have a complete O&R .23 if you want pictures and details.
If yours has the front rotary induction as well I'd be interested in any photos, especially how the circuit breaker assembly fits on the front.
I have a list of O&R serial numbers which gives the date of manufacture, if you don't know it already that is!
thanks
Wilf
Re Ohlsson and Rice Restoration
Mine is serial no 405575 would be nice to know year. Mine has been
converted to glow by simply putting pressed tin cover over timing cam,
as many of the old sparkies were. Mine has an insert in intake throat
held in by the needle valve assembly, presumably to reduce power for
free flight and easily removed for CL
https://i.servimg.com/u/f46/17/26/04/06/twin_l14.jpg
https://i.servimg.com/u/f46/17/26/04/06/twin_l15.jpg
You can just see residue of red paint on head.
Mine is probably O&R 19 rather than a 23
John
John
proctor- Gold Member
proctor wrote:Mine is serial no 405575 would be nice to know year. Mine has been
John
Yes, it's a .19, front rotary valve 19's from 1948 until production ended in early 1953 had serials from 406849 to 433682, so your's is somewhere towards the middle of that period, around say, 1950. The research done so far hasn't narrowed it down any closer, but the list is due for an update anytime now, so we may get it closer.
I read that Ohlsson left the company in 1949 and records weren't kept very well after that.
I can give you a little bit of advice, as I have dismantled our O&R 29 a couple of times:
- the Cyilinder and head are one piece. they were spot welded together during manufacture so they cannot be taken apart. to remove the piston, twist the piston 90 degrees and pull it out from the bottom.
- the piston has a deflector bar on it, and the narrow end need to point towards the intake, or AWAY from the exhaust.
- The only difference I can see between the O&R spark and glow models is a plastic spacer where the points went and a glowplug on top. might be a way to try it out while you are looking for ignition parts.
- Spark coils are all the same, but if you want to throw this on a plane, you could look at spark coils for chainsaws, as they are pretty compact.
Puffie40- Bronze Member
Thanks Ivanhoe, awesome decals! have not run my O&R yet but it's got
a lovely plop to it so will get it on the bench tomorrow.
John
John
Ivanhoe wrote:Admin wrote:I have a complete O&R .23 if you want pictures and details.
thanks
Wilf
LOL, I have the rear induction with the little plastic "thimble" tank on the back. I knew something looked a little off!
Puffie40 wrote:I can give you a little bit of advice, as I have dismantled our O&R 29 a couple of times:
Yes, thanks Puffie, that's a good idea about trying it out as a glow, one thing that is worrying is whether it has the early rubber seal between the head and the cylinder, I read that they are prone to leaks, and are nearly impossible to repair because of the "staked" head/cylinder, I just hope it's the later alloy one on this, just have to wait and see! Good tip about removing the piston, and thanks for the detail about the piston baffle position, I'd have been sure to put it back the wrong way round!
Wilf:
My first model aircraft engine was a new circa 1952 O&R .23 front rotary which was a new concept for the time replacing the rear intake used previously.
It appears the the engine shown has had front rotary attached and is therefore incorrect for a "sparker". If you intend to convert it back to spark you'll need to ditch the front rotary and go back to the rear intake system. You'll also need a "sparker" crankshaft as a front rotary uses a different crank. Wheter the internal porting would match, I haven't a clue.
Don't let me disparage your quest for the correct parts. Just know that they exist. Enjoy the hunt.
SuperDave- Rest In Peace
SuperDave wrote:Wilf:
As far as my reading so far goes, the front rotary setup was at first a factory "aftermarket accessory" in that you bought a kit of the altered crankshaft and the front section of the crankcase, plugged the rear inlet and replaced the contact breaker assembly on the new front end (see photo)
There is certainly no need to go back to the rear inlet setup to run it as a spark ignition.
I can get a new contact breaker assembly for about 5 times what I paid for the engine, but at least they ARE available!
My biggest problems will be getting replacements for the prop driver and washer, parts like that just don't seem to be being reproduced yet, and also, if it is the early version with a rubber gasket between head and cylinder, and it's leaking, it's virtually impossible to replace due to the staked together head and cylinder.
Oh well, just makes it more interesting!
I was not aware of an O&R factory coversion kit from spark to rotary.
I wrote only from memories some sixty some years past.
"Given enough time and $$$$$, anything is possible."
SuperDave wrote:I was not aware of an O&R factory coversion kit from spark to rotary.
It's the $$$$$$$ that's bothering me!
In the end will the finished product justify the the expenditure of the $$$$$$$$$$$$?
Only you can answer that, my friend.
A $10 engine could cost a hundred when "restored"..
SuperDave wrote:In the end will the finished product justify the the expenditure of the $$$$$$$$$$$$?
Good O&R 23s sell for between $150 & $220 (the last price was a NIB example) WAY out of my league, but a little here and a little there, and the enjoyment of putting a scrapper back in service, and ending up (Hopefully) with a usable spark engine is what I'm aiming for, after all any hobby is going to cost you money!
Well, the O&R arrived today, it's in much better condition than it looked in the photo, internals are very clean (I understand that sparkies don't gum up like glows) although the piston crown is well carboned so it's seen a fair amount of use, according to the serial number it was made in 1947, so it's nearly as old as I am, but I think it's worn rather better!
I need to find a replacement prop driver as a first priority so that I can see if it will run as a glow before I lay out big bucks on a replacement contact breaker assembly.
If anyone knows anyone, private or commercial, who might have any O&R spares I'd appreciate a contact.
I'll post progress pictures as I get them.
mitchg95- Diamond Member
I finally got an exact date on this engine, thanks to the helpful folks on the "Ignition Treasures" thread on RC Groups. It's actually 1948 manufacture, later modified to front rotary induction.
Nice to know just how old it is!
Wilf:
I believe that I mentioned the possibility of the modfication when you first posted about the O&R but now you have it from an authoratative source as well as an acturate date of manufacture.
Nice detective work, Inspector!
Thanks, I got a copy of the original instruction leaflet, and the conversion kits are listed on it, $5.00 for the front case and a replacement crankshaft!
John
I've just discovered that the intake insert was standard on these engines John, but is obviously missing from mine, any chance that you could take a picture down the intake so that I'd have some idea what to look out for?
thanks
Wilf
» Ohlsson & Rice .29
» Ohlsson & Rice .75
» The Little Ohlsson & Rice .049 Runs
» Arden .099 VS Ohlsson & Rice "23"
» i have an ohlsson&rice tether car motor and it needs help
